NGK Plugs.....
#3170635
08/26/23 04:08 PM
08/26/23 04:08 PM
Posts: 12,416 Taxes & Virus's R-US, NY
Dragula
I stopped using these in the early 90's because they are crap and would just quit when conditions were not perfect. So I have not bought any since....The other day my ATV needed a plug, and Napa sells me an NGK plug even after I protested....They say they are good now.
Well I went to install the effing POS plug and what happens, it breaks in half right at the threads....The threaded part in down in the bore, and then entire rest of the plugs comes out....electrode and all...Anyone ever worked on an ATV...there is no room in there to work. This sucks, and it wasn't even tight yet..
NGK still sucks!!!!!!!!!!!
PS....Why do you think I was changing the plug in the first place...gas went bad over winter, even with stabilizer, and it had an NGK plug that stopped firing...Other ATVs with same fuel, no issue...
Re: NGK Plugs.....
[Re: Dragula]
#3170640
08/26/23 04:55 PM
08/26/23 04:55 PM
Posts: 2,526 PA
moparacer
PA
Well if they suck I must have been lucky the last 15 years or so I have ran them. Every one has always been gapped the same out of the box too. I could have slapped every set in and never checked them. More than I can say for the other brands.
The set I took out of my car last month was 3 years old. The set in my Barracuda are maybe 10?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: NGK Plugs.....
[Re: GY3]
#3170643
08/26/23 05:04 PM
08/26/23 05:04 PM
Posts: 1,558 Michigan
Kiddart
i use them as well no issues ever.
Thank you Kiddart
Re: NGK Plugs.....
[Re: GY3]
#3170650
08/26/23 05:17 PM
08/26/23 05:17 PM
Posts: 2,526 PA
moparacer
PA
I use nothing but NGK and have had great results. They are easy to read with a nitrous tune, too! Yep easy to read the timing mark on the ground strap.
Re: NGK Plugs.....
[Re: Dragula]
#3170657
08/26/23 05:50 PM
08/26/23 05:50 PM
Posts: 2,526 PA
moparacer
PA
Did you put it in with a 1/2 breaker bar or 3/4 impact? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) That is literally the first NGK plug I have ever seen do that. It might be a issue with that particular plug number but If you do that with a NGK automotive plug I think you dont know your own strength.
Re: NGK Plugs.....
[Re: Dragula]
#3170659
08/26/23 05:53 PM
08/26/23 05:53 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m sorry but I would be afraid walking next to you in a rain storm.
Re: NGK Plugs.....
[Re: Dragula]
#3170685
08/26/23 08:05 PM
08/26/23 08:05 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m sorry but I would be afraid walking next to you in a rain storm. Long as you are shorter, all is good... I’m shorter but I’ll bet I’m wider. Lol 😂
Re: NGK Plugs.....
[Re: moparacer]
#3170695
08/26/23 09:24 PM
08/26/23 09:24 PM
Dragula
Did you put it in with a 1/2 breaker bar or 3/4 impact? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) That is literally the first NGK plug I have ever seen do that. It might be a issue with that particular plug number but If you do that with a NGK automotive plug I think you dont know your own strength. As I said, getting into an ATV to change a plug is not somthing you can use any real tools on...And it was just a short handled wrench...And it was not even tight yet...Then I had to figure out hot to get that portion out of the cylinder.
Re: NGK Plugs.....
[Re: dvw]
#3170705
08/26/23 10:06 PM
08/26/23 10:06 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
All I use as well. I've been running the same set for 8 yrs. Every season I say I'm going to change them, just haven't. Fires right up and sets into a nice even idle. Last week was 7.043, 7.045 and 7.044. Just need the driver to get as consistent.
Ok
Re: NGK Plugs.....
[Re: cudatom]
#3170732
08/27/23 12:20 AM
08/27/23 12:20 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Ngk is all I’ve run since auto lite decided to close up shop here and set up in places I don’t trust. Run them in everything. The ford guys say to put them in eco boost motors. Apparently they make them for ford, to some crap spec, so you have to go with the ngk branded ones to get things right.
I want my fair share
Re: NGK Plugs.....
[Re: Dragula]
#3170749
08/27/23 07:32 AM
08/27/23 07:32 AM
Posts: 2,934 A shed in England
Tig
A shed in England
I've never seen any make of plug snap there before. I recently swapped from NGK to Champion because the price of the NGK's has got so high. Out of the box the earth strap on the champions is twisted and not centered over the electrode, 6 of the 8 were like this. Not particularly impressed. ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: NGK Plugs.....
[Re: carter]
#3170772
08/27/23 10:45 AM
08/27/23 10:45 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
48 years of running Autolite racing plugs for me.
