Re: trailer break away system Q [Re: Wirenut] #3172602
09/03/23 03:09 PM
09/03/23 03:09 PM
A 25 amp relay may be a better choice than the fuse work scope twocents
Re: trailer break away system Q [Re: Cab_Burge] #3172617
09/03/23 04:04 PM
09/03/23 04:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'd suggest a maybe 30a breaker if wire size is larger than 14g, being this is only potentially for intermittent use during breakaway. and 14g+ will handle short periods of 25A as breaker resets.
Re: trailer break away system Q [Re: Wirenut] #3172624
09/03/23 05:09 PM
09/03/23 05:09 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
One more trick. Get a second dead man switch. Mount it under the trailer close to the axle. Run the pull cable through the wheel. If the wheel ever rotates it'll pull the pin. The brakes will be on. Good theft device.
Doug
Re: trailer break away system Q [Re: jcc] #3172799
09/04/23 12:15 PM
09/04/23 12:15 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Was thinking the same
Re: trailer break away system Q [Re: dvw] #3172800
09/04/23 12:15 PM
09/04/23 12:15 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Doug
Very smart
Re: trailer break away system Q [Re: Wirenut] #3172807
09/04/23 12:44 PM
09/04/23 12:44 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Until you forget it's hooked up and drive away, not that I would ever do that. rolleyes
Re: trailer break away system Q [Re: jcc] #3172812
09/04/23 01:04 PM
09/04/23 01:04 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
That's how I know it works. You don't move very far.
Doug
