Re: Best place to buy trans parts(46re)
[Re: volaredon]
#3176452
09/19/23 07:06 PM
09/19/23 07:06 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
Try Tranz Depot, in Michigan.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: volaredon]
#3177987
09/25/23 09:24 AM
09/25/23 09:24 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Just ordered what I need from eBay, lotsa options, but couldn't believe how many show as being shipped straight out of China, I made sure to avoid them. I wanted the HD borg warner gov pressure sensor and the rostra HD gov pressure transducer. I found the transducer cheap but all the sensors were "std duty". And I need 00 and up, most were 96-99 versions. Once I get past the problem I have I want to start beefing this thing up a bit. . But don't want to add any more things to the fire to potentially cause more problems before I get they the ones I have now. I just swapped tranny's and this one works ok but doesn't shift like the old one did before it crapped out. Start with the valvebody from the old trans, take it apart and clean out all the old fluid.
[Re: volaredon]
#3178161
09/25/23 05:34 PM
09/25/23 05:34 PM
Posts: 3,076 Michigan
A727Tflite
I was thinking about that, was also thinking about starting with the existing VB and pop the new solenoid and transducer in and see if it solves the problem with the computer wanting so much gov pressure once I exceed a certain speed. I got a 3rd VB here, from a guy in another forum that he said was for my year but has the older style of governor sensor/transducer. Supposed to be a fresh rebuild with new solenoids but they won't work for 00 and up. (Mine is 01) What problems are you having? Also you refer to the computer wanting so much gov pressure. What do you mean here ?
[Re: A727Tflite]
#3178168
09/25/23 06:02 PM
09/25/23 06:02 PM
Posts: 2,237 ILLINOIS
volaredon
ILLINOIS
When I plug in the scanner and watch it while someone else drives as soon as I hit 34 mph the "desired" governor pressure goes from close to the mph I'm driving, and jumps to 126 8 psi and stays there no matter what speed I am at as long as I'm in the gas in the least, even just maintaining speed. As soon as I let off the gas and coast the " desired" pressure follows the speed I am going. Then the trans tries to meet the "desired" pressure the computer wants to see. If the actual actually crosses 100 psi then I get a CEL for "gov pressure high". It seems to drive fine though. When I monitor the voltage of the governor pressure, it goes to 1.46v at 33 mph and jumps to 3.46 volts, skipping the "2.-xx" volt range completely. I have another computer (actually the original one from this Durango) that I have had on the shelf for a while, I tried plugging it in as a "substitute known good part" step and it does exactly the same. I have likewise subbed in a known good TPS being that I can duplicate it very reliably just by driving and crossing 34 mph, and no change there either .that "126.8" psi desired seems to be some kind of a default reading.
Now my 96 Dakota also has a 46re and does not act like that I drove that one and monitored the scanner just like I do in the Durango, just for comparison. Both are stone, dead stock, no mods. No chip, no performance tube or anything.
[Re: volaredon]
#3178171
09/25/23 06:08 PM
09/25/23 06:08 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
Replace your output speed sensor while you are under there , the one that screws into the driver side lower part of the rear extension housing. you wouldn't believe how many issues that can cause with pressure readings
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: volaredon]
#3178172
09/25/23 06:13 PM
09/25/23 06:13 PM
volaredon
ILLINOIS
What's weird is this problem with setting a high governor pressure started only after I had the whole dash out to replace the evaporator and the heater core. My original trans crapped out very shortly after I had the dash reassembled to which I blame on 311,000 miles of use if I had to guess id say the overrunning clutch went bad by the way the trans was acting. It was actually fine once it got to 3rd and 4th, but shuddered terrible from takeoff, thru 2nd and until it hit 3rd. The fluid came out all glittery, but the weird part is though the replacement trans shifts fine, it still has that weirdness where the computer wants the same crazy gov pressure is the same as with the other trans. The trans I put in gas been under my bench for 3-4 years, but it came from a u pull, out of an identical Durango that looked like it didn't belong in a junkyard. It (the trans) was very clean, and freshly painted "rebuilders gray". I have no doubt it was a very fresh overhaul, if I had to guess the customer couldn't pay the bill, so the shop got a "mechanic's lien" on it and scrapped it. But the u pull had a "sale" and the price was too good to pass on. I spent more for a case of ATF+4 than I did for the trans. I have a tough time believing that these sensors and the old ones were all bad, but then again it was in a junkyard for some reason, I had rebuilt the trans myself that croaked 65k before and I didn't replace the electronics in that trans either, I have no idea if whoever did the rebuild on this trans did while they had it apart either, so I basically want to put new ones in so I can eliminate it for sure and establish some sort of a baseline with it...
