trailer break away system Q #3172330
09/02/23 01:49 PM
09/02/23 01:49 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hi All,
Any reason why I cant use a full size car battery to power the breakaway switch? Right now I have a full size battery on boar that is independent of the tow trucks electrical system. The battery just powers a radio and some lights on the trailer . The little breakaway system battery crapped out and I would like to eliminate it .
Thanks for looking
Re: trailer break away system Q [Re: Wirenut] #3172335
09/02/23 01:58 PM
09/02/23 01:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
12 volts is 12 volts….. hook it up!
Re: trailer break away system Q [Re: J_BODY] #3172389
09/02/23 03:37 PM
09/02/23 03:37 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Not a problem at all.
Re: trailer break away system Q [Re: J_BODY] #3172396
09/02/23 04:02 PM
09/02/23 04:02 PM
iagree wrench scope
Re: trailer break away system Q [Re: Wirenut] #3172414
09/02/23 05:25 PM
09/02/23 05:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by Wirenut
Hi All,
Thanks for looking
Only issue I see, is a small partly charged breakaway sized battery if seeing a system short for some reason, will likely drain itself rather quick, vs an unfused fully charged full size car battery might burn the trailer and its cargo down promptly. I don't know the current needed for brakes in a breakaway situation, but a large fuse, 30-50A? would give you some peace of mind I would think.
Re: trailer break away system Q [Re: jcc] #3172417
09/02/23 05:42 PM
09/02/23 05:42 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If I’m in a situation where that system has to be used….. a burning trailer is a few items down the list for sure.
Fwiw I’ve had trucks towed into work with stone dead batteries only to figure out faulty brake controllers or bad brake switches energized the trailer brakes all night…. no fires to report on my end.
I’m betting in a lot of cases those tiny batteries are in a state where they wouldn’t apply the brakes for too long anyways….. great, going to check mine.
Re: trailer break away system Q [Re: J_BODY] #3172424
09/02/23 06:25 PM
09/02/23 06:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You know I was addressing an unfused short, right?
Re: trailer break away system Q [Re: jcc] #3172435
09/02/23 07:43 PM
09/02/23 07:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only time the brake system could be energized is if the dead man switch plug is pulled out. The seperator plug attached to the pull cable is plastic. When its pulled the contacts inside the switch touch each other completeing the positive side of the circuit. If there was a short from the battery to ground it wouldn't be any different than if you were using a car battery in the trailer for a winch, lights, etc. Simple enough to place a knife switch at the battery itself and open it while the trailer is parked.
Doug
Re: trailer break away system Q [Re: jcc] #3172459
09/02/23 09:29 PM
09/02/23 09:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Yes…. and this conversation peaked my curiosity and it appears you’ll find on most rv’s, toy haulers that utilize their larger battery as a source for the “break away” switch that circuit is not fused. I read some discussion on a 40amp self resetting breaker being installed on that circuit.
…..now thinking how most RV, toy hauler, race trailers are wired that’s kind of scary.
Re: trailer break away system Q [Re: dvw] #3172463
09/02/23 09:57 PM
09/02/23 09:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, I agree, but one aspect here stands out to me, The OP has a dead backup battery and has not yet IMO confirmed why it's dead, and there are a number of benign reasons it is, but if a short is involved, installing a battery with 10? times the capacity, even if the same voltage with no current limiting could be a recipe for disaster.
Re: trailer break away system Q [Re: J_BODY] #3172465
09/02/23 09:59 PM
09/02/23 09:59 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
On my 7k axles, they draw 6 amps per axle, So stick a 30 amp fuse in it and send it.
Joe
Without Data, you’re just another guy with an opinion.
Re: trailer break away system Q [Re: jcc] #3172515
09/03/23 09:26 AM
09/03/23 09:26 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hi All,
Thanks for looking
This is actually what I was wondering. Do they use the small battery so that the available current is very small as opposed to a larger battery. In the case of a short in the wiring between the battery and plunger switch the wiring is so short and small I sure it would simply burn off and it all outdoors.
When you apply your trailer brakes do they see a full 12 volts? Or would a full 12 volts damage the system? I think I should check that .
Thanks for all the replies.
Re: trailer break away system Q [Re: jcc] #3172516
09/03/23 09:26 AM
09/03/23 09:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The brakes are connected to the tow vehicles battery as well. So where ould there be a difference?
Doug
Re: trailer break away system Q [Re: sr4440] #3172517
09/03/23 09:27 AM
09/03/23 09:27 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Joe
Do you know if they see a full 12v or does the brake switch limit voltage?
Re: trailer break away system Q [Re: jcc] #3172518
09/03/23 09:29 AM
09/03/23 09:29 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Small battery is just old .
Re: trailer break away system Q [Re: Wirenut] #3172521
09/03/23 09:54 AM
09/03/23 09:54 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Joe
My brake controller shows it ramping up proportional to the force required. For emergency braking, it is directly connected to the battery, the full 12 (13.2) volts.
My trailer has living quarters and a generator, and i wanted to hook to the large battery, so I ask the inspector about the battery, he said "as long as the battery is independent of the towing vehicle" and able to fully apply the brakes if disconnected from the tow vehicle.
Joe
Re: trailer break away system Q [Re: Wirenut] #3172523
09/03/23 09:58 AM
09/03/23 09:58 AM
A727Tflite Offline
A727Tflite  Offline
Joe
The controller varies the voltage based on need, more voltage, more stopping power. I think most controllers have a variable setting that adjusts trailer brake application based on pedal application.
Re: trailer break away system Q [Re: Wirenut] #3172525
09/03/23 10:03 AM
09/03/23 10:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Joe
I'm going to say no, at least most of the time, if you set the gain to max it may. My understanding is that electronic controllers are essentially a rheostat, more gain = more voltage to the brakes, which equals more braking. Years ago, my brother had a hydraulic/electric controller, the more you pressed the brake pedal the more brake the controller applied to the trailer, it worked very well.
Re: trailer break away system Q [Re: sr4440] #3172543
09/03/23 11:24 AM
09/03/23 11:24 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Just like sr4440 said, my trailer is a 48' goose neck w/ living quarters and it doesn't even have a "small" battery, it has 2 large deep cell 12v batteries. EVEY\RYTHING runs off of them.
Brian
Re: trailer break away system Q [Re: '72CudaRacer] #3172578
09/03/23 01:09 PM
09/03/23 01:09 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Ok good enough. Tossing the small battery . Will put a 30 amp fuse in line after the switch.
Thanks again everyone
