Electronic distributor gap #3172538
09/03/23 10:53 AM
09/03/23 10:53 AM
BlueRacer69 Offline OP
Hey people, can someone tell me what to set the gap at on the Mopar Performance Electronic Distributors? I forget. Old age is sitting in. lol. Thanks.
Re: Electronic distributor gap [Re: BlueRacer69] #3172542
09/03/23 11:23 AM
09/03/23 11:23 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
0.008 using a brass feeler gauge..
Just my $0.02.. wink
Re: Electronic distributor gap [Re: Sinitro] #3172556
09/03/23 12:06 PM
09/03/23 12:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That seems about right from memory.
Re: Electronic distributor gap [Re: BlueRacer69] #3172559
09/03/23 12:17 PM
09/03/23 12:17 PM
Quote
It'll get worse!
Re: Electronic distributor gap [Re: markz528] #3172561
09/03/23 12:20 PM
09/03/23 12:20 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I never seem to forget stuff like that. The gap for electronic dist with the brass feeler and the V8 firing order are a few things that are etched into my brain.
Re: Electronic distributor gap [Re: RapidRobert] #3172583
09/03/23 01:50 PM
09/03/23 01:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by RapidRobert
Quote
It'll get worse!
iagree frown
Re: Electronic distributor gap [Re: Sinitro] #3172584
09/03/23 01:57 PM
09/03/23 01:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have found over the years to check the parallelism between the reluctor and pickup is a good idea as they are sometimes tweaked. Also a good idea to check all 8 points and for play in the shaft. I have set them as wide as .010 to compensate when needed with no noticeable effect beer
Re: Electronic distributor gap [Re: TJP] #3172593
09/03/23 02:43 PM
09/03/23 02:43 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't know about the MP distributor but I've run into a couple stock ones that as the vacuum advance moved the pickup plate, the gap decreased. I had one where the gap decreased to the point the reluctor contacted the pickup.
Re: Electronic distributor gap [Re: BlueRacer69] #3172597
09/03/23 02:55 PM
09/03/23 02:55 PM
Only if you live long enough for that to set in luck up grin
Re: Electronic distributor gap [Re: 6PakBee] #3172615
09/03/23 03:53 PM
09/03/23 03:53 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Had the same situation years ago. Couldn't believe engineers didn't anticipate that happening. Aftermarket ball bearing breaker plates solved the problem.
Re: Electronic distributor gap [Re: 6PakBee] #3172649
09/03/23 07:27 PM
09/03/23 07:27 PM
years ago one of our members from south america (Nacho) did something to his advance plate to where he got the change down to several thou iirc to resolve that. not sure what he did but you might eyeball it & see if anything jumps out at you that you might alter that will decrease the change.. EDIT I am thinking that he just relocated the pivot point so there was less arc in the sweep
Re: Electronic distributor gap [Re: RapidRobert] #3172658
09/03/23 08:00 PM
09/03/23 08:00 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Take the distributor out of the motor. Spin the shaft and look for the smallest gap and go from there.
Re: Electronic distributor gap [Re: Rollin Hand] #3172796
09/04/23 12:02 PM
09/04/23 12:02 PM
^^^ this. find the one closest & set it at .008"
Re: Electronic distributor gap [Re: Rollin Hand] #3172956
09/04/23 08:43 PM
09/04/23 08:43 PM
That's good advice. Thanks for that information.
