Page 2 of 3 1 2 3
Re: Location for Accusump [Re: topside] #3171605
08/30/23 11:55 AM
08/30/23 11:55 AM
Illinois
gearhead01 Offline OP
Illinois
The Canton valve kit was $229 through my local speed shop.
Included the valve, switch, wire, terminals, nipple (1/2" NPT) and a plug for the pressure switch (if you are not using it).
Like said, there are a lot of parts that can be sourced from commercial vendors.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Location for Accusump [Re: Streetwize] #3171644
08/30/23 01:30 PM
08/30/23 01:30 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by Streetwize
Im not sure the distance really matters as an accumulator is a charged headspace in the running oil circuit so it should be constantly "on duty" and it should dampen even minute fluctuations in oil pressure.
Never heard that comment before.
Do they even exist in a positive displacement pressurized system any way, do they matter if so, other that interruption in supply, which is the main task of the accumulator?
With EFI, your point would IMO have a lot of merit, where a smooth supply is a plus.
Re: Location for Accusump [Re: moparacer] #3171645
08/30/23 01:33 PM
08/30/23 01:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by moparacer
One thing to consider. You should mount it somewhere that is fairly easy to access so it can be removed and cleaned during oil changes. I pull my Moroso off and clean it every change.
Other than peace of mind, does it collect enough of what you don't want to make the task worthwhile?
Re: Location for Accusump [Re: jcc] #3171647
08/30/23 01:37 PM
08/30/23 01:37 PM
You have to feed it after the oil has gone through the pump and filter, correct work
I'm sure it can't hurt to take it apart now and then and look at what has collected inside of it and clean it up, I wouldn't do it after every oil change unless it had a part fail like spinning a rod bearing or some other metal making failure that would contaminate the oil work shruggy
It's your choice shruggy
Re: Location for Accusump [Re: Cab_Burge] #3171671
08/30/23 02:41 PM
08/30/23 02:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Which won’t make much difference in a race engine for the 8-11 second run, if something breaks an oil filter is useless, the engine is toast.
Re: Location for Accusump [Re: cudaman1969] #3171758
08/30/23 08:24 PM
08/30/23 08:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I'd be more concerned about what's in the pan than what managed to find its way into the accumulator!
Re: Location for Accusump [Re: Stanton] #3171766
08/30/23 08:43 PM
08/30/23 08:43 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe he drops his pan every oil change? stirthepot grin
Re: Location for Accusump [Re: Stanton] #3171771
08/30/23 08:50 PM
08/30/23 08:50 PM
Illinois
Illinois
For an engine failure, both Canton and Moroso say the Accusump or Accumulator need to be cleaned, flushed, or sent back for cleaning or rebuild.
John
Re: Location for Accusump [Re: cudaman1969] #3171778
08/30/23 09:42 PM
08/30/23 09:42 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is mounted on the core support in front of my rad and trans cooler. Behind the front bumper. I use it for a pre-luber and as an Accusump as intended.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Location for Accusump [Re: AndyF] #3171809
08/31/23 06:35 AM
08/31/23 06:35 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Originally Posted by AndyF
Inside the car is illegal in NHRA but legal in NASCAR and SCCA. NASCAR runs the dry sump tank behind the driver's seat but NHRA doesn't allow liquids in the driver compartment. We hung the accusump on the rollcage inside the cabin on Tim's road race Valiant and that was fine with the road race tech guys but NHRA wouldn't allow it.
I will say that you don't want an aluminum tube full of hot oil inside the car on a street car. It is just like having a big heater sitting in the cabin with you. After 30 minutes or so the tank will be 180 degrees and the car will smell like hot oil!
I haven’t looked at an nhra rulebook in a long time on this. It seems that I see a whole bunch of cars with intercooler tanks or n2o bottles on the passenger floor. I don’t remember ever seeing a requirement for isolator lines on oil gauges. (fuel gauges- yes)
The last time I had the car recertification was way back when… maybe 2006 or so. The inspector said he didn’t like it. He also said there wasn’t a rule against it, and suggested I move it.
