Re: drilling the yoke for u bolts
[Re: stinger]
#3171825
08/31/23 09:28 AM
08/31/23 09:28 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I would not. If you really want U bolts, get the appropriate yoke. Having said that, if you're still using 7260 U joints, you probably don't need to change anything. I ran in the low 11s and high 10s at 3700 lbs w/ the stock style straps and never had an issue, but that was w/ 7290 U joints. I'm not sure how fast your car is or what combination you're running though.
[Re: stinger]
#3171885
08/31/23 02:35 PM
08/31/23 02:35 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
[Re: stinger]
#3172199
09/01/23 09:53 PM
09/01/23 09:53 PM
Cab_Burge
[Re: Cab_Burge]
#3172351
09/02/23 02:20 PM
09/02/23 02:20 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I know I,perials used the U bolts on the ones I had.I saved at least one to change the strap one on y 65.Cant remember what rear they used IIRC mine were 489s
Chrysler Firepower
[Re: therocks]
#3172426
09/02/23 06:53 PM
09/02/23 06:53 PM
Posts: 91 sweden
carter
sweden
I know I,perials used the U bolts on the ones I had.I saved at least one to change the strap one on y 65.Cant remember what rear they used IIRC mine were 489s Yes! Imperials use U-bolts. I have a -742 house from a -67 Imperial.
[Re: carter]
#3172505
09/03/23 08:55 AM
09/03/23 08:55 AM
Posts: 2,006 Apollo, PA.
B1MAXX
Apollo, PA.
I know I,perials used the U bolts on the ones I had.I saved at least one to change the strap one on y 65.Cant remember what rear they used IIRC mine were 489s Yes! Imperials use U-bolts. I have a -742 house from a -67 Imperial. As I recall those Imperials one's aren't 7260 or 7290 though I want to say Spicer 1330.
[Re: B1MAXX]
#3172599
09/03/23 02:59 PM
09/03/23 02:59 PM
Cab_Burge
I know I,perials used the U bolts on the ones I had.I saved at least one to change the strap one on y 65.Cant remember what rear they used IIRC mine were 489s Yes! Imperials use U-bolts. I have a -742 house from a -67 Imperial. As I recall those Imperials one's aren't 7260 or 7290 though I want to say Spicer 1330. , I think that is the correct I.D. Some of the street hemi 4 speed cars with Dana 60 had that yoke also
