Best place to buy a dana 60 these days #3164893
08/01/23 04:56 PM
08/01/23 04:56 PM
USA
hudsonhornet7x Offline OP
USA
I need a dana 60 for my 68 Charger. Who is a good company to deal with these days? Thanks
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3164896
08/01/23 05:05 PM
08/01/23 05:05 PM
Sticky South
Rodenteliminator Online content
Rodenteliminator  Online Content
Sticky South
Dr. Diff he can get what you need, I bought a Strange S60 thru him flawless deal. Doug
Sorry honey I spent the rent
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3164897
08/01/23 05:11 PM
08/01/23 05:11 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I got a Dana 60 from Doctor Diff for my 1968 Charger
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Best place to buy a dana 60 these days [Re: metallicareload] #3164899
08/01/23 05:16 PM
08/01/23 05:16 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Dr Diff
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3164944
08/01/23 08:35 PM
08/01/23 08:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
S60 from the good Dr in my Duster too! Cass definitely took care of us!
Re: Best place to buy a dana 60 these days [Re: J_BODY] #3164945
08/01/23 08:50 PM
08/01/23 08:50 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I bought my S-60 through Dr. Diff.
It was easy.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3164959
08/01/23 09:14 PM
08/01/23 09:14 PM
AndyF Offline
AndyF  Offline
S60 from Strange. Doctor Diff is a good dealer to work with, especially if you want to add disc brakes or stuff like that. If it is a stock width rear end then you can also get the correct brake lines and mating parts. If you are going with a non-stock width then you'll most likely need to build your own lines.
Re: Best place to buy a dana 60 these days [Re: AndyF] #3165059
08/02/23 11:52 AM
08/02/23 11:52 AM
central il.
second 70 Offline
second 70  Offline
central il.
S 60 from Dr, Diff fast service and he even handled sale and shipping of my factory Dana to another member.
Re: Best place to buy a dana 60 these days [Re: second 70] #3165073
08/02/23 12:40 PM
08/02/23 12:40 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
It's been so long that I can't remember if I got my Strange from Dr. Diff or my diff from Dr. Strange...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Best place to buy a dana 60 these days [Re: Brad_Haak] #3165090
08/02/23 01:15 PM
08/02/23 01:15 PM
USA
USA
Sounds like there is a consensus. Thanks to all, I will be calling soon.
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3165098
08/02/23 01:33 PM
08/02/23 01:33 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Ordered my S60 from Dr Diff 6/29.Received a Email over the weekend
that it is on it's way.
Re: Best place to buy a dana 60 these days [Re: mkdart] #3165132
08/02/23 03:44 PM
08/02/23 03:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I ordered my complete axles and spool from Dr. Diff for my cut down truck Dana 60.
Excellent service and they installed and worked perfectly for quite a few years now.
So, one more vote for the good Dr.!
'63 Dodge 330
11.19 @ 121 mph
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3165240
08/03/23 03:23 AM
08/03/23 03:23 AM
I buy junk yard Dana 60s, especially ones with damage axle tube ends, and have them shorten and put in new 35 spline axles and a spool or if I have a good Dana 60 clutch type posi unit I will convert it to 35 splines by replacing all the internal parts needed to do that conversion. If it is going in a drag car I will buy the correct 35 spline spool for that gear set and buy drag race axles instead of street axles work up
Re: Best place to buy a dana 60 these days [Re: hudsonhornet7x] #3165253
08/03/23 09:04 AM
08/03/23 09:04 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
A buddy of mine has a Dana 60 that he took to Little Rock and had rebuilt by a proper shop. Might even be a 68. He sold his Road Runner project 2 weeks ago so I know he doesn't need it. You might try him if you want an original. I don't know where you're at, he's in Stuttgart, Arkansas. His name is Bobby Hall. His cell is 870-830-8401. He mows yards for a living so you might have to leave a message.
2011 Drag Pak Challenger
Re: Best place to buy a dana 60 these days [Re: rickseeman] #3167859
08/14/23 02:03 PM
08/14/23 02:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
S60
Re: Best place to buy a dana 60 these days [Re: CMcAllister] #3167875
08/14/23 03:05 PM
08/14/23 03:05 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I recently ordered an S60.
By the time I bought a yoke, axles, differential, gear and install kit for my original Dana there wasn't much difference in cost. (going from 4.10 to 4.56)
Plus I wasn't really looking to set it up with shims under the bearings again.
Re: Best place to buy a dana 60 these days [Re: INTMD8] #3167918
08/14/23 06:24 PM
08/14/23 06:24 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Second the Dr. Diff suggestions. I bought my S60 through him earlier this year, and had some special requests that got handled with no issue. I also picked it up from Strange directly and got to see the facility.
