Camshaft ID please #3172652
09/03/23 07:51 PM
09/03/23 07:51 PM
owt west
Thread Ender1 Offline OP
owt west
Any ideas of camshaft manufacture and spec? its solid lifter rough measurement of .530 lift ..it scribed 285-295 and 108 as well as the other visable numbers
hope the pics are good enough, thanks in advance
Re: Camshaft ID please [Re: Thread Ender1] #3172654
09/03/23 07:56 PM
09/03/23 07:56 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm not to much help but that is a comp cam. the c over c denotes that. See what they list at those durations and lobe center.
Re: Camshaft ID please [Re: Thread Ender1] #3172656
09/03/23 07:56 PM
09/03/23 07:56 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Looks almost like a regrind to me. Like comps old way of writing and mopars way of stamping.
STOP POTATO HATE!
Re: Camshaft ID please [Re: Mr PotatoHead] #3172657
09/03/23 07:59 PM
09/03/23 07:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I agree with that also.
Re: Camshaft ID please [Re: Mr PotatoHead] #3172659
09/03/23 08:02 PM
09/03/23 08:02 PM
owt west
owt west
its a bb 3 bolt, it does have a cc on it also, 285-295 any rough ideas duration at .050
thanks for your input
Re: Camshaft ID please [Re: Thread Ender1] #3172692
09/03/23 09:47 PM
09/03/23 09:47 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
probably something like 250/260 just a guess I could look at my cc lobe catalog tomorrow. Looked like there was a serial number on it maybe they could look it up.
Re: Camshaft ID please [Re: Thread Ender1] #3172717
09/04/23 01:52 AM
09/04/23 01:52 AM
there are several options on how to find out how this cam is ground now, mock it up in a block with #1 or and #6 pistons and two solid lifters with a degre wheel on the crankshaft and a TDC indicator and rotate the motor around with a decent dial indicator reading off the intake lifter and record the readings at .050 lifter lift before and after TDC, then check the lobe separation angle on that lobe and then do the other exhaust lobe the same way.
The other easier way is to take that cam to good machine shop or speed shop that has a cam checker and have them check it and give you their results work scope up shruggy
Re: Camshaft ID please [Re: Thread Ender1] #3172753
09/04/23 09:53 AM
09/04/23 09:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
285-1/295-1 S108 is a Comp Cam utilizing the “High Torque” series of lobes.
It’s 250/260@.050 and has .355/.370 lobe lift, and is ground on a 108lsa.
The lobe catalog shows them to use .018 lash, but those are some of Comps earliest lobes.........and “back in the day” the recommended lash was .026”.
Re: Camshaft ID please [Re: fast68plymouth] #3172804
09/04/23 12:38 PM
09/04/23 12:38 PM
owt west
owt west
Thanks for everyone's input..the good is it's probably a good core that shouldn't flatten a lobe
