Denso 90A alternator - IG amp draw
#3173173
09/05/23 04:47 PM
09/05/23 04:47 PM
Posts: 17 Chicago area
Magnum GT
Chicago area
Hello,
Does anyone know the amp draw on the IG wire (12V key on) for the Denso 90A alternator? I've searched the net and can't find any conclusive number.
Thank you,
Steve
Steve
1979 Magnum GT 2011 1500
Re: Denso 90A alternator - IG amp draw
[Re: Cab_Burge]
#3173358
09/06/23 02:00 PM
09/06/23 02:00 PM
Magnum GT
Chicago area
Thank you everyone.
Cab-That will be a while. Drivetrain is out of the car and I'm laying out the wiring plans for the EFI, ignition, in tank pump and Denso conversion.
What am I doing....
Steve
[Re: AndyF]
#3173588
09/07/23 02:46 PM
09/07/23 02:46 PM
Magnum GT
Chicago area
Thanks Andy, good idea. I looked at some schematics and although the wire gauge wasn't indicated, I did find a few that show a 7.5A fuse in the ignition line. I took a look at your website for the 90A alternator install instructions and I see what you mean regarding small wire gauge on the pigtail connector.
Steve
[Re: Sniper]
#3174228
09/10/23 02:39 PM
09/10/23 02:39 PM
Posts: 1,016 rust belt
Moparite
rust belt
Does anyone know the amp draw on the IG wire (12V key on) for the Denso 90A alternator? Maybe I don't, IG wire? Ignition wire? The alternator had nothing to do with the draw of the ignition. A amp probe will tell you the draw on any wire. [video:youtube] https://www.youtube.com/watch?app=desktop&v=VNZgm0hatzU[/video]
[Re: Moparite]
#3174238
09/10/23 03:41 PM
09/10/23 03:41 PM
Posts: 6,326 nowhere
Sniper
nowhere
Does anyone know the amp draw on the IG wire (12V key on) for the Denso 90A alternator? Maybe I don't, IG wire? Ignition wire? The alternator had nothing to do with the draw of the ignition. A amp probe will tell you the draw on any wire. [video:youtube] https://www.youtube.com/watch?app=desktop&v=VNZgm0hatzU[/video] What feeds the (usually) blue wire that connects to one of the field terminals? The ignition circuit. The other field terminal connects to the regulator green (usually) wire. ![[Linked Image]](http://www.mopar1.us/elec.jpg)
[Re: Sniper]
#3174408
09/11/23 01:16 PM
09/11/23 01:16 PM
Moparite
rust belt
The ignition circuit. The other field terminal connects to the regulator green (usually) wire. Blue wire(one going to the regulator) is battery power(key on), The green is the way the regulator "regulates" the alternator output. This is relatively low amperage and the regulator varies voltage to the field to control output.
[Re: Moparite]
#3174500
09/11/23 05:22 PM
09/11/23 05:22 PM
Sniper
nowhere
The ignition circuit. The other field terminal connects to the regulator green (usually) wire. Blue wire(one going to the regulator) is battery power(key on), The green is the way the regulator "regulates" the alternator output. This is relatively low amperage and the regulator varies voltage to the field to control output. The blue wire is the IGNITION ONE circuit. That's how the factory labeled it, that's how the OP referred to it. You can call it a ham sandwich if you want, but no one's going to have it for lunch.
[Re: 360view]
#3175237
09/14/23 07:40 PM
09/14/23 07:40 PM
Sniper
nowhere
Good link.
So the “IG” wire on Denso alternators only has to carry enough current to “bias on” a transistor switch inside the Regulator IC Chip - probably a low current. Only if it's an internally regulated alternator though, which may or may not apply to the OP's alternator because Denso made both styles.
[Re: Magnum GT]
#3175276
09/15/23 12:12 AM
09/15/23 12:12 AM
Posts: 43,307 Bend,OR USA
Cab_Burge
Thank you everyone.
What am I doing.... Me too, ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) on two cars under construction, one drag race (150.00+ MPH 1/4 mile, 130 MPH in the 1/8 mile) only and the other street only ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Sniper]
#3175310
09/15/23 09:12 AM
09/15/23 09:12 AM
Magnum GT
Chicago area
Yes, 90A alternator, internally regulated. AndyF's (AR Engineering) conversion.
Steve
