belt driven fuel pump #3168951
08/19/23 12:27 AM
08/19/23 12:27 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
How much presure do you think is on the bracket that holds a belt driven fuel pump I have to make or modifie the bracket on my BLP pump. Thanks
Re: belt driven fuel pump [Re: dragon] #3168964
08/19/23 06:41 AM
08/19/23 06:41 AM
gregsdart Offline
gregsdart  Offline
I run an 80a-1 pump for methanol constant flow fuel injection. Pressure is 60 psi at times. It mounts with two four inch bolts through a casting, to the cam cover threaded holes in the block. One is 3/8, the other 5/16 diameter. No problems in twenty four years.
Here is the big block mount kit, etc The bracket that holds the pump is just left of the big silver pulley
Re: belt driven fuel pump [Re: gregsdart] #3169836
08/23/23 02:30 AM
08/23/23 02:30 AM
gregsdart Offline
gregsdart  Offline
You can mount the pump on the driver's side like I did by drilling the smaller hole in the bracket to accept the larger bolt. Some massaging of the brackets was done as well to make it fit where I wanted it. I use a different length belt as well.
Re: belt driven fuel pump [Re: gregsdart] #3170274
08/25/23 12:05 AM
08/25/23 12:05 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Thanks I did a lmost the same thing it looked felt strong enough never hurts to ask thanks again
