TF270 Heads....HP #3172243
09/02/23 09:00 AM
09/02/23 09:00 AM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
With a typical stroker build, a real cam, what kind of HP are you guys getting out of these? Just trying to see what runs better, the Indy of the TF's.....
Re: TF270 Heads....HP [Re: Dragula] #3172276
09/02/23 10:59 AM
09/02/23 10:59 AM
AndyF Online content
AndyF  Online Content
The TF270 heads make 700 hp with typical bolt on parts and pump gas compression. They'll make 800 hp with really good parts and some careful tuning. If you want more than 800 hp then you need to switch to a -1 type head or a 572-13.
Re: TF270 Heads....HP [Re: AndyF] #3172285
09/02/23 11:43 AM
09/02/23 11:43 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My feeling is that the 440-1 head, on a suitably sized short block, is the “easy button” for getting past the 800hp mark.
I also feel that the added port volume of the EZ 295 and 325 are going to have more potential as the power levels start to exceed 700hp...........with the bigger heads proving their worth as the cubes/desired rpm/power go up.
However, for around 500” and say up to say 725-ish hp, dollar for dollar it’s going to be hard to beat a TF270.
Re: TF270 Heads....HP [Re: fast68plymouth] #3172293
09/02/23 11:58 AM
09/02/23 11:58 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The Indy heads seem to wake up some with porting, and I've seen a few people change the 295/325 intake valve to 2.25 to pick up some additional flow. Would the Trick Flow 270's benefit any from porting or are they pretty much tapped out since they started as the 240 casting?
For a wedge with stock exhaust port location it doesn't sound like there are any better options than the max wedge sized EZ's, or the TF270.
Re: TF270 Heads....HP [Re: Blusmbl] #3172294
09/02/23 12:04 PM
09/02/23 12:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Ootb TF270 on pump gas 713 hp/709 torque. Street car motor.
Re: TF270 Heads....HP [Re: Blusmbl] #3172309
09/02/23 12:58 PM
09/02/23 12:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
It should probably be mentioned that in “ootb” form, the TF heads are consistently good.
The Indys often should really get some tweaking to the valve job and the way the valve job is blended into the bowls and chambers.
In one extreme example, I had some SR 295’s that picked up over 30cfm on the exhaust side by re-cutting the seats and blending.
Re: TF270 Heads....HP [Re: fast68plymouth] #3172310
09/02/23 01:01 PM
09/02/23 01:01 PM
SoCal
Brian Hafliger Offline
SoCal
Last I heard Indy cancelled the 325 heads due to casting control problems...is this still true Dwayne?
Brian Hafliger
Re: TF270 Heads....HP [Re: Brian Hafliger] #3172311
09/02/23 01:05 PM
09/02/23 01:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
I haven’t heard that, but I’ve only ever sold I think 3 sets of EZ325’s..........and one of those sets had some issues.
Todd Marsh might have that info.
I think a dyno comparo between some EZ295’s vs the TF270’s would be interesting.
But I also think a test between ootb EZ295’s vs “prepped” EZ295’s would be interesting.
Just not interesting enough to put in the effort to actually do the test.
Re: TF270 Heads....HP [Re: fast68plymouth] #3172560
09/03/23 12:18 PM
09/03/23 12:18 PM
I've built race engines with both the 270 heads and the EZ 325 heads. The EZ325 heads make more power than the TF270 heads, but the EZ325 heads can be trouble down the road with water leaks. I was told that Indy stopped selling them but I haven't confirmed that with Indy. The last engine I did with Indy parts was a bit of a hassle. It took several tries before the parts all worked properly. We've done a lot of engines with TF heads and they always work right out of the box. Only exception is fitting the rocker arm shafts. Some rocker arms require the stands on the TF heads to be machined for clearance.
If a guy is building a street car I always recommend the TF heads. Race car probably gets Indy heads. Street/strip car with 700 to 750 hp I'd go TF270. Race car shooting for 800 hp I'd go Indy -1 heads.
I don't think I've ever used a set of EZ295. They might be a good matchup against the TF270 heads. Either one should make 750 without any trouble if the rest of the parts are up to the task.
Re: TF270 Heads....HP [Re: Blusmbl] #3172566
09/03/23 12:25 PM
09/03/23 12:25 PM
I wouldn't bother spending any money trying to port a set of 270 heads. If you want to spend money to make more power spend it on the intake. There are no really nice OOTB 700 to 800 hp intake manifolds for MW ports. The Super Victor is pretty good but not great, the Indy stuff is okay but needs work to be great. I've heard the new TF intake is good but I haven't seen one yet. They made a few and then ran out.
