E-Body Steering Column #3170371
08/25/23 01:21 PM
08/25/23 01:21 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I am having an issue with a 73 Challenger we just finished up. The couple that owns it are
of very different sizes. He is well over 6 ft tall and on the larger size and she is about 5'6".
She fits comfortably right now with the drivers seat about in the middle. He can not fit behind
the steering wheel.
I have ordered the Year One seat relocation brackets to try, and am planning on going with a
smaller steering wheel (maybe a tuff wheel?). Was also thinking maybe a tilt wheel column may
help?
Has anyone removed the crush can in between?
My question is, has anyone came up with a telescoping steering column that may work with out
a lot of modifications. Just trying to think outside the box...
Any ideas would be appreciated!!
Thanks,
Re: E-Body Steering Column [Re: jim6346] #3170403
08/25/23 03:06 PM
08/25/23 03:06 PM
moparx Offline
moparx  Offline
after climbing around my stash of "stuff", and getting "so close, but so far away.......", a 78 imperial tilt/telescope column "very roughly" measures "about" 36-38" from the edge of the wheel to the floor mounting plate, with the wheel being in the collapsed [shortest] position.
it also has approximately one foot of the shaft protruding from the base, where it then would connect to the box.
if that may even be remotely close to anything that might work for you, i can do more "gymnastics" to get the column down from the rack, and get precise measurements and a couple of pictures.
[that ought to be a hoot, watching an old man climb around and get "stuck" in a place he won't be found for days to come. laugh2]
beer
Re: E-Body Steering Column [Re: jim6346] #3170406
08/25/23 03:17 PM
08/25/23 03:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Before Eric hurts himself......
Can she keep the car & trade him in on a smaller version?
Re: E-Body Steering Column [Re: Alaskan_TA] #3170420
08/25/23 03:52 PM
08/25/23 03:52 PM
moparx Offline
moparx  Offline
hurt myself ????????? whistling panic laugh2
you must remember something about my "stash of stuff"................ biggrin [and believe it or not, i got RID of FOUR pickup loads of it at Carlisle this year ! eek grin]
beer
Re: E-Body Steering Column [Re: moparx] #3170449
08/25/23 06:32 PM
08/25/23 06:32 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
Re: E-Body Steering Column [Re: jim6346] #3170490
08/25/23 09:08 PM
08/25/23 09:08 PM
IMGTX Offline
IMGTX  Offline
Some later model mopars had tilt & Telescoping steering columns
The column was a GM design if I remember correctly. One of those columns may be modified to fit the Challenger. shruggy
As for removing the Crush Can yes it can be done. Two methods I have used.
Put a tough wheel and adapter which will cut off a few inches and you can still see the gauges fairly well.
I ended up with a Grant GT wheel and their adapter which took the whole length of the crush can out. Works great for me (over 6') but the gauges are covered by the small diameter steering wheel.
The only drawback is you loose some of the safety of the collapsible steering column.
You know my motto..
No Airbags, we die like real men. punkrocka
Re: E-Body Steering Column [Re: jim6346] #3170520
08/26/23 07:58 AM
08/26/23 07:58 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I installed a retro Tuff wheel on my Challenger.Tried the adapter that removes the crush can and
wheel hit the dash. An a-body Tuff Wheel adapter worked perfect also a 6-way seat provides more adjustment.
Re: E-Body Steering Column [Re: RTSE4ME] #3170769
08/27/23 10:29 AM
08/27/23 10:29 AM
IMGTX Offline
IMGTX  Offline
Good looking Challenger. up
Those A body Tough Wheel adapters are also available in B bodies and Truck/Vans if they got the tough wheel or a similar style factory wheel. They seem to became more prevalent after 74 in the B bodies and Truck/Vans. I am pretty sure (correct me if I am wrong) that the tough wheel was a dealer only option in the 74 and older B bodies.
This is the Grant GT and their short wheel adapter in a Challenger.
Re: E-Body Steering Column [Re: ekim] #3170776
08/27/23 11:05 AM
08/27/23 11:05 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Originally Posted by ekim
I just installed the ididit in my '70 Challenger. Crush can is actually smaller and has tilt. I'm 6'1" and did have a hard time with the original set-up, kept hitting my head getting in and out. With the tilt, it is much easier. It is an easy install. Jeff
Re: E-Body Steering Column [Re: 1969RR] #3171092
08/28/23 02:17 PM
08/28/23 02:17 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I agree with all above comments... however, the factory Mopar TUFF Wheel is slippery.. not desirable... go with aftermarket Flaming River or other (they offer much better grip)... and consider in the long run to get a tilt steering column (for dash reading clearance... .and ease of entry/exit).
Re: E-Body Steering Column [Re: Mopar Mitch] #3171099
08/28/23 02:51 PM
08/28/23 02:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A tilt column from a F body might work, it took 3 different columns (f body, van and pickup) to make one fit in my 88 pickup. The tilt ones have a different connection on bottom of shaft because shaft goes in from top. I think a smaller wheel would work the best it remember the e-body’s where NOT made for tall guys so I’d lay the seat back more. I’m 6-2 and it’s not comfortable, I also lowered the seat as far as I could.
