ANOTHER TORSION BAR QUESTION #317124
05/13/09 02:58 PM
05/13/09 02:58 PM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
need some info please.putting the rt side bar in my 70 rr but the hexes for the bar are just ever so slightly off.can put in control arm but not in frame or visa versa.even took out the upper bumpstop,lower control arm is loose at the pivot and loosened up the strut bar.still wont line up.thanks for any help.
Re: ANOTHER TORSION BAR QUESTION [Re: FM370RR] #317125
05/13/09 04:08 PM
05/13/09 04:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
make sure you tap the little lever down all the way that the adjusting bolt loads the bar with. Often they stick up a bit!! That turns the hexes down more of course
