simple Engine run stand. #3174605
09/12/23 10:41 AM
09/12/23 10:41 AM
Finally a HUSKER again
Moparnut426 Offline OP
I built a run stand for my 434, Its a very basic very simple engine, converted points distributor to petronix, just curious how you guys would wire it up, Im using my simple hand button on the starter to start it. I was going to run the red wire to + coil, Black wire the - coil, then run red wire to a simple on off toggle switch, and ground to ground, toggle wire to + battery, then I could roll the engine over and flip the switch for ignition.
Curious if this will work, or If I am over thinking it...
Re: simple Engine run stand. [Re: Moparnut426] #3174632
09/12/23 12:16 PM
09/12/23 12:16 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You would have to follow the wiring on the conversion kit. I went through this recently and went with one of those all-in-ones from 440 source for $100. Works great. For a starter I used a simple push button from Bumper-to-Bumper and a Ford solenoid. (Kinda like a chassis race car.)
2011 Drag Pak Challenger
Re: simple Engine run stand. [Re: rickseeman] #3174674
09/12/23 02:07 PM
09/12/23 02:07 PM
NC
440Jim Offline
440Jim  Offline
NC
Rick,
I like you put a master shut off electrical switch on the panel.
Here is mine. The switch panel was a leftover, so I used it. It has fused circuits.
