440 rods in 383? #3170046
08/24/23 06:00 AM
08/24/23 06:00 AM
MN
JERICOGTX Offline OP
MN
I want to upgrade the rods, and pistons, in the 383 in my Dad's Super Bee, It currently has stock rods, and old KB pistons. Want to switch to a set of Molnar rods, and forged pistons. Since it needs a custom piston anyways (currently .040 over) I was wondering if anyone runs this combo? I know it's been done many times with a stroker crank. This is for a street car only.
Thanks.
69 GTX 68 Road Runner
Re: 440 rods in 383? [Re: JERICOGTX] #3170057
08/24/23 07:57 AM
08/24/23 07:57 AM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I just got finished putting together a combo like this. I am running a .030 over 383 with the K1 6.760" 440 rods and using a factory forged 383 crank. I am using a custom Wiseco +18cc dome piston because I wanted higher compression and have Trick Flow heads, but I know Diamond has some part numbers for a 3.375" stroke and the 440 rod although from what I recall they may only offer .030" and .060 over" as shelf options.
Re: 440 rods in 383? [Re: IROC78] #3170058
08/24/23 08:03 AM
08/24/23 08:03 AM
MN
MN
With the dome, what does your compression ratio come out to be? The engine has Edelbrock Performer heads on it. Id like to get the compression to around 10.5:1.
Re: 440 rods in 383? [Re: JERICOGTX] #3170060
08/24/23 08:24 AM
08/24/23 08:24 AM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
With the 78cc chamber of the TF head, Cometic .045 head gasket, and -.003 deck clearance it calculated out to somewhere between 12.3 and 12.4 : 1. I had the pistons lightened and that shaved off about 40 grams and I want to say they ended up weighing around 580 grams when finished. I think the Performer head may have a slightly smaller (75cc?) chamber? To get to 10.5 : 1 you will probably still need a small dome. You may be able to achieve that CR by shaving the heads and running a thinner head gasket although just having a custom piston made may be simpler and less expensive. To be honest these pistons I had made were fully custom down to the shape of the dome based on the TF head and only cost a few hundred dollars more than the 383 w/440 rod pistons Diamond lists part numbers for. The worst part for me was trying to find a set of Molnar or K1 rods with the supply chain issues but after posting a want ad here I was lucky enough to have a member here contact me and he was nice enough to sell me a set he wasn't using.
Re: 440 rods in 383? [Re: JERICOGTX] #3170069
08/24/23 09:09 AM
08/24/23 09:09 AM
Out of the State of Confusion
blue_stocker Offline
I'm building this combination for a medium-weight street/drag car: 6.76 PEP rods (this gives the combo a 2:1 rod ratio), Diamond 51907 shelf pistons (flat top pistons with valve reliefs), .000" deck, Cometic C5460-036 gaskets, (or the .020" Chrysler gaskets with -.015" deck), ported 915 heads cut to 65 ccs which comes out to approx 11.4:1 static. You can play with the Wallace compression ratio calculator (I have for years) or do the long math, but their SCR calculator is pretty close, just add your specs and voila, a ballpark estimation! http://www.wallaceracing.com/cr_test2.php
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: 440 rods in 383? [Re: blue_stocker] #3170144
08/24/23 01:56 PM
08/24/23 01:56 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If he sold one old junk tractor, he could use the $$ to put in a stroker crank.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 440 rods in 383? [Re: Hemi_Joel] #3170160
08/24/23 02:28 PM
08/24/23 02:28 PM
MN
MN
Very true, but then the snowball effect starts. The car still has it's numbers matching block, and transmission. While the car will never be for sale, I still don't want to take a chance wrecking the original block. Then you need to buy a new cam, upgrade the fuel system, etc.... It's a street car that gets driven a few times a year. It has more then enough power to destroy tires as it is.
Re: 440 rods in 383? [Re: JERICOGTX] #3170175
08/24/23 03:56 PM
08/24/23 03:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about finding a decent 440 crank and have the mains turned down to B size and have the crank offset stroke to BB Chevy size and increase the stroke to 3.91 and use some after market BB Chevy H or I beam rods 6.8 or 6.7 long to really wake that Super Bee up whistling stirthepot up devil
I do that to some of my milder 400 blocks I build for customers who want to do a low deck build a little cheaper than going with a new stroker crank, rods and pistons up work scope twocents
Re: 440 rods in 383? [Re: Hemi_Joel] #3170222
08/24/23 07:35 PM
08/24/23 07:35 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
One of 'Those guys' hmmmmmm.
