Interesting 540 dyno test #3169050
08/19/23 04:23 PM
08/19/23 04:23 PM
AndyF Online content OP
AndyF  Online Content OP
We're running a 540 BBC on the dyno this week and it isn't going very well. The engine just won't rev past 6000 rpm. It is a hyd roller cam so that is the obvious suspect but it doesn't make any valvetrain noise at 6000 rpm and it has the correct springs in it and plenty of oil pressure. We actually think the problem is due to something weird in the EFI system and/or the intake manifold itself. We're going to switch over to a carb next week to see what happens. This engine has been on the dyno before and last time it acted weird. It has a lot of really good parts but something isn't correct somewhere. Hopefully we can figure it out. Here is a short video showing two dyno pulls back to back: https://youtu.be/4q-tV1mNl-g
Engine is making 730 hp on these pulls so it isn't a slouch, but it should be making more and it should be pulling higher so something is wrong somewhere. Plugs all look good, EGTs are normal, AFR is normal, etc. so no obvious clues.
Re: Interesting 540 dyno test [Re: AndyF] #3169052
08/19/23 04:37 PM
08/19/23 04:37 PM
gregsdart Offline
gregsdart  Offline
For it to hit a wall like that I have wonder about spark? Rev limiter?
Re: Interesting 540 dyno test [Re: gregsdart] #3169055
08/19/23 04:55 PM
08/19/23 04:55 PM
gregsdart Offline
gregsdart  Offline
I am guessing though that if it was spark related, you might see a drop in egt, or the afr would go berserk?
Re: Interesting 540 dyno test [Re: AndyF] #3169062
08/19/23 05:25 PM
08/19/23 05:25 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
What kind of EFI system, can you post a log?
Without Data, you’re just another guy with an opinion.
Re: Interesting 540 dyno test [Re: sr4440] #3169070
08/19/23 06:38 PM
08/19/23 06:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
When ever we hit a wall like that, its been the valve springs. But curious as to what you find.
Re: Interesting 540 dyno test [Re: sr4440] #3169072
08/19/23 06:45 PM
08/19/23 06:45 PM
Holley EFI system. It is a complete Holley kit. I'm not a fan of the 90 degree connectors that Holley used and they used a weird internal regulator that doesn't look to me like it will work properly. I think it is a fuel issue but I don't know for sure. Rev limit is set at 7000 rpm in the software. The data log shows a little ripple on the RPM signal after 6000 rpm which is what the trace looks like when it hits a rev limiter but we don't have one set at that RPM. We'll switch to a carb and MSD distributor just to see what happens. That is an easy test to run when it is on the dyno.
Re: Interesting 540 dyno test [Re: AndyF] #3169088
08/19/23 07:49 PM
08/19/23 07:49 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What does the BSFC do at the top of the rpm range?
Re: Interesting 540 dyno test [Re: 6PakBee] #3169100
08/19/23 09:17 PM
08/19/23 09:17 PM
Looks normal but you can't always trust the data since the fuel flow on an EFI engine is what the ECU is commanding, not what actually flows. Usually the same thing unless something weird is happening.
Re: Interesting 540 dyno test [Re: AndyF] #3169137
08/20/23 07:21 AM
08/20/23 07:21 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Just did a guy's engine on my dyno, stroked 340 Mopar and it acted just like yours. Ran good down low but fell off quick after 6,200 rpm. I told him to check the valve springs. They went home and pulled the heads, the valve pockets in the piston were deep enough but not big enough in diameter, the intake valves were just touching the edges under high load.
Re: Interesting 540 dyno test [Re: jwb123] #3169196
08/20/23 01:07 PM
08/20/23 01:07 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Chinese casting heads? Asking because I have seen this happen with various brands and makes of engines.
