Re: Weird A/C Issue
[Re: Crosshairs]
#3172321
09/02/23 01:36 PM
09/02/23 01:36 PM
Posts: 6,306 nowhere
Sniper
nowhere
I thought a bad resistor only allowed the fan to blow at one speed. Correct and that speed is wait for it High And it doesn't effect the clutch, unless the AC line pressure gets too high, but that would the the pressure switch kicking in.
Re: Weird A/C Issue
[Re: Sniper]
#3172341
09/02/23 02:09 PM
09/02/23 02:09 PM
Posts: 35 Sunshine State
Crosshairs
Sunshine State
I thought a bad resistor only allowed the fan to blow at one speed. Correct and that speed is wait for it High And it doesn't effect the clutch, unless the AC line pressure gets too high, but that would the the pressure switch kicking in. Still don't understand what the blower speed has to do with the clutch! What am I missing?
Re: Weird A/C Issue
[Re: Crosshairs]
#3172468
09/02/23 10:38 PM
09/02/23 10:38 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
I thought a bad resistor only allowed the fan to blow at one speed. Correct and that speed is wait for it High And it doesn't effect the clutch, unless the AC line pressure gets too high, but that would the the pressure switch kicking in. Still don't understand what the blower speed has to do with the clutch! What am I missing? I'm thinking the line pressure
Re: Weird A/C Issue
[Re: Crosshairs]
#3174418
09/11/23 02:05 PM
09/11/23 02:05 PM
Crosshairs
Sunshine State
1989 Dodge Dakota 3.9 2WD. The A/C blows nice and cold (48) on all fan speeds except HIGH (the clutch turns off). Once I lower the fan speed, the clutch kicks back on and everything is cool again! **************It seems it was the blower resistor************************* Thanks
