Re: Trans and rear
[Re: cudaman1969]
#3174055
09/09/23 04:08 PM
09/09/23 04:08 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
The transmission will have an id pad on side. The 2nd row will have numbers that contain the assembled date. It corresponds to a 10,000 day schedule that Chrysler has and published. Its on the net if you look it up. It shoukd say something like p833 1234 5678 The first set of 4 nimbers is the date pf assy (on the 10,000 day scedule. The remaining 4 numbers are the unit number for that day.
The dana has numbers on the rear facing pass axle tube. There is a BOM number that id’s the model dana. Then below usually are a date code. Month , day, and yr isually from what i’ve seen. Ex 9 20 66
Hope this helps.
Re: Trans and rear
[Re: cudaman1969]
#3174082
09/09/23 07:45 PM
09/09/23 07:45 PM
Chargerfan68
New York, USA
602829 is the BOM for all 66/67 The date code will tell which year.
Photo of numbers on a ‘67 Dana for reference (borrowed from another post somewhere):
The date is actually in this format : 12 2 6 ( Dec 2nd 1966)
Re: Trans and rear
[Re: cudaman1969]
#3174181
09/10/23 10:18 AM
09/10/23 10:18 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
'66-'67 Dana 60's have a drain plug in the bottom of the housing. Only years that did.
Re: Trans and rear
[Re: Chargerfan68]
#3174403
09/11/23 01:03 PM
09/11/23 01:03 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Hope this helps. If the trans is a 66 it won't have the ID pad , that started in 68.
