Re: FORD F150 $5600 tail lamp repair ?
[Re: not_a_charger]
#3172502
09/03/23 08:08 AM
09/03/23 08:08 AM
Posts: 5,818 ohio
ruderunner
ohio
One thing I don't understand is why manufacturers don't add any drainage or ventilation to lights. It's a well known problem of water intrusion and it doesn't have to be a manufacturing defect but just minor damage.
The easiest fix is an 1/8" drill bit
It's not just lights either. Plenty of vehicles get water pudding in trunks and floors. Just recognize that keeping water out is very difficult, finding a leak even more so. The standing water is the big problem, let it out.
Angry white pureblood male
[Re: ruderunner]
#3172510
09/03/23 09:09 AM
09/03/23 09:09 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Modern day car ownership outside of the OEM warranty means owning a liability. Even when under warranty- the problem may have no fix and the customer gets strung along for a BS ride. (Think dual clutch Ford transmissions)
Keep old mopars alive.
[Re: 2boltmain]
#3172531
09/03/23 10:22 AM
09/03/23 10:22 AM
Posts: 5,818 ohio
ruderunner
ohio
A big reason I like older vehicles, all the problems are known and solved.
[Re: topside]
#3173364
09/06/23 02:33 PM
09/06/23 02:33 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
I tell so many people that come into the shop that there are 3 things you need to have with any late model vehicle.
A factory warranty that covers as much as possible Full coverage that covers as much as possible lastly deeppocket books to cover what the above does not cover.
Contact Me about AMD Prices
[Re: not_a_charger]
#3173617
09/07/23 05:07 PM
09/07/23 05:07 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Think thats bad price one for a Super Duty. Or even better a newer Benz.....
[Re: hotairballoonpilot]
#3173753
09/08/23 11:03 AM
09/08/23 11:03 AM
2boltmain
Holland MI Ottawa
Its a double edged sword. People want all the tech- all the niceties bells and whistles and the MFGRs are happy to give it to them. No one takes the time to consider what the cost of that tech will be 5 plus years down the road. Toyota as a business would die if they built their current vehicles to the quality standard they established in the 1990s. I know why the MFGRs switched to electric blend door motors- but my god it can be thousands to replace them deep in a dash. Cable and vacuum blend door operation is notwancient and maybe barbaric- but it worked fine for the second, third fourth etc owner of that vehicle as it aged.
