Hemi suddenly has insatiable craving for oil?
#3173576
09/07/23 01:31 PM
09/07/23 01:31 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
So a friends truck has gone from using 1 qt between oil changes to using 1qt ever 100 miles overnight, no smoke, no noise, no blow-by, no misfire, no leaks... I thought maybe a piston chipped but even with the PCV hose plugged it barely shows any blow by and even that is smooth and not puffing at all.
Re: Hemi suddenly has insatiable craving for oil?
[Re: redraptor]
#3174059
09/09/23 04:42 PM
09/09/23 04:42 PM
Posts: 10,707 North Dakota
6PakBee
North Dakota
There's only two ways that oil gets out of a motor. It burns it or it leaks it. It doesn't just magically disappear.
[Re: 6PakBee]
#3174111
09/09/23 10:32 PM
09/09/23 10:32 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
If he's running synthetic oil, you won't see it burn.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: 1969ronnie]
#3174390
09/11/23 12:31 PM
09/11/23 12:31 PM
HotRodDave
Kalispell Mt.
I change the oil here at my shop it gets done religiously every 3000 miles and we use oreilly brand synthetic 10-40 in the summer and 5-40 in the winter. Oil filters are oreilley generic (wix).
My first thought was I didn't get the drain plug or filter tight but I checked them and they are dry and tight... I also thought maybe I got distracted or something and didn't actually fill it up the last time but even after topping it up it still keeps dropping rapidly.
[Re: HotRodDave]
#3174395
09/11/23 12:42 PM
09/11/23 12:42 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Dave, you have replaced the PCV?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: HotRodDave]
#3174457
09/11/23 03:40 PM
09/11/23 03:40 PM
Posts: 421 montana
BANDIT
montana
Hey Dave, was going to send you a PM, but your over limit. Can you reach out to me? Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#3177264
09/22/23 04:52 PM
09/22/23 04:52 PM
HotRodDave
Kalispell Mt.
260 8596 with a Montana areola code to call or text
[Re: HotRodDave]
#3216183
02/25/24 09:25 PM
02/25/24 09:25 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
my son's build was doing this. all kinds of oil. On disassembly we think that it was pushing oil from the oil feed to the heads thru the mls gasket. On one cylinder all the gasket layers were saturated with oil. The block wasn't decked and checked ok but I think that was the problem. The leak down was good, etc.
[img] [/img]
