Tubular upper arms? #3168410
08/16/23 10:54 PM
08/16/23 10:54 PM
WI
Dcuda69 Offline OP
Dcuda69  Offline OP
WI
Looking at adding tubular upper arms to help gain caster. 69 B'cuda w/73- up disc brakes,manual steering, BB/4spd car,street toy, Hellwig sway bar.Looking at QA1 and PST. Any others I should be looking at?
Re: Tubular upper arms? [Re: Dcuda69] #3168464
08/17/23 10:02 AM
08/17/23 10:02 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Had QA1s on a Duster - installed by previous owner.
They worked fine, car drove great with the added caster, but they would squeak.
I lubed them, still had a bit of a squeak, but never heard it while driving.
Re: Tubular upper arms? [Re: topside] #3168469
08/17/23 10:53 AM
08/17/23 10:53 AM
Andrewh Offline
Andrewh  Offline
I would bet firm feel makes some and I run them on my early b. but not sure on an a.
Re: Tubular upper arms? [Re: topside] #3168473
08/17/23 11:08 AM
08/17/23 11:08 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I have Magnum Force on three cars, love them. I have the standard one, the single adjustable and the double adjustable. 10k miles on pothole riddled California roads in 5 years one the Cuda. No wear and didn't squeak a bit. They might be back ordered for the meantime as they had a new shop built and have been transferring over.
Re: Tubular upper arms? [Re: migsBIG] #3168485
08/17/23 11:39 AM
08/17/23 11:39 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I used the Firm Feel tubular uppers on my 70 Sport Satellite . . . went with the "standard" rubber bushings - no squeek. Also, because I like to drive the car, and never know when you can encounter "weather" . . . I prefer the rubber bushings, over the hiem joints. . .
just my 2 cents
Cheers,
Mark
Re: Tubular upper arms? [Re: a12rag] #3168558
08/17/23 02:53 PM
08/17/23 02:53 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have a set of Firm Feels on my 1970 'Cuda. No issues and it does seem to handle a bit better with the added caster they allow.
Re: Tubular upper arms? [Re: a12rag] #3168685
08/17/23 10:31 PM
08/17/23 10:31 PM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
just my 2 cents
Cheers,
Mark
The non adjustable magnum force arms are rubber bushed, not that anything wrong with the billet ones.
Re: Tubular upper arms? [Re: migsBIG] #3168699
08/18/23 12:14 AM
08/18/23 12:14 AM
WI
Dcuda69 Offline OP
Dcuda69  Offline OP
WI
Not a fan of the Magnum force design. The Firm Feel and PST stuff looks the same....is one supplying the other? The QA1 is definitely different and $40 more....might be the way I go?
Re: Tubular upper arms? [Re: Dcuda69] #3168764
08/18/23 11:01 AM
08/18/23 11:01 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If budget matters, you can shorter the rear arm on each side of your original ones 1/4" and with the offset problem solver bushings you will get all the adjustment you could possibly need. It used to be called the Ford mod or the Ford cut which is where I first heard of it years ago. laugh2 I have done this to all of my Mopars for many years. It is cheap and effective. My alignment guy always has plenty of room to get it where it needs to be.
Master, again and still
Re: Tubular upper arms? [Re: Dcuda69] #3168796
08/18/23 12:53 PM
08/18/23 12:53 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
No opinion on the arms, but what I can say is stay away from poly control arm bushings. I've used poly bushing on almost everything and never had squeaks. Ordered them on the tubular arms and the squeaks are driving me nuts.
Re: Tubular upper arms? [Re: MarkZ] #3168810
08/18/23 01:49 PM
08/18/23 01:49 PM
A collage of whims
A collage of whims
Comparing the MF curved arms va the straight arms, seems to me the straight ones are stronger.
Think compression & extension forces vs bending an arc.
Dave's comment on modding the OEM arms has merit: my Duster (sig pic) had the front leg widened about that amount by Jack Arnew back in the day.
Car goes straight as a string @ 130 at the track, runs about 7 deg pos caster.
Wheels remain vertical during wheelstands with no bump steer when it sets down.
Only side-effect is it self-centers aggressively, don't have your hand between the steering wheel spokes when it centers.
Depending on the combo, 3.5-5.0 works well on the street.
Re: Tubular upper arms? [Re: topside] #3168936
08/18/23 10:11 PM
08/18/23 10:11 PM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
Not sure if this is of any concern, but the MF arms are made with chromoly tubing and US sourced. I know most other brands use mild steel tubing. I’ve never had an issue with strength and the only two times I ever seen them bent in 15 years was due to severe accident impact. If fact, when the guys 1968 Barracuda got clipped and hit the side roadway, it was still attached to the spindle when the frontend came off the car.