[Re: jwilson 61]
#3178174
09/25/23 06:18 PM
09/25/23 06:18 PM
volaredon
ILLINOIS
Replace your output speed sensor while you are under there , the one that screws into the driver side lower part of the rear extension housing. you wouldn't believe how many issues that can cause with pressure readings Oh really? I've replaced those a few times over the years (don't remember if I ever did this one) but i know I had to a few years ago on my Dakota, and when that one went it started shifting all sorts of weird. I wouldn't have suspected that sensor for the problem I'm now having. I've also had (as weird as it sounds) a rear O2 screw with me before, but ive replaced it on this Durango and no change. On the output speed sensor I had to replace one on another Dakota I used to have, after I caught something with a front tire in the road and it spit up and smacked the output sensor on that one. I've had quite a few Dakotas with the 46re over the years.
[Re: volaredon]
#3178186
09/25/23 06:46 PM
09/25/23 06:46 PM
A727Tflite
Now my 96 Dakota also has a 46re and does not act like that I drove that one and monitored the scanner just like I do in the Durango, just for comparison. Both are stone, dead stock, no mods. No chip, no performance tube or anything. Drive your Dakota again and let me know what the actual gov psi does once it gets in to third then OD . I’m betting the gov pressure will rise quickly to 120+ in OD.
[Re: volaredon]
#3179725
09/30/23 10:36 PM
09/30/23 10:36 PM
volaredon
ILLINOIS
update time The other day I got my "Rostra" gov sensor and my "HD Borg warner" solenoid in the mail, and my new ATSG book. Today I put it up on my lift, (yes I have my own) dropped the pan, and changed the filter (again) and those gov sensor and solenoid. The "desired" pressure does just like it did. Jumps straight to 126.8 soon as I pass 34 mph. The "actual" though does like the original, failed trans did before I swapped them. The "actual" gets to ~75-80 then levels off and falls back a few PSI. It doesn't try to "catch up with" the "desired" PSI like the replacement trans did with the original solenoids that were in it when I got it//. and even the wife noticed, it shifts just like it used to before the original one went bad. so, I can confirm my beliefs that the trans failure was pure coincidence// and had nothing to do with having the dash out of it just a few days before. I had been pulling my hair out, rechecking grounds and every wiring plug to be sure they were snapped in as designed.
It's just weird the shudder in the original trans started 15 miles, after I had the dash out and back in. the fact that I have 312k miles on this rig, probably has nothing to do with it, huh? well, the redundant grounds I ran, in trying to troubleshoot this, sure won't hurt anything. I had had much of the dash (back) apart more than once checking things. along with the wiring diagrams on Mitchell On'Demand that we have at work.
I have a few-years-old ATSG book on the 42/44re, and I didn't see much of anything in there about the governor, other than pix of the different sensors and solenoids used thru the years of the "RE series. I just got the "latest" 46-47-48RE book from them, and there it was in black n white. there is a section on governor operation that wasn't in the other book I have....
It never did start out in 2nd or 3rd and "stay there" though, as it said was the usual symptom of gov sensor/solenoid issues. but the new book did describe how the governor is supposed to work in a way that I "got" (understood). and it appears that part of what I was seeing was right, the only part of what I was seeing that wasn't, was the "actual" side of governor pressure. Now it shows on there (the scanner), as should be expected/ at least according to that book. I did head to town and threw a new output speed sensor on there "for good measure". the only thing that didn't get done, was that I bought a new spring for the 3-4 shift in the VB, when I bought the solenoid and sensor, and being we had "somewhere to be" I put it back together and forgot to swap that out. No, I never pulled the cover off, so nothing open, nothing loose in there. But I have found several of those particular springs busted in 1/2, over the years so I was "wanting to" replace it while I was in there, though it was very obvious that this was a VERY recent overhaul, because I got it from a U pull, I have no idea who rebuilt it, or how extensively. but it works fine. the trans temp reading with the new solenoid and sensor is making more sense now than with the old set in there, as well.
I am gonna have to stock up on trans filters via Ebay, rock auto, etc, This was the 2nd time since I swapped that trans, that I had to pay an outrageous $28 at my local O'Wrongleys for a Wix trans filter.... and then $34 for that output sensor. of course I have 6 of the older, non plastic cased, 904/727/500/518 trans filters here already.... For a trans that I "just had to have" on a sale day at the U pull for $60 with converter (I think core was something like $28 then, besides) like 4 years ago, I spent $157 on the first case of ATF+4 and filter that went in the day i swapped it in, then $120 for the HD solenoids, then another $60 in fluid today and that 2nd filter (the one I bought today) and the output speed sensor, but I think I finally got it solved.