Re: Interesting 540 dyno test [Re: fbs63] #3169234
08/20/23 03:25 PM
08/20/23 03:25 PM
Yeah I've seen that several times including BB Chevy engines. The really cheap no name Chinese stuff works okay for a cruiser but won't make power at WOT. But that shouldn't be the case with this engine since the customer bought really nice parts including a Dart block and AFR 335 cnc heads. It isn't a high compression engine since it is heading into a street car, but my 470 Mopar with TF270 heads made more power on pump gas than this 540 is making. AFR 335 BB Chevy heads should flow a ton more air than Trick Flow Mopar 270 heads and 540 is 70 inches bigger than my 470 so something isn't clicking.
We'll get some runs on it this week with a 1050 Dominator and a MSD billet distributor and see what happens.
Re: Interesting 540 dyno test [Re: AndyF] #3169288
08/20/23 07:56 PM
08/20/23 07:56 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Good to know. Interested to see what it is!
Re: Interesting 540 dyno test [Re: AndyF] #3169303
08/20/23 08:58 PM
08/20/23 08:58 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It will be interesting to see what happens with a carb. That should eliminate the uncertainty with EFI.
Re: Interesting 540 dyno test [Re: fbs63] #3169340
08/20/23 11:32 PM
08/20/23 11:32 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Are you running out of injector pulse width, is there a limiter for it in the injection?
Re: Interesting 540 dyno test [Re: Uberpube] #3169649
08/22/23 12:14 PM
08/22/23 12:14 PM
I checked that and injector duty cycle was only about 70% when the engine hit the wall.
We switched over to a 1050 Dominator and made some pulls. The engine is still really rough down low but smooths out at WOT with the Dominator and sounds pretty healthy. It pulls to 6200 RPM with the Dominator before the lifters start to complain. Power is roughly the same as with EFI but the curves are a little bit smoother.
At this point I think it is probably the intake manifold design and something wrong with the EFI fuel rails. It actually makes good power and the customer should be happy with it for a street engine. It makes enough power to completely destroy tires as well as transmissions and rear ends so it should be good to go. I guess he'll put it in the car and see how it performs. It might work just great once he gets it bolted up to a good converter. I have some ideas on how to fix the fuel rail layout so I'll suggest those. Changing the intake is a big deal in an EFI engine so I doubt he'll want to experiment with that.
Re: Interesting 540 dyno test [Re: AndyF] #3169654
08/22/23 12:28 PM
08/22/23 12:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Unless you’re duplicating a known good valve train combo....... big block weight parts, high rocker ratios, Hyd lifters and higher rpm’s can be a challenge to get sorted out.
Re: Interesting 540 dyno test [Re: AndyF] #3169680
08/22/23 01:34 PM
08/22/23 01:34 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Can you change the injection phase angle in the software? It could be fuel stand off in the intake where the fuel gets blown backwards up the intake and it acts like a rev limiter as the engine stutters because the mixture goes all to hell. When I was welding up custom intakes for rotaries, the more overlap I put into the motor, the farther away the injectors had to be away from the rotor, or in your case, cylinder. On some intakes, i could fix it with phase angle changes.
Re: Interesting 540 dyno test [Re: fast68plymouth] #3169774
08/22/23 07:12 PM
08/22/23 07:12 PM
I agree. We proved to ourselves that the upper rev limit is the lifters. The lower RPM roughness appears to be manifold related. EGT values are all over the map at 2000 rpm but they smooth out at higher revs. The weird pulsing issue was due to the poor fuel rail design and the undersize fuel pressure regulator.
Re: Interesting 540 dyno test [Re: Uberpube] #3169775
08/22/23 07:13 PM
08/22/23 07:13 PM
The injector phase table that I have in there is known good table for this type of engine. I didn't mess with it since it should work but there is always a chance that this motor wants something weird.
Re: Interesting 540 dyno test [Re: AndyF] #3169865
08/23/23 10:08 AM
08/23/23 10:08 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Did you try more valve spring? Or lighter springs/retainers. (smaller OD, titanium)
I've yet to see a loss of valve control come down to the lifter itself. JMO
