Re: FORD F150 $5600 tail lamp repair ? [Re: not_a_charger] #3172502
09/03/23 08:08 AM
09/03/23 08:08 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
One thing I don't understand is why manufacturers don't add any drainage or ventilation to lights. It's a well known problem of water intrusion and it doesn't have to be a manufacturing defect but just minor damage.
The easiest fix is an 1/8" drill bit
It's not just lights either. Plenty of vehicles get water pudding in trunks and floors. Just recognize that keeping water out is very difficult, finding a leak even more so. The standing water is the big problem, let it out.
Angry white pureblood male
Re: FORD F150 $5600 tail lamp repair ? [Re: ruderunner] #3172510
09/03/23 09:09 AM
09/03/23 09:09 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Modern day car ownership outside of the OEM warranty means owning a liability. Even when under warranty- the problem may have no fix and the customer gets strung along for a BS ride. (Think dual clutch Ford transmissions)
Keep old mopars alive.
Re: FORD F150 $5600 tail lamp repair ? [Re: 2boltmain] #3172531
09/03/23 10:22 AM
09/03/23 10:22 AM
ohio
ohio
A big reason I like older vehicles, all the problems are known and solved.
Re: FORD F150 $5600 tail lamp repair ? [Re: ruderunner] #3172795
09/04/23 12:00 PM
09/04/23 12:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 06 Ram sliding back window has leaked for years, I’ve drilled more hole in the channel but done with it. That black gooey stuff they stick under windshields is next sealing the whole sliding part. I looked into a solid glass but was quoted $600 to install.
Re: FORD F150 $5600 tail lamp repair ? [Re: cudaman1969] #3172916
09/04/23 06:16 PM
09/04/23 06:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
We did a lot of warranty repairs on those Rams, resealing the back slider-window assemblies.
A lot of the leaks were at the top, and the sealing could also be pretty poor at other areas around the perimeter.
Frequently it was actually the CHMSL above the back glass leaking.
Ft cab lights were another occasional leak source.
Re: FORD F150 $5600 tail lamp repair ? [Re: topside] #3173364
09/06/23 02:33 PM
09/06/23 02:33 PM
South Dakota
hotairballoonpilot Offline
South Dakota
I tell so many people that come into the shop that there are 3 things you need to have with any late model vehicle.
A factory warranty that covers as much as possible
Full coverage that covers as much as possible
lastly deeppocket books to cover what the above does not cover.
Contact Me about AMD Prices
Re: FORD F150 $5600 tail lamp repair ? [Re: cudaman1969] #3173371
09/06/23 02:56 PM
09/06/23 02:56 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Are you sure the leak isn't coming from your 3rd brake? It's a well known problem in that era truck.
https://www.detroitmuscletechnologi...asket-chmsl-leak-repair-adhesive-backed/
Re: FORD F150 $5600 tail lamp repair ? [Re: not_a_charger] #3173617
09/07/23 05:07 PM
09/07/23 05:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Think thats bad price one for a Super Duty. Or even better a newer Benz.....
Re: FORD F150 $5600 tail lamp repair ? [Re: hotairballoonpilot] #3173753
09/08/23 11:03 AM
09/08/23 11:03 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its a double edged sword. People want all the tech- all the niceties bells and whistles and the MFGRs are happy to give it to them. No one takes the time to consider what the cost of that tech will be 5 plus years down the road. Toyota as a business would die if they built their current vehicles to the quality standard they established in the 1990s. I know why the MFGRs switched to electric blend door motors- but my god it can be thousands to replace them deep in a dash. Cable and vacuum blend door operation is notwancient and maybe barbaric- but it worked fine for the second, third fourth etc owner of that vehicle as it aged.