Re: 440 rods in 383? [Re: quickd100] #3170320
08/25/23 10:41 AM
08/25/23 10:41 AM
central il.
second 70 Offline
second 70  Offline
central il.
What makes this funny is Joel telling somebody he needs to get rid of something. Lol
Re: 440 rods in 383? [Re: IROC78] #3170337
08/25/23 11:35 AM
08/25/23 11:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Diamond will make them in the oversize needed , shouldn't cost much more than what they charge currently for the piston ... which isn't as cheap as it used to be ...
Re: 440 rods in 383? [Re: Cab_Burge] #3170338
08/25/23 11:41 AM
08/25/23 11:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have that exact build here , 6.70 rods and 1.32 CH , though his oversize at .040 is going to require a semi custom as that is not a common oversize.
My pure stock 383 build the Dan built for me has the Diamond shelf stock 383 piston in it at .040 with a smaller 3 cc piston notch. At zero deck with a set of 80cc 906's it's close to 11.0.
Re: 440 rods in 383? [Re: JohnRR] #3170459
08/25/23 07:17 PM
08/25/23 07:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
FYI, Manley ran a small run of 383 I-beam rods a couple of years back for Stock/SS 383 racers. I bought a set for a SS 383 I'm building. Jim Hale was supposed to buy all of them but wimped out. They are fairly light at 810 grams and I-beam design like their Pro I-beam rods. Not cheap at nearly $1500. The long rods are a better choice for non-NHRA legal engines.
Floyd Lippencott IV
Re: 440 rods in 383? [Re: Cab_Burge] #3170466
08/25/23 07:49 PM
08/25/23 07:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’d bore the main bores out to 440 size, more crank choices out there
Re: 440 rods in 383? [Re: second 70] #3170504
08/25/23 10:54 PM
08/25/23 10:54 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
laugh2 I do have that hoarding thing in common with Jeffs dad. But I think the theory was supposed to be hoard stuff now, then live off the proceeds when you're retired. Except for the stuff you really like. Which is almost every thing... realcrazy
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 440 rods in 383? [Re: cudaman1969] #3170597
08/26/23 01:49 PM
08/26/23 01:49 PM
Why weaken the main bore in the 400 blocks? tsk twocents
Re: 440 rods in 383? [Re: cudaman1969] #3171270
08/29/23 09:39 AM
08/29/23 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a bad move in a 383 block , the main webbing is already paper thin.
Re: 440 rods in 383? [Re: mr_340] #3171274
08/29/23 09:43 AM
08/29/23 09:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know that , I had Dan Costello prep a set of stock rods for my 383 Pure Stock build , at the time the only other choice were Eagles. I'll have to keep my eye out for some ...
'source might have had something but I think they were made of 5140 ... only good for lawnmower engines ...
Re: 440 rods in 383? [Re: JohnRR] #3171306
08/29/23 11:24 AM
08/29/23 11:24 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I haven't built a 383/400 in a long time but if it were me and a non-class restricted combo, I'd offset grind the rods to 2.200 and a 3.51" stroke and use an off the shelf mopar width BBC 6.535 or 6.700 rod and run a lighter .990 pin piston as well. but even keeping the stroke the same the 2.200/.990 is a huge plus especially since any 383 4.25 based bore is starting off as a 427 BBC piston blank anyway.
Of course long rod ratios keep the angularity down and the 'dwell' "up", which was great for holding on the compression when all we had were relatively poor flowing OEM heads.
I had once planned on a 422" long rod B motor combined with something like a TF 240 head to make for a pretty sweet little high-revving medium-size motor that would be easy on a factory block and should last forever compared to a short rod stroker. and with enough gear and converter you could concievably make about the same power and ET
And if you wanted to get really crazy you could de-stroke the crank to 3.23" or so and build a 400 based 389" with TF 270's and a 7.1" rod (~1.26" compression height piston) and see how high we could really rev a B wedge.
But if I was using an LY or similar oem rod with a 1.09 pressed pin, i would definitely do the old Landy trick and whack 1/2" off the pin and save about 50 grams per slug. you're gonna have to re-balance anyway so why not take out weight instead of add it back?
WIZE
In Car:
Re: 440 rods in 383? [Re: Streetwize] #3171380
08/29/23 02:50 PM
08/29/23 02:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Something like that never even crossed my mind ... now I'm going to have to take the 383 that Dan did for me apart ...
