Unlawfls Fastest Car List by Al Alguire #1229320
05/08/12 10:29 AM
05/08/12 10:29 AM
tboomer Online work OP
tboomer  Online Work OP
Because of the confusion updating the list, the Mods have been asked to takeover this function.
Please send requests to add,edit or delete any entries to me via PM.
Send me your old ET to facilitate removing your old out dated time.
Since I haven't made a pass down the track in years I will no longer be handling Unlawfls fastest car list!
Al Alguire will be taking over this duty.
As you all know,Al is a top notch racer,
Knows his stuff and is an all around good guy!
Thanks everyone! Ted
PS Please have a little patience with me as I am a racer myself and not here 24/7. There are times I am on the road for a race or at one and it may take a few days for me to update your info but I will and let you know when I do.
Re: Unlawfls Fastest Car List by Al Alguire [Re: tboomer] #3172044
09/01/23 11:10 AM
09/01/23 11:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
---6 second Zone---
ET MPH 60' Notes of build Member
6.05 224.96 0.931 1/8=3.845 @184.46,b1headman Koffel's Place Lake Erie Monster
6.44 223.73mph 1970 Cuda 526 Twin Turbo Hemi 10.5 car. Owner/driver Mike Ziccardi. moparmadman1973
6.49 1.03 1/8= 4.45, 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
6.69 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
6.95 201 1.13 Dodge Avenger single blow thru carb turbo 412c.i. s/b, B&T Motorsports Lorton, VA
---7 second Zone ---
7.158 @ 186.98 1.010 60' SP6162, 655 predator NA 1 carb, Kim's Bantam Altered. sp6162
7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona
7.16 @ 192 1.10 526 MBR HEMI, 727 Torqueflite, 2850lb steel body 73 Challenger username: Powermaxx
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.21 @ 184.4 1.042 60' Al_Alguire, 600-13 2010 Diamond
7.26 @183.19 1.044 60' Al_Alguire, 600-13, 2000 Racetech
7.28 @ 187.71 1.04 60', 2004 RJ Stratus 2300lbs 605" Predator NA, PG in Vegas(2200'), Al Alguire
7.32 @ 158 Nostalgia FED Blown 392 hemi fm Sweden
7.33 @ 183.23, 2007 Yancer dragster 1810#'s w/driver B1 originals 572,camastomcat
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.46 @ 183.60, 1.08 60', PlumCrazyCharger, '68 Charger, 620 B1MC, 1.80 PG, 2680#
7.51 @ 182.00 1.10 60 ft 3000lbs naturally aspirated Larry Morgan Hemi,Dynamic Trans Torqueflite. 7sec.cuda
7.55 @ 185.26 Rod Shop Colt,Indy Wedge,Holt Race Cars ProBob
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.84 @ 172,(1.16 60 w\rear tires?)496 predator motor, juiced with a torq flight.dafixer
7.86 @ 173 mph '65 Belvedere Post, 604 B1 with tunnel ram/two 1050 dominators, 2-stage nitrous, built 727, Dana 60/4.10 gears; 3100 lbs race weight -- Bumbalawski http://www.youtube.com/watch?v=ygnNm_Kcuc8
7.89 168.00 1.11 60ft 632, 600X-13 single 4 at 2800 lbs 1969 Dart 440GTX
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
7.99 @ 163 w/1.084 60'. 451 TF270 11.0-1 CR, 2001 Reese 225" dragster. aarlucas
---8 second Zone ---
8.02 @ 174+, The Haze, twin turbo 452"
8.02 @ 169 SBM single stage fogger 3,050lbs and 10" tires Leon441
8.03 @ 174, 71 demon, 512 blown & n20, 2890#3 spd lenco.Demon340GSS
8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor
8.10 @ 168mph 1.10" 60ft, Cuda,2350lbs tube chassis Cuda, 572 B1, Lencodrive 3 speed, NENE
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona
8.17 @ 169.9 one nos kit, 10.5 no w's, @ 3500lbs andy mayes (rtstreet)
8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.32 & 164, Mike Swann, 68 GTX, 540/727/N20, 11 inch DOT, 3400lbs.
