Re: 340 engine questions
[Re: 71GoMango]
#3169021
08/19/23 01:18 PM
08/19/23 01:18 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As with all questions concerning overboring, only an ultrasonic test will confirm the safe overbore size. Sleeving only one cylinder is a common practice. Depending on where in the bore the pits are, you might consider leaving the bore as is and call them "oil reservoirs".
[Re: John_Kunkel]
#3169368
08/21/23 09:22 AM
08/21/23 09:22 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I always heard 340s had thin walls. I've only sonic checked one and it was very thin. Same deal as you have...it was a .030" over 340 w/ rust pits in multiple cylinders and it would not tolerate another overbore. Honestly, some were marginal at .030" over. Not worth slamming a bunch of sleeves in to save it. In your case, I'd have no problem sleeving that one hole and running it. With what people want for a good 340 block, sleeving one hole is a much cheaper alternative.
[Re: Cab_Burge]
#3169821
08/22/23 10:46 PM
08/22/23 10:46 PM
Posts: 2,005 Apollo, PA.
B1MAXX
Apollo, PA.
things I know about sleeving a 340. A sleeve at 4.283 will typically pin hole the bore. adjacent bore(s) will require boring/honing of at least .003 to correct out of round.
unless the pits are in the very upper 1" of ring travel, and significant in size (width of ring) forget about them.
[Re: B1MAXX]
#3169970
08/23/23 06:59 PM
08/23/23 06:59 PM
Posts: 20,706 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
You can buy .040 over 340 pistons from a few vendors, but they may likely be a custom order as many go from .030 straight to .060. Video of a 396 block being fully re-sleeved I watched a few days ago. This one was in pretty bad shape when they got it. These two have other videos that are pretty interesting to watch if you like engine machine work in general. https://youtu.be/G7M1UC5PVZ4?si=FxviJydTJNNXghQD
