Company making off-the shelf Mopar turbo headers #3169082
08/19/23 07:15 PM
08/19/23 07:15 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
There is a company on eBay that makes a few turbo headers for mopars, but seem to be of a limited verities, but I came across this US company making a large verity of turbo headers, including front exit headers. Thought I would post a link here. They even offer kits if you want to build your own, and in stainless no less.
https://www.stainlessheaders.com/mopar-bolt-on-turbo-headers
Re: Company making off-the shelf Mopar turbo headers [Re: migsBIG] #3169097
08/19/23 09:02 PM
08/19/23 09:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I guess there is bang for buck ratio for every engine solution, but, if I remember correctly "Engine Masters" felt thru testing a log style turbo exhaust left a lot on the table power wise vs a full tube turbo manifold.
Re: Company making off-the shelf Mopar turbo headers [Re: jcc] #3169147
08/20/23 08:42 AM
08/20/23 08:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Have you priced one?
Did it fit?
Boffin Emeritus
Re: Company making off-the shelf Mopar turbo headers [Re: polyspheric] #3169280
08/20/23 07:13 PM
08/20/23 07:13 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Did it fit?
I just found the site and looks like they price out at a grand for done set and about half of you want to build it yourself. Just posting it because a few members in the past were looking for turbo options and some (like myself) are not in a position to make their own set.
JCC, I remember that test and it great info. For those on the board that were looking for something that could be used for a bit more competitive, convenient or wanting to go full race mode, they offer a few choices. The negative part of using manifolds is where you’re looking to have the exhaust exit and manifolds may be a little restrictive. Headers can be repaired and modified if needed while manifolds if damageged would need to be sources and replaced, not something someone wants to worry about before a race. Plus, front mount headers for mopars out the box is nice. Anyone building turbos products for mopars should be shown support as we don’t have major companies fighting to build specific products for our drivetrains/vehicles.
Re: Company making off-the shelf Mopar turbo headers [Re: migsBIG] #3169335
08/20/23 11:21 PM
08/20/23 11:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I should have added in my above slightly disparaging reply, a turbo with a crappy exhaust turbo header, still blows away, pun intended, anything NA. grin
Re: Company making off-the shelf Mopar turbo headers [Re: migsBIG] #3169344
08/21/23 05:03 AM
08/21/23 05:03 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I'd be thinking about what happens when that straight large tube heats up and grows.
Re: Company making off-the shelf Mopar turbo headers [Re: jcc] #3169360
08/21/23 08:45 AM
08/21/23 08:45 AM
CJD AUTOMOTIVE Offline
Stainless Headers is a good company. I buy a lot of my 321 and 304 stainless from them. It's all Rath/Gibson tubing, so excellent quality and US manufactured.
Bend quality is pretty good, would be what Burns sell as B-stock, so comes down to cost versus fitment time.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Company making off-the shelf Mopar turbo headers [Re: CJD AUTOMOTIVE] #3169919
08/23/23 02:39 PM
08/23/23 02:39 PM
moparx Offline
moparx  Offline
$1000.00 doesn't sound out of line, especially if one compares turbo headers to some of the TTI headers for a big block.
stating now, i don't know a thing about turbos. just a casual observation.
your mileage will vary.
beer
Re: Company making off-the shelf Mopar turbo headers [Re: moparx] #3169954
08/23/23 05:58 PM
08/23/23 05:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Seems reasonable. But I can get stainless LS headers for under $200
I have a set hanging on the wall as wall art
Re: Company making off-the shelf Mopar turbo headers [Re: FastmOp] #3169957
08/23/23 06:27 PM
08/23/23 06:27 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
You can occasionally find stainless headers for Mopar applications that look like exact duplicates of other company's mild steel products on eBay. Just depends when the Chinese factory makes a run.
Re: Company making off-the shelf Mopar turbo headers [Re: MarkZ] #3170022
08/23/23 10:53 PM
08/23/23 10:53 PM
IL
furious70 Offline
furious70  Offline
IL
from the measuring and test fitting I've done before I built the TT setup in my Fury and doing mock up for the eventual one in my Coronet, A arms, PS, and alt all normally have issues with straight ahead forward manifolds. You would want to talk to them about what bodies they've tested on and what were the FMEA configurations tested.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Company making off-the shelf Mopar turbo headers [Re: migsBIG] #3170204
08/24/23 06:03 PM
08/24/23 06:03 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
One of the things i have learned works well with the big block pattern on the flanges is to add an upper and lower fastener between the two center exhaust ports. This spot was a constant troublesome area for leaks.I never used gaskets on the exhaust and had extremely minimal leakage after doing this. Look at the carbon trace on the head…
Re: Company making off-the shelf Mopar turbo headers [Re: CJD AUTOMOTIVE] #3170374
08/25/23 01:27 PM
08/25/23 01:27 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks for the info. up
Re: Company making off-the shelf Mopar turbo headers [Re: TRENDZ] #3170410
08/25/23 03:31 PM
08/25/23 03:31 PM
moparx Offline
moparx  Offline
wonder if that would be a good idea for standard type headers, provided there is enough meat on the header flange to do so, and still allow reduced hex flange nuts to be used. work
beer