69 Dart 8.33 @ 173 Aluminum 528ci F2 3300lb race weight thru mufflers and ET Streets, street car Quickdart502
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.423 at 257.87 km or 160.23 mph
65 valiant, 420 cui n/a ,two speed racingtrans, dot tires, 2700#,mafo
8.45, 154.62, Old scool FED, 498 single four gas
8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.47 @159 mph 540 Barton Hemi,single 1050 dominator/with a glide 2850# 69 Cuda Barton Hemi
8.48 @158.7 mph,1.18 60' 2700 DA 67 Cuda 2800# 557 wedge Cudabin
8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.602 @ 156.73,572,2400#na 91 Daytona Pittsburghracer
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.69 @156.50 Low deck 499" 2850# Chassis car Dart JD Dart
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA Mopar_racer_99
8.733 @ 152.96 1.268 60' '68 Barracuda 542" B1 P/G 4.30's Chris's Barracuda single 4bbl. #3020 2800' DA
8.74 at 156 mph '70 hemicuda, 3900# street car on drag radials, an8sec70cuda
8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial
STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR
8.874 @148.23 1/4, 1.234 60ft.,5.598 1/8. 1970 Cuda 493 Indy -1, PG, 4:56, TNTmachine
8.901 @ 152.32, 1.243 60',Steelhead, 2700#, 70 Cuda, 493 INDY SR alcy, PG, 4.10D,14x32
8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.92 @149.5 1.23 60' 340 clutchless 5 spd,all motor,2850# 1969 Dart stevet340
8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4
8.93 @ 149 1.21 6o ft '73 Swinger 5.7 HEMI, Megasquirt, 88mm turbo, 'glide and caltracs. DaveS
8.94 @ 151.10, Bigcube '69 Dart , 3000#, all motor, Indy -1 557cid
8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.94 @ 149, 1980 Plymouth Arrow 499" BGR bullet #2300 1.21 60ft. [email]5.62@124[/email] [email]8.94@149[/email] on the launch control for .200 Eric
8.95@ 146.7, Cappy572, 76 Gremlin 440/Indy SRs, 3080#, 2 stage plate, PG-Dana 60
8.96 @ 150mph 1.29 60'3375# 10.5tire,70 DART,B1 596 N/A ROSSIO
8.97 @157, B-1 498 106mm turbo e-85 drag radials, joshking440
8.97 @ 150.9 440 70 duster 451 3300lb. NOS homebuilt hotrod,70dustmite
8.973 @ 148.37 1.313 60', 1981 Aries, 2665lbs w/drvr, ARC 548, footbraking BBLM23
8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone --
9.005@150.05 1.26 60' 1964 Belvedere N/SS 3350 lbs 572 -1 Indy crossram-dvw
9.02 @ 147, 440Jim, 1.26 60', 5.70 @ 119, 69 Dart GTS 3205#
9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.070 @146.5 1.27 60' 71 Duster flat tappet 540" 'B' 3000# 540dust
9.08 @147.39 1.25 60' 68 Charger R/T Dwayne Porter prepped 572" 440-1 heads World Block 3600# Montessa
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.08 @ 149 MR P BODY 405ci W-9 2405#
9.09 @ 149.1 73 Duster, 514" B1 original engine, 3440 lbs At Bandimere in Denver username: 506RR
9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS
9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs
9.16 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380#
9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976#
9.28@ 144mph, 73 Au. Charger, 410cu W9 stack injection, n/a, leafs, 727, 3000# charger410,
9.31 @ 144, 1.25 60�, 66 Coronet,Opel Eng. 528 NSS Hemi, L&P 727,4 Link Dana 60. REHBERGER RACING
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.38@ 146.75, hemi-itis, 63 Belvedere,545 blown Hemi,3700# 6# of boost,1.42 60'
9.39 @141* 91 Daytona 474 low deck, Indy -1 Heads, Turbo 400, 9" 4.30 #2600 1.28 60', 5.90@115 9 1/8 mile, Ken Michalikm 1974 474 Duster
9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire
9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver
9.43 @ 141.34, 70 GTX 493CI Chenoweth stroker, Indy SR heads 727 Specialist trans Dana, moparjohn
9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.46 @ 143 "J-body" in a 70 Duster 439 W8 n/a IMM Engines/Brett Miller top end
9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!!
