Balancing beads with car tires
#3176455
09/19/23 07:21 PM
09/19/23 07:21 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Has anybody ever tried using balancing beads for a set of car tires? I know they're mostly used with semi trucks, but I've read some places where they say you can and others saying you can't. I don't see why it would be a problem, and if it does work, it's better than having the stick on weights that fall off after a couple thousand miles. This site sells kits for car and truck tires https://www.abcbalancingbeads.com/
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Balancing beads with car tires
[Re: 73cuda340]
#3176470
09/19/23 07:53 PM
09/19/23 07:53 PM
Posts: 12,240 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We have mounted and balanced a lot of tires. If you have stick-on weights that are falling off, someone is doing something wrong. That is not normal.
The balance beads have their place. We have tried them. For certain applications, they work. But for the vast majority of passenger car and truck balance though, the tried and true clip on and stick on weights are hard to beat.
Two things about the beads, DO NOT breath them and it takes a minute or so of driving after every stop for the beads to re-balance the tire. Not a problem for over the road situations, but not cool in stop and go traffic. And they are much more expensive than the others.
Master, again and still
[Re: 73cuda340]
#3176481
09/19/23 08:21 PM
09/19/23 08:21 PM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
I am not saying that my theory is correct but I wouldn't use them. They are designed for tire types that may not be passenger tires. I had a good tire and a rim with a leak from rusty rim. Tire was good and rim was straight so I popped the bead and slipped in a tube on a tubeless tire. I made it about 5 hours out of town and the tread left the tire. Still had pressure and all but the tread peeled off. I credit this as I used a tube in a tubeless tire and they were not compatible. Might have built up undo friction inside the tire when they flexed, maybe it was limiting the natural flex of the tire, not sure but it happened. I am open to other opinions. It seems like passenger tires would flex more than truck tires so the beads would be moving more often or two much causing undo heat or bead degradation. So unless the tire is made for them I wouldn't use them. Btu that is me.
[Re: IMGTX]
#3176494
09/19/23 08:37 PM
09/19/23 08:37 PM
73cuda340
clarks summit pa
The beads listed in the link don't rotate around in the tire, they claim to use a static charge and stay in place for the life of the tire. There's a few videos on their website about the difference compared to the regular equal that's used. I'm not against it, however I'm not completely sold on using it, I figured I would just ask if anyone has used it out of curiosity. As far as the stick on wheel weights falling off, the last three sets of tires that I've had mounted and balanced have all fallen off after a while. My vehicles rarely get driven due to having a company vehicle for work, so my tires last for years, so maybe part of the issue Is the adhesive wearing out after a couple of years.
[Re: 340SIX]
#3176703
09/20/23 02:55 PM
09/20/23 02:55 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
https://www.amazon.com/Loctite-Plas...;hvtargid=pla-4584207589768777&psc=1The left hand tube in the LOCKTITE Plastics package does not have liquid in it - instead it is a “magic marker style pen” with a felt tip that spreads a kind of “Primer layer for glue sticking improvement” . Since I have several of these markers left over after the superglue tube either runs out or hardens, Ihave tried the markers with completely different glues than Loctite. So far this has seemed to have helped every time. I do not know whether it would help lead balancing weight adhesive stick better to wheels.
[Re: 360view]
#3176723
09/20/23 04:19 PM
09/20/23 04:19 PM
Posts: 19,587 north of coder
moparx
on a whim, i bought some air soft pellets one time [only $4.99 at wally world for a giant size bottle of pellets] and tried them inside some tires on my "bus" [caravan]. i measured the amount for each tire on a postal scale, installed one side of the tire on the rim, dumped the pellets in, then installed the other side of the tire. they seemed to work. as these tires and wheels were my winter tires, i used them for several seasons and all seemed ok. as last year was a virtual no snow winter, [ ] i didn't put them on. would i do it again ? i really don't know. just my own personal experiment. your mileage will vary.
[Re: BDW]
#3176808
09/20/23 09:35 PM
09/20/23 09:35 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
My tape weights are falling off too, been on about 2-3yrs? How should the rim be prepped? brake clean may work depending on it's composition but is a good start. If one chooses to get really anal do the following. 1. Acetone wipe the area until a white paper towel stays white. 2. Follow with and alcohol wipe down, again until the towel remains white. 3. Scrub the area with a mild abrasive 220 or coarser. The scratches create more surface area for the adhesive. 4. Follow up with another alcohol wipe down until clean. 5. Apply adhesive weight trying not to touch any part of the adhesive. 6. Applying as much pressure as possible roll the top off the weight with a wooden or metal seam roller A bit over the top but I'll bet that weight will be hell to get off
[Re: 340SIX]
#3176916
09/21/23 12:27 PM
09/21/23 12:27 PM
moparx
How do you figure out how much air soft to put in? i just used the guidelines i found on line as to the amount in ounces needed of the "beads" per tire size, then used that figure to measure out the same amount in the air soft pellets. i used a postal scale, put a cup on the pad, then zeroed out the cup. poured in the pellets until i got the correct amount, done. rinse and repeat for the other three tires. i had studded winter tires on the front, and i wore those things down to almost the wear bars and didn't have any problems with vibration of any kind.
[Re: moparx]
#3177078
09/21/23 09:16 PM
09/21/23 09:16 PM
TJP
Omaha Ne
I seem to remember some magic gimmick in the 60's or 70's that involved balancing beads in your cars tires, maybe JC Whitney deal ??? There were also these LINKY or these