Re: TF270 Heads....HP [Re: AndyF] #3172591
09/03/23 02:40 PM
09/03/23 02:40 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's great info, thanks Dwayne and Andy. It sounds like the hot ticket would be to send either the new TF MW intake or the Indy 440-3X to Wilson to get cleaned up.
Looking on Indy's site, they don't have pricing for the 325's listed anymore. They do list the EZ, EZ-1, and EZ-295 though, along with the SR, -1, 572, 600 and predator heads.
Re: TF270 Heads....HP [Re: Blusmbl] #3172598
09/03/23 02:58 PM
09/03/23 02:58 PM
Best Machine built a 572 last year for a customer of mine. It had EZ325 heads and it made 860 hp on the dyno. It was an EFI, dry sump, Jesel belt drive, T&D rocker arm type engine so not your average bracket racer stuff. Nice motor, probably would've made over 900 hp with 572-13 heads but the customer was constrained to stock port locations.
Engine also had an Indy aluminum block and the intake was ported by Wilson. Big buck engine, probably had close to $40,000 in it by the time they were done.
Re: TF270 Heads....HP [Re: AndyF] #3172653
09/03/23 07:55 PM
09/03/23 07:55 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's a really interesting build, I can't say I've seen any max effort 572's with standard exhaust port heads. If that was dialed back a bit with a conventional wet sump and TF270's (assume the TF's are giving up 40 cfm over prepped 325's?), what would you expect that motor to make? 750-ish with a lower HP peak because the ports really aren't big enough for a 572?
Re: TF270 Heads....HP [Re: Blusmbl] #3172680
09/03/23 09:25 PM
09/03/23 09:25 PM
Depends on how much power a person wants to make. I don't think there would be any problem making 800 hp with a 572 inch shortblock and TF270 heads if a person is willing to do some testing. My old 514 made 700 hp when I first put it together with EZ heads. After a couple of years of dyno testing it broke 900 hp. It took us a while to figure out the correct combination of parts but eventually we cracked the code.
I was able to get close to 800 hp with a pump gas 470 that had TF270 heads on it so I think it would be fairly easy to hit 800 hp with a race gas 572. Just need the right cam and a good intake manifold.
Re: TF270 Heads....HP [Re: AndyF] #3172714
09/04/23 12:40 AM
09/04/23 12:40 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
What would be a good cam for a 500 ish TF270 700+hp engine?
Same question for a 572 Indy head 800+ hp?
Re: TF270 Heads....HP [Re: Dragula] #3172754
09/04/23 09:59 AM
09/04/23 09:59 AM
USA
hudsonhornet7x Offline
USA
What do you consider a " real cam"?
Re: TF270 Heads....HP [Re: GomangoCuda] #3172756
09/04/23 10:06 AM
09/04/23 10:06 AM
So. Burlington, Vt.
So. Burlington, Vt.
Cams would be different for different applications.
I wouldn’t use the same cam for an 1800lb dragster and a 4000lb street strip wagon.
Re: TF270 Heads....HP [Re: fast68plymouth] #3172760
09/04/23 10:14 AM
09/04/23 10:14 AM
GomangoCuda Offline
GomangoCuda  Offline
Good point. Let's say your typical 3000 - 3600 lb street/strip, NSS or bracket car with appropriate converter, gear and tire, Not a tube car or a tuna boat.
Re: TF270 Heads....HP [Re: GomangoCuda] #3172768
09/04/23 10:45 AM
09/04/23 10:45 AM
TF heads are very sensitive to cam timing since they flow so well at lower lifts. It is easy to over cam them, I've done it a few times even though I should know better. For my pump gas 470 a 271 was too big but a 264/268 was just about perfect. I don't remember the cam in the 572, probably something in the 280/290 range.
I did have a customer try the 264/268 in a street car. It was a 505 with TF270 heads that made 700 hp on the dyno, but the idle was so rough that it took several hours of tuning before he could even drive the car. Fortunately it was an EFI car so we were able to tune it. Not so sure a carb and distributor could have been modified enough to work.
Re: TF270 Heads....HP [Re: GomangoCuda] #3172781
09/04/23 11:15 AM
09/04/23 11:15 AM
So. Burlington, Vt.
So. Burlington, Vt.
Basically, for a “race car”, meaning 5000+ converter and gears to match, the 700hp 500 would be in the 270’s and .700 or so lift(something that could use the TF springs).
The 800+hp big cube Indy head combo would be in the 280’s and .800-ish lift.
That will actually get you over 900 with a nice high CR bottom end and good heads.
Quote
That cam is under 270@.050 and under .700 lift.