9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!!
9.50 @ 142 mph,65 Valiant Signet,358 cu.in. R5P7,Dot tires on leaf springs Ck[FIN]
9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 60'
9.538 @ 138 2610, block 1.257 60' race weight 408" stock eddyheads Wheelsup68dart
9.57 @ 142.51, 1.388 60', 74 Chally, 572ci, Indy -13 heads,3850# W/D, N/A. Tig
9.57 @ 142mph,stock block 410 SB on the juice,1965 ap6 Valiant,3550#,full street trim Ian
9.57 @ 139 mph,1.29 60' W2 398 CI,2830#,All motor,1973 Duster,Plymouth340
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear
9.59 @ 139 mph,1.36 60' 78 Plymouth Volare/Duster,416 with Indy heads and nitrous Voluster
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075#
9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.66 @139 mph,68 Barracuda Fastback,3520# 422 SB,W9 heads,all motor on leaf springs vc360
9.66 @ 139.78, 1.34 60' 51 Ply, 451, with Flying Toilet, "La Putita" Diego-Ted
9.68 @ 138.5 1.29 60� 72 duster,511,victor heads,3170# MoparPitBull
9.70 @ 137, 1.345 60� 72 Challenger, 499, EZ-1 MCH heads, Straightline roller, footbrake, 3300lbs.ChallyL427
9.71 @ 146, 1.47 60�,69 Dart The Legend 498 3300#,street tires,ss sprgs,10sec340
9.72 @ 136.5,70 cuda 446 rons terminator 3100 lbs 1.34 60 ft, speedy 383
9.73 @ 139 mph,1.38 60',foot braking 1974 Dart Sport,540" Big Block, Dartin
9.75 @ 139.29 68 hemi dart at 3450' elevation, Chryco
9.77 @139 w 100 shot 3293# w\drvr 1/8 6.20 @112,1.32 60'"El Picoso"
9.77 @ 134, 1.30 60� 68 Barracuda 435 ironhead sb, Blonde Barracuda
9.77 @ 134,1.36 50� 73dartsport 451, 73Dartsport
9.78 @ 132.73, 6.13 @ 109.46, 1.304 60 ft. 2622 lbs. Stock Stroke 340, OEM heads, 904 68 Barracuda S/ST 3040
9.79 @ 140mph,1.28 60'1970 Dodge Dart, Koffel's Place 408sbm,MrMoparRacing
9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.79 @135.5 1.39 60' N/A 470 BB 72 Dart Swinger Street Car Thumperdart
9.80 @135, 1.47 60� 69 dart 3.23 gears. 3300 lbs, 556 pumpgas, drag radials, twin turbo mower
9.82 @ 136,1.36 60,69Dart, 500" pump gas, 3200#'s 10.5" tires. ProSport
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven.
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol
9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs
9.86 @ 135.76, 1.36 60, 6.26 @ 109 1/8, Drag radial, muffs, pump gas, Dustedu
9.88 ET 141 Mph 71 hemicuda 528ci pump gas hemi 3950# street car run on Mickey Thompson ET Street Radials. DodgeCharger
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.91 @ 136 mph 3400# indy 511 72 duster, ARI440
9.92 @ 134.86, 1.397 60', 3,530# 67 Coronet, 505" RB, Vic MWheads G-bob
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.95 @ 135 '68 Cuda, #3450, 500in, indy ez-1's JACK1440
9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.96 @ 134 mph, 1.360 60’, 72 Duster, 3160#, 408ci stock block, iron W2 heads, Caltracs, 275 Drag Radials, Mufflers Humpty
9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor.
