wiring/terminals Q
#3172022
09/01/23 10:10 AM
09/01/23 10:10 AM
RapidRobert
Wiring up the stock car. other than the battery to the main cutoff then to the starter which are large welding cables, for general wiring (alt/reg/ignition) is it acceptable to crimp on the terminals or should I crimp & solder them? these are 10 gauge (alt to battery) & the rest are smaller (alt field/reg/ignition) & the crimp on terminals are cheap overseas ones which is all I could find at the time. thank you for your time. RR
Re: wiring/terminals Q
[Re: RapidRobert]
#3172037
09/01/23 10:54 AM
09/01/23 10:54 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Crimps work fine as long as they are properly done. Its a personal preference
[Re: topside]
#3172045
09/01/23 11:11 AM
09/01/23 11:11 AM
RapidRobert
yes that is what I did, removed the plastic covers. I did start to solder em but my small soldering iron is not hot enough & I would have to go get one
[Re: topside]
#3172053
09/01/23 12:11 PM
09/01/23 12:11 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
I should have mentioned that I buy non-insulated terminals; easier on the hands than cutting those plastic covers off I Crimp/Solder and heat shrink with adhesive lined tube...every size. I use non insulated connectors from Del-City but there are other suppliers.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: moparx]
#3172148
09/01/23 06:26 PM
09/01/23 06:26 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Yes, save yourself headaches and get one of the "ratcheting" crimpers. I got a pair off Amazon for about $30.
[Re: W.I.N. Racing]
#3172195
09/01/23 09:42 PM
09/01/23 09:42 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I should have mentioned that I buy non-insulated terminals; easier on the hands than cutting those plastic covers off I Crimp/Solder and heat shrink with adhesive lined tube...every size. I use non insulated connectors from Del-City but there are other suppliers. Another vote for Del-City non insulated connectors and good quality shrink sleeve. I crimp, solder, and shrink all terminals. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: RapidRobert]
#3172202
09/01/23 09:57 PM
09/01/23 09:57 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3172203
09/01/23 10:19 PM
09/01/23 10:19 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Uninsulated terminals, crimped, heat shrunk. I haven't soldered any of it in years.
2 ga battery cable, tops. Once the engine starts, anything bigger is just dead weight,
[Re: SomeCarGuy]
#3172244
09/02/23 09:09 AM
09/02/23 09:09 AM
RapidRobert
Good comprehensive info! I will make some changes. thanks guys. RR
[Re: R3 Racing]
#3172298
09/02/23 12:11 PM
09/02/23 12:11 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Do not solder. Not a good idea. Ton of info on the net for reference. Tinning the wire is fine, but not a full solder joint.
A quality lug properly crimped will be the best solution. Non-insulated lugs are best.
[Re: Cab_Burge]
#3172322
09/02/23 01:36 PM
09/02/23 01:36 PM
markz528
Morrow, OH
A quality lug properly crimped will be the best solution. Non-insulated lugs are best. What is your reasoning about not soldering? Corrosion affects many electrical circuit throughout our country that have humidity levels above 35% most of the time Soldering eliminates that Corrosion is an issue with soldering. Very difficult to remove all the flux from a solder joint. The left over flux will cause corrosion over time. Proper crimp with a proper heat shrink (sealant filled heat shrink is best) addresses the corrosion issues. Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment. Bad connections have caused my company millions of dollars in failures over the past decade. We put a team together that addressed the connection problems . The conclusion is a proper sized good quality lug properly crimped is the solution.
[Re: Wirenut]
#3172544
09/03/23 11:25 AM
09/03/23 11:25 AM
Al_Alguire
Las Vegas
FWIW I order most my wiring supplies Del City as well. I also use Duetsch connectors for all my stuff.
