E body rear brake line to proportioning valve fitting #3176811
09/20/23 09:42 PM
09/20/23 09:42 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anyone know the fitting size for the rear brake line that goes to the proportioning valve for a e body? I'm installing one of the wilwood mopar 4 bolt master cylinder kits and the output port on the proportioning valve for the rear brakes is 3/8-24 and the rear brake line fitting is larger. Do they sell any adapter fittings to adapt the two sizes? This is sold as a mopar specific kit, yet the sizes don't work with the factory rear line.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: E body rear brake line to proportioning valve fitting [Re: 73cuda340] #3176912
09/21/23 12:15 PM
09/21/23 12:15 PM
moparx Offline
moparx  Offline
at most good parts stores, there is usually a bin or rack with brake adapter fittings of all sorts, so you should be able to find something there.
i used to have some Edelman part numbers here, but i don't know what i did with them.
i'm thinking the larger size would be 7/16-14 [common for 1/4" line] or 1/2-20, still common size fittings used with 3/16" brake lines.
beer
Re: E body rear brake line to proportioning valve fitting [Re: moparx] #3177001
09/21/23 05:59 PM
09/21/23 05:59 PM
clarks summit pa
clarks summit pa
I'll have to keep looking around. Every parts store around me has everything but what I need
Re: E body rear brake line to proportioning valve fitting [Re: 73cuda340] #3177004
09/21/23 06:09 PM
09/21/23 06:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why not call the place you bought the ill-fitting kit from.
Re: E body rear brake line to proportioning valve fitting [Re: NITROUSN] #3177099
09/21/23 10:06 PM
09/21/23 10:06 PM
clarks summit pa
clarks summit pa
The lines are the right size. They matched the original valve. It’s just the wilwood proportioning valve is too small. They only list the size that their fittings are, but not the factory size