9.98 @ 133,1.40 60� 71 Chally 496. Stret car st tires, pump gas full exh, a big shot, bodog106
9.943@ 134.62 1.398 60' 1971 Dodge Demon 499 BB with a little help from BGR Dodgeguy101
9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446
9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone ---
10.004 @ 132.71, 1.393 60 foot 3300 lb. 68 Dart,dbran451
10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
10.02 @ 132, 1.42 60', TonyS451, 71 Demon, 451 Indy SR's, street legal 3 1/2" x pipe, ultra flo mufflers, 28x10 Quicktime pros,caltracs and #3350
10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
10.073 @131.42, 440PURSUIT, 1.375 60'
10.08@ 133 BigGreenDodge, 64 Dodge 440
10.08 @ 132, 1.43 60' 64 Dodge (wildcargo)
10.08 @ 135 1.40 60' 500cid w/Indy SRs Flat Tappet thru Mufflers on DOT's TC67CUDA
10.098 @133.35, 1.418 60� 68 RoadRunner, 528 Indy Maxx, MRMOPAR
10.10 @ 130, 1.36 60' 440RB Eddys Comp 590cam pump gas 3400#, 10sec440
10.14 @ 138.02,1.62 60 ft, 82 Rampage 2.4 turbo 16v auto.30 psi boost, Rampage16v
10.14 @136 69 Sport Satellite 3900#,KP440,346 iron heads METAL STORM
10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.14 @ 129 1.29 60' 474 Low Deck Stage IV heads .613 FT cam single dominator Turbo 400 W/brakeDana 60 4.88s 3100# dry 1974 474 Duster
10.16 @ 130.3, 1.40 60�, 68 Dart 496. T748
10.16 @ 129.72,1.42 60' 69 Dart GTS 440 RB,RPM heads,.590 cam 3150# Deaks
10.18 @ 131, 1.37 60�, Demon pump gas,street tires,and muff.all steel except hood.mild 493 grncpe
10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet
10.23 @ 129mph, 1.36 60ft 68 gtx 3500# mendez motorsports 451 B,larry890
10.26 at 131mph at MATS 2014. 1972 Duster. Moparmanjames
10.27@ 130.56,1.44- 60ft, 3750 lbs, 540 cubes, N/SS, 67 Belvedere, actionange
10.27 @ 129.9b 68 fb cuda 2980 lbs, 9.0x30 tire,leaf springs. 500�, 4150 carb, indy ez-1s Footin it cudasteve68
10.31 @ 131.85, 1.36 60', Kevins440, 493RB, Indy 440-1's, stock '63 cross ram, 3300lb.
10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10.38 @ 128 mph, 1.44 60', 68 Valiant 100, 408, Indy 360-2s, pump gas, 3100 lbs, 340_Dart
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs
10.43 @ 126.41 1.42 60�,70 Superbee 451,3500 lbs,SS sprgs,Std port EZ's, super451b
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.500 @ 131.05,03 Dakota R/T Turbocharged 408, rtspeedemon
10.50 @ 128.00,1979 Chrysler 300,Bown 408 SB,727,4:56 gears Crizila
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, 400 stk bot end E heads,w squeeze, pump gas,BB70DUSTER
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.57 @ 126, 1.45 60�3650#, 66 Coronet440,9in slks.cal tracs,no pwr aders, theman440.
10.58 @ 125,1.44 60�,70 dart,493,pump gas,eddy rpm's,solid cam,493 Dart
10.59 @ 127, 1.49 60' 70 Bee 440 eddy rpm heads
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.6167 @ 133.65, 4190#.030 over 360, Sgl Turbo, 99 Dakota, Duner
10.62 @ 125mph,69 Cuda, 394"SB IMM ported Eddies,IMM flat tappet, Pump gas, 275 Radials, imin269
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725#
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.67 @ 128.3, 1.55, 72 Chally, Auto/Pump Gas Street Car, 3850, full exh, DOT's *WeDgiE*
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 125, 10secGTX 67 GTX 3670#
10.68 @ 125, 73 Str/Strip Dart stock 440/727 pump gas ET Streets Mopar65
10.68 @ 123 mph. 76' Volare 406" iron head magnum motor, 904 trans, 3300 lbs on 9" Radials. Hyd roller camshaft -- StandOnIt
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.71 @ 126.12, gj69charger, '69 charger, 500cid
10.75 @ 125.35, 1.54 60', 67Charger, 496/727 (full man.), 4.10's, full exhaust, 3925# w drvr
10.76 @124.99 493" BB 1963 Sport Fury Street Car 383man
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.764 @ 123.26,1.42 60' 408/904/4.30 77 Aspen R/T 3420# 77DragracerR/T.
