Re: Oil Weight for big cube street / strip Motor
[Re: an8sec70cuda]
#3169623
08/22/23 10:16 AM
08/22/23 10:16 AM
Posts: 9,848 MI, usa
dvw
MI, usa
Mine runs .0030"/.0027" clearance. Its run a 50/50 mix of JR1 5w20/ 5w30 for yers. Pressure runs 50@idle/80@7000. Oil temp is normally around 150 degrees. Same babbit cam bearings for over 950 passes. Springs are 310/805 psi Doug
[Re: Dragula]
#3169719
08/22/23 03:03 PM
08/22/23 03:03 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I may be wrong here, I'm certainly no Ray Barton, but the roller cam bearings in those blocks are for friction reduction due to insane spring pressures (and larger cam cores) moreso than oiling. Taking oil away from the lifters where it isn't really needed is more beneficial in your case than having roller bearings. Yes exactly....For me, its a volume issue. I have been killing #7 & #8 bearings for years when they starve for oil....Wondering what other folks due differently. Obviously, an accumulator might be in order as well. So roller cam bearings and maybe sleeved lifter bores sounds like what I have been missing. Maybe a better oil pump or and more oil volume in the oil pan
[Re: Cab_Burge]
#3169846
08/23/23 07:39 AM
08/23/23 07:39 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I may be wrong here, I'm certainly no Ray Barton, but the roller cam bearings in those blocks are for friction reduction due to insane spring pressures (and larger cam cores) moreso than oiling. Taking oil away from the lifters where it isn't really needed is more beneficial in your case than having roller bearings. Yes exactly....For me, its a volume issue. I have been killing #7 & #8 bearings for years when they starve for oil....Wondering what other folks due differently. Obviously, an accumulator might be in order as well. So roller cam bearings and maybe sleeved lifter bores sounds like what I have been missing. Maybe a better oil pump or and more oil volume in the oil pan He's not lacking oil in the pan. I think he runs a 10-12 quart pan already. I think he runs the good Milodon external pickup style pump also.
[Re: Dragula]
#3169923
08/23/23 03:11 PM
08/23/23 03:11 PM
an8sec70cuda
At this point, if you had a 55 gallon drum for an oil pan, it wouldn't matter. I don't think the amount of oil you have in that motor is gonna matter...it's where the oil is going (or isn't going) that's the issue.
[Re: an8sec70cuda]
#3169925
08/23/23 03:14 PM
08/23/23 03:14 PM
Cab_Burge
[Re: second 70]
#3170159
08/24/23 02:27 PM
08/24/23 02:27 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
With my 55MM roller cam bearing cam. I run Penn Grade 10W30 with a Melling high volume oil pump that I took apart clearanced, ported and polished. Also run bronze bushed lifter bushings with push rod oiling and the RBRE rocker system that has built in spray bars. Also a 10 quart Milodon flat bottom top fuel/funny car oil pan with Milodon external pick up. and a 3 quart Accusump (just in case). No issues on the street with hundreds of miles or strip.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3170302
08/25/23 09:44 AM
08/25/23 09:44 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
"I have been killing #7 & #8 bearings for years when they starve for oil" In the interest of not being totally useless, thought I should mention during the WP/MP/Royal Oak boring era I did replace two iron blocks because the drill bit for the main oil feed broke through the side of the main structure. This type of defect would create the type of pinhole internal leak that could cause a similar problem. At the time, the oil feed hole was 5/16", which is pretty huge given the lack of material in the area of the main structure above the crank, where the hole passes through. I never found out whether the hole was to print, or a world famous engine builder's idea. It's not hard to repair with a tube pressed in..... but a messy job to confidently find it.... as the whole thing has to be assembled, pressurized, and viewed with the oil pan off, to look for leaks where there shouldn't be. Might not need exotic parts or machine work, might be something wrong with the block OK, back under my rock I go.
Rich H.
Esse Quam Videri
