Bill Mitchell 4.50 bore block Hemi
#3170634
08/26/23 04:00 PM
08/26/23 04:00 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
What kinds of mods have to be done on the block to accommocate the Hemi crank both 604 or 572. Bottom of bore mods for each and modifications in the oil pick up area. Any other mods need to bee done to the block. Pictures would be great if available.
1971 HEMI E BODY REGISTRY
Re: Bill Mitchell 4.50 bore block Hemi
[Re: quickd100]
#3170652
08/26/23 05:27 PM
08/26/23 05:27 PM
hemicar1971
Chicago Blackhawks
With the 4.75 the 2.2 rod does create more room and the crank like you said does take away from putting an internatl pick up in the motor. With the 4.50 crank and the old world block that I believe is the Mitchell block or looks much like it will worked with an internal pick up with some extra work. I like the external with a swing pick up in the pan with a much bigger and better pump and the line running to the front of the block. Just can not remember how much of the block needs to be ground down to except the 4.75. Frend built his and can not find his pictures of the work so I can show this to another friend. The friend has not decided on 4.50 or 4.75. He will be running the Eddy Hemi Heads and is leaning toward an Ohio Crank Rods and Pistons order for the motor. All read any most with good information on this kind of build, so keep them coming.
[Re: 440Jim]
#3170818
08/27/23 01:43 PM
08/27/23 01:43 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3170981
08/28/23 08:48 AM
08/28/23 08:48 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
When I ordered my KB block in 2005, they asked me what stroke and rod combo I was going w/ and had the bottom of the bores notched to clear. I told them aluminum rods, even though I was running steel, to get the clearancing done in case I changed later. Oddly enough, when I was fitting everything, the front counterweight on the crank hit the block and needed a small notch. All the rods cleared just fine.
[Re: an8sec70cuda]
#3171018
08/28/23 10:37 AM
08/28/23 10:37 AM
Posts: 16,928 NC
440Jim
NC
Oddly enough, when I was fitting everything, the front counterweight on the crank hit the block and needed a small notch. All the rods cleared just fine. Along that topic... I am using a Callies 4.500" crank in my BMP block as I said above. My early mockup showed the crank counterweights cleared. But for balancing (B1 pistons, not hemi), I had the counter weights reduced in dia. Then it only needed a small dimple to balance, not a bunch of big drilled holes in the counterweight. 572 CID B1 engine build - Part 3The counterweights were 3.79” radius (7.58” dia). The front and rear are 1.23” wide, inners are 0.78” wide.