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.77 @ 122.8 mph 1.47 60' 440 flat tops,915 heads,.590 cam with 4:30 gears 74 Dart 3300# 340man4ever
10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 !
10.83 @ 125, 1.6 60ft. 1970 Duster 440/500 stroker, all steel, all motor, pump gas, street driven. Mike Forsythe (70Drop)
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080#
10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4sp Stock Appearing, F.A.S.T. legal on G70-14 bias plys
10.926 @ 122mphb 1.54 60� 90Dakota 360w 175 shot/727 mphsmitch
10.928 @ 120.19, 1.52 60�, 76 pacer, 512 B, 727 dana 60. plumridiculous
10.94 @ 122 ramrod W2 360 71 Duster 3000#
10.96 @ 122 69RR, 500� stroker, auto 4:10, Street tires, full exh, 93 oct, Irons Works r suspension. RoadRnnr69
10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
10.98 120.51, 1.502 60�/1/8 6.932 97.82, Jenni 66 coronet-3600lb 446ci auto-cal-tracs,VernMotor
10.99 @ 124.38 mph, 1.55 60', 3926# street cruiser, 4 speed car 68LAR
---11 second Zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.01 @ 122 blown 340 76 Road Runner street trim/slicks 3890# dvw
11.02 @ 123.00 1.58 60' Zippy 69' GTX Street Car 451 CI
11.05 A 122.17, 78 aspen 440 cnc'd eddy soild cam 3665#s full trim, pump gas driven to track,1fastaspen
11.50 @114mph 1.552 60',90 dakota 360 magnum stock bottom R/T heads,125 shot
11.07 @ 120.24, 1.56 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock CrossRam, solid cam and pump gas
11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas..
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
11.18 @ 118, 76 spen 434sb N/A pump gas "J" heads 1050 Dom Street car out of gear at 900�, StrokerAspen
11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs.
11.23 @ 120,1.64 60� '69 Charger R/T SE, 3900#s,493/727/8 3/4 w/3:23 750DP w/PF main body, TTI 1 7/8 headers, 3" full exhaust, flat tappet Comp stick, Caltracs, Lifsgrt
11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.24@ 119.78 mph, 70Swinger, 416,w2's,3350 lbs, pump gas street car,340 Dart
11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs
11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
11.31 @ 116 pump gas 383 '70 Cuda Dbl�00�Joe
11.349 @ 117 1.567 60 ft. - 360 Duster - no bottle - Moparforlife
11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger
1975 Dodge Dart Hang 10 edition, 3100 # w/o Driver. 408 CI, 360-1 Indy Heads (285 cfm) 275/60 MT Et street radial. 1.62 60 foot, 7.30 1/8th, 11.38@119.67 mph 1/4 mile. Footbrake, 390 gears, car chassis dynod 401/395 rwhp/rwtq on 94 octane Pump Gas. 11.3:1 comp NA motor. 75 DartHang10
11.37 @ 118 Blusmbl - 1968 Plymouth Fury, 4345#, mild 440 with plate kit, RMVB 727 on the column
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.41 @ 118 mph,1.43 60' 1970 Challenger S/E drag car 4 speed,446" 3500#,working power windows! Sixgun
11.43 @ 120mph 1972 340 Duster F.A.S.T. legal 444ci, 904, polyglas tires- CJK440
11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.45 @ 117, 1.56 60',70 Dart Swinger, 408",x-heads,727,4.10's,full-bodied,pump-gas,street car, jinxy
11.45 @ 117, 1.62 383man's sons 406 Dart pumpgas street car.
