Is there off the shelf 400 stroker piston with smaller rings
#3168494
08/17/23 12:07 PM
08/17/23 12:07 PM
Posts: 2,657 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I know a guy wanting to build a 4.150 or 4.250 stroke 400 block engine. I've looked at Scat and 440 Source stroker kits. I would like smaller (more modern) rings like .043/.043/2mm or 1.2/1.2/2mm. Does anybody make an off-the-shelf piston for these motors like that? I know Diamond will make customs, but $$$. Thanks.
2011 Drag Pak Challenger
Re: Is there off the shelf 400 stroker piston with smaller rings
[Re: rickseeman]
#3168517
08/17/23 12:52 PM
08/17/23 12:52 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
I know a guy wanting to build a 4.150 or 4.250 stroke 400 block engine. I've looked at Scat and 440 Source stroker kits. I would like smaller (more modern) rings like .043/.043/2mm or 1.2/1.2/2mm. Does anybody make an off-the-shelf piston for these motors like that? I know Diamond will make customs, but $$$. Thanks. Diamond used to do a one or 2 changes to a shelf stock for a small upcharge, I guess that is not the case anymore ?
[Re: JohnRR]
#3168526
08/17/23 01:08 PM
08/17/23 01:08 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I would try RaceTec pistons. They are extremely easy to deal with and have a lot of stuff available that may not be in the online catalog and will make a few minor changes with no or low upcharge.
AG
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: EchoSixMike]
#3168625
08/17/23 07:42 PM
08/17/23 07:42 PM
rickseeman
Stuttgart, Arkansas
Mahle uses a metric ring stack. S/F....Ken M I've heard of those. They look like the best of off-the-shelf so far.
[Re: gregsdart]
#3168716
08/18/23 07:21 AM
08/18/23 07:21 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I really liked the -12.5cc dish, 1.32 CH piston that Diamond sells for the 400 with a 4.25" crank. Unfortunately the price has nearly doubled in ten years.
My current go to is Mahle and thankfully the 2023 catalog lists 1.320 CH offerings. The only dish piston I see listed is stock 440 CH.
Also of note is that Mahle makes a gas nitrided steel top ring that is sold only as a top ring package to go with the 2nd/oil ring provided in with the piston kits. This saves $100+ over buying a complete set of hellfire rings.
Here is the 2021 Mahle ( pronounced mah-la) offerings for mopars
[Re: Jeremiah]
#3168717
08/18/23 07:23 AM
08/18/23 07:23 AM
Jeremiah
Rogue River, OR
In comparison here is the 2023 mopar section. All B and RB pistons are 1.5/1.5/3.0mm
[Re: Jeremiah]
#3168734
08/18/23 09:10 AM
08/18/23 09:10 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
What I don't get with nearly all Mahle pistons is that they yield a way too high compression ratio for pump gas if building a stroker. The only option is to use iron heads with 88+ cc chambers. They completely ignore all engines that use modern aluminum cylinder heads which have combustion chambers between 72 and 84cc.
[Re: Jeremiah]
#3168735
08/18/23 09:10 AM
08/18/23 09:10 AM
JohnRR
U.S.S.A.
In comparison here is the 2023 mopar section. All B and RB pistons are 1.5/1.5/3.0mm That 1.320 is a great CH for the low deck ... to me anyway ... you can use it with multiple strokes all the way up to 4.25 with just a rod change. That's a great street piston , would be nice if they made it as a flat top to get a little more squeeze ...
[Re: DGS]
#3168736
08/18/23 09:13 AM
08/18/23 09:13 AM
JohnRR
U.S.S.A.
What I don't get with nearly all Mahle pistons is that they yield a way too high compression ratio for pump gas. The only option is to use iron heads with 88+ cc chambers. They completely ignore all engines that use modern aluminum cylinder heads which have combustion chambers between 72 and 84cc. What is too a high compression ratio for you in Europe, I don't really see an issue with 10/11 with a good closed chamber design aluminum head here in the states , I could run something like that all day on 93 ?
[Re: JohnRR]
#3168790
08/18/23 12:37 PM
08/18/23 12:37 PM
rickseeman
Stuttgart, Arkansas
Thanks for everyones ideas. The Mahle looks the best off-the-shelf but the ring spacer idea sounds good too. I'll check the Diamond price but I've got a bad feeling about that. I'll look at these ideas. Thanks
[Re: rickseeman]
#3170430
08/25/23 04:39 PM
08/25/23 04:39 PM
Posts: 567 Sth.IL
dare_dude
Sth.IL
[Re: dare_dude]
#3170465
08/25/23 07:47 PM
08/25/23 07:47 PM
Posts: 410 NH, USA
toddinNH
Egghead
Egghead
NH, USA
I'd call Racetec. They'll give you options for minimal cost. Or, just buy the Mahles as they have clear advantages in a shelf piston. I don't think you can go wrong either way. Diamond is going to be quite a bit more expensive. https://www.lsxceleration.com/search.php?search_query=Mahle+pistons§ion=product ofttimes has deals on Mahle pistons for the LS guys(I got a smokin' deal on two sets I bought there) I'd call them with the Mahle part umber and the best price you've found and see if they'll beat it. Great no BS shop.