As for heating being an issue, I never felt anything more than a warm sensation that you would be able to rest your hand on for as long as you wanted after beating up on the car a bunch. It isn’t a flow through system. Unless you have some really screwed up oiling problems, the accumulator doesn’t have a continuous heat source.
I used mine for engine safety on extreme decel with my rear sump pan, so a full oil dump was rarely done. That car had a lot af street miles and never once had any issues with in cabin leaks or temperatures.
The only picture I have just barely shoes the ball valve handle for an idea of its location/ proximity to me.
Re: Location for Accusump [Re: 6PKRTSE] #3171810
08/31/23 07:19 AM
08/31/23 07:19 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mines mounted under the radiator, first few wheelies I was accused of running N2O grin Used for priming and as an accumulator. It doesn't get hot, if everything is working correct there is minimal oil flow during normal running. I use a manual cable operated lever, I always try to remember to build some oil pressure and close the valve each time the engine is shut off so I can prime it on the next start. According to Canton, it hold's about 2 quarts with 10 psi air pressure, though there's likely a quart in the lines just to get to the engine as we also use a remote oil filter.
Re: Location for Accusump [Re: Tig] #3171814
08/31/23 08:53 AM
08/31/23 08:53 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Do they need to be horizontal ??
Re: Location for Accusump [Re: Stanton] #3171816
08/31/23 09:00 AM
08/31/23 09:00 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That IMO is a good question. I think the concern would be if there is any trapped air in the system, one would not likely want it to be the first displacement back into the system when oil pressure was dropping, being on its side or the plumbing exit being on the bottom would seem to prevent/mitigate that.
Re: Location for Accusump [Re: Stanton] #3171826
08/31/23 09:31 AM
08/31/23 09:31 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
According to the Canton installation instructions it can be mounted in any position. But, if the O/P can be mounted slightly higher then it is better due to the reasons mentioned up
Re: Location for Accusump [Re: jcc] #3171833
08/31/23 10:09 AM
08/31/23 10:09 AM
PA
moparacer Online content
moparacer  Online Content
PA
Yes. And I don't know about the others but all you need to clean the Moroso is a big set of snap ring pliers. Been cleaning my Moroso 3 quart for Oh, about 23 years lol.
I wouldn't run one if it had to be sent away to be cleaned.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Location for Accusump [Re: TRENDZ] #3171924
08/31/23 06:15 PM
08/31/23 06:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A cage inspector can only inspect a cage for thickness, placement and tigged if CM, has no authority to determine anything else.
Re: Location for Accusump [Re: cudaman1969] #3171960
08/31/23 09:27 PM
08/31/23 09:27 PM
I don't think anyone needs to worry about the NHRA tech certifying a car race cage away from the track, the local track tech are my worries work shruggy
Re: Location for Accusump [Re: cudaman1969] #3172004
09/01/23 08:01 AM
09/01/23 08:01 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The NHRA cage inspector is an NHRA tech inspector… I wasn’t saying my cage would have failed cage inspection because of the accumulator. I guess I see how you thought that was my point. Bottom line… he was a tech inspector and what he said(at that time) was it was not against the rules. As Andy mentioned that may have changed in the years since, but that doesn’t explain how people have the previous mentioned liquids in the driver compartment
Re: Location for Accusump [Re: TRENDZ] #3172016
09/01/23 09:28 AM
09/01/23 09:28 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Agree, I wouldn’t want fluids in driver area either. Murphy’s law
Re: Location for Accusump [Re: cudaman1969] #3172024
09/01/23 10:22 AM
09/01/23 10:22 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Fair enough, but at the same time IMO many are oddly fine with an open face helmet, no Hans, no full containment seat, no fire suppression system, etc
NHRA IMO does not allow fluids inside the passenger compartment because it does not trust competitors to do it safely, correctly, and/or for it to be supervised properly.
SCCA , Nascar, etc evidently does not have that same concern for cars with significantly much longer on track time of use wheel to wheel.
To each their own.
Page 2 of 3 1 2 3
