New best, more to be had #3170872
08/27/23 05:04 PM
08/27/23 05:04 PM
gregsdart Offline OP
I couldn't get the one/two shift to shift on time, and hit the rev limiter in 1st gear for .4 seconds on every pass. Still, I am happy I got it down the track with a new best 60 ft of 1.224. But the best part was my best 1/8th mile speed of 128.87 mph yesterday. Today's ET was best at 8.60
The DA was 2166, with an 8 mph head wind
Re: New best, more to be had [Re: gregsdart] #3170878
08/27/23 05:34 PM
08/27/23 05:34 PM
tboomer Offline
tboomer  Offline
Way to go Greg! You deserve that after all of the hard work you did on your car! up
Re: New best, more to be had [Re: tboomer] #3170887
08/27/23 05:56 PM
08/27/23 05:56 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Nice job, Greg! More in it. That 128 to the 1/8 is nice too!
"Any fool can know. The point is to understand"
- A. Einstein
Re: New best, more to be had [Re: EvilB1Dart] #3170902
08/27/23 07:37 PM
08/27/23 07:37 PM
Sticky South
Rodenteliminator Offline
Sticky South
Now that is getting done! Good job! Doug
Sorry honey I spent the rent
Re: New best, more to be had [Re: Rodenteliminator] #3170922
08/27/23 09:55 PM
08/27/23 09:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations Greg! beer
Re: New best, more to be had [Re: slantzilla] #3170926
08/27/23 10:08 PM
08/27/23 10:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Great job Greg.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New best, more to be had [Re: gregsdart] #3170943
08/27/23 11:29 PM
08/27/23 11:29 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
Great job!! What's your trap rpm's?
Re: New best, more to be had [Re: hugo] #3170960
08/28/23 05:51 AM
08/28/23 05:51 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nice numbers Greg! Glad it's coming around for you.
69 GTX 68 Road Runner
Re: New best, more to be had [Re: gregsdart] #3170966
08/28/23 08:02 AM
08/28/23 08:02 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Now that’s what I’m talkin about. That thing is nasty.
Re: New best, more to be had [Re: gregsdart] #3170973
08/28/23 08:37 AM
08/28/23 08:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats Greg! It's spinning the tires with that MPH/ET. Between DA and a little more efficiency there's plenty left in it to get you kicked off the track! up
Re: New best, more to be had [Re: hugo] #3170984
08/28/23 08:57 AM
08/28/23 08:57 AM
Trap rpm is 7600.
Re: New best, more to be had [Re: gregsdart] #3170987
08/28/23 09:03 AM
08/28/23 09:03 AM
an8sec70cuda Offline
Very nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New best, more to be had [Re: gregsdart] #3170992
08/28/23 09:07 AM
08/28/23 09:07 AM
Thanks guys for the compliments. I still have to figure out why the 1/2 shift doesn't happen til 7800 rpm. As I said earlier, it was against the rev limiter at 8,000 rpm on the 1/2 shift. It may be I have the window too narrow for shifts. I have the circuits setup to only function while a throttle stop setting provides a path to ground for the air shifter. I will check and see if the window/ stop setting is coming in too late . I needed to set it up this way to keep the trans from shifting to safe neutral, since my shift pattern is now PR123N. I may still go to a separate rpm switch if there is one that allows different settings for each shift. For the life of me I couldn't get the MSD7531 to work like the book says it should.
Re: New best, more to be had [Re: gregsdart] #3170997
08/28/23 09:25 AM
08/28/23 09:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Both my Digital Delay shift timer and my old ACD you could set different shift rpms.
Nice passes! We’ve only been waiting 20 years for you to do that! Going to get out in some more favorable fall air soon?
Re: New best, more to be had [Re: gregsdart] #3171011
08/28/23 10:10 AM
08/28/23 10:10 AM
PA
moparacer Offline
moparacer  Offline
PA
Oh ya get that shift issue fixed and its going to run 5.30 easy at 128 mph. beer
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: New best, more to be had [Re: J_BODY] #3171023
08/28/23 10:50 AM
08/28/23 10:50 AM
Twenty years? Am I really that old?😁
Re: New best, more to be had [Re: moparacer] #3171026
08/28/23 10:59 AM
08/28/23 10:59 AM
That would be great to see 5.30s in the 1/8rh. Best so far is 5.47. The 60 fts are a bit slow I suspect as I run a throttle controller, not a stop
For launch rpm. I leave at about 1/8th throttle at 4,000 rpm, and it takes about .2 seconds for full throttle. I figured with only a 10.5x33 tire I would hit it soft to start. Still, the 1.224 is the fastest it has ever gone in the 60 ft.
The 30 inch ladderbar are at 120 percent of rise by my calculations. Rear shocks are Afco big guns, set at 12 from full stiff on separation, 6 from full stiff on compression. The feeling I had before was tire spin when I tried to run the ladderbar in the bottom hole . The car would pitch rotate too fast and hit the wheeliebar unloading the rear tires. I don't feel that now.
Re: New best, more to be had [Re: gregsdart] #3171039
08/28/23 11:34 AM
08/28/23 11:34 AM
PA
moparacer Offline
moparacer  Offline
PA
I have went 5.47 @ only 125 mph with a 1.18 60 ft. So with a better DA, and suspension tweaks to better the 60 ft I bet it clips the high 30s at least.
The big issue you have is the low starting line ratio with the 3 speed and ladder bars killing the tire if you try to leave harder.
Re: New best, more to be had [Re: moparacer] #3171272
08/29/23 09:41 AM
08/29/23 09:41 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Congrats Greg!