11.47 @ 119.62 mph, 68 GTX 508 6 pack full street trim 727 3.91 mrmopardan
11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim
11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10
11.54 @ 116mph 1.70 60', 1971 Challenger Conv. 3810lbs, 511ci, 727, 3.55 Defbob
11.59 @ 115 Mph. 1970 Duster built up 360/ 904 auto 4.30 gears, 3300 lbs race weight Dennis aka "360904"
11.60 @ 116 mph 1964 Savoy 426 Wedge Todd
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears.
11.71 @ 113 with a 1.63 60' 8.5 slicks , mild 408, 64 Dart The Shocker
11.72 @ 114.2 1956 Plymouth 493 cid 1.63 60 ft at 3760 lbs -- Dynamite
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID
11.73 @114, 94 Dak,3380 w/o drvr, 446 cu.in 4k stall,4.10 SG CalTracs , ET Streets, KatFysh
11.74 @ 111.81 mph, 1.60 60�, 70Swinger, 360 home port J heads,2850lbs, pump gas, DragDart360
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.77 @ 116.29 1.83 60', Bone stock \ 6 with turbo, 70 Swinger, 2.76 gear, Shaker223
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.79@ 117 mph. 66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs, on regular Firestone Firehawk radials (Bad Moon Racer)
11.83 @ 114, 1.70, Sportfury440, '66 Fury, 446/727, Edelbrocks, 9.5" PTC, 4:10's, 3850lbs, 275/60 DR's
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.82 @115mph 1.70 60' 71 Duster 366" X Block, Indy RHS Steel Heads. Stock interior car. 727 & 4.10 gears. Built By MRL Performance. Matt Butler
11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
11.92 @111 mph,67 Satellite street car,451 CID pump gas,Driven to and from the track! GEnsrud
---12 second Zone ---
12.000 @ 117mph - 1968 Coronet R/T, Billy B Bad
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 110, 1.58 60', cudadan
12.05 @ 115. 1.89 60', Slant 6 with turbo, 70 Swinger, 2.76 gear, 59 Shaker223
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is StreetLegal
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.39@ 110 mph, 1.84 60', 318/392 cui stroker - 71 Aussie Valiant Charger - Moparmal
12.41 @110, Superb70, 1970 Super Bee 440,727,4.10's
12.52 @ 110 73 Challenger 360-4 speed 3775# street trim/slicks dvw
12.54 @ 107 1.81 60� 70 Polara 4dr 496/727 2800 stall/3.55 4600lbs on 275/60/15 Nitto DR gch
12.64 @ 108.6 1.85 60', 318/390 stkr 71 Aussie Valiant Charger Moparmal
12.70 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim
12.71 @ 109 mph,1.91 60' 1969 Dodge Superbee,mild 440,727 with 3.91 gears MikeyT
12.79 @ 115, 1.93 60� 1968 Plymouth Fury III 4-Door, Blairboy3
12.89 @101 75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car)
12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
---13 Second Zone---
13.03 @102mph,1.80 60',1969 Coronet,318/904,4:10 gears,3300# HP318
---14 Second Zone---
14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
*****Moparts 1/8 milers*****
4.41@ 160 mph 1.00 60' 2008 Pro Stock Stratus Hemi auto all motor Paul M.
4.52 ET 2011 Jerry Bickel Dodge Avenger 762" Hemi, rickseeman
4.74 ET,@149.9 mph, 1.12 -60' Bill Stevens, 01 Plymouth PU, Blown-inj 526 BAE/Veney HEMI, Bruno/Lenco 2spd
4.88 @ 144 MPH(2250#w drvr)225"Hard Tail Dragster 557" Indy motor, Bob Coomer
5.262 @ 134.59 1.260 60' 1971 Demon 3280# 28x10.5 tires a493Demon
6.15 @108.90,1.272 60' (9.73 @ 105) 416 3000# A body Eddie RPM's by RyanJ,Victor 340 and 750 Holley, Racer Brown Solid. Lil Wedge
