MSD 8998 or 89981 tester?
#3167912
08/14/23 05:45 PM
08/14/23 05:45 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
...and why?
Drag race stuff
Re: MSD 8998 or 89981 tester?
[Re: CMcAllister]
#3167919
08/14/23 06:30 PM
08/14/23 06:30 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Not even a contest, pick the 89981, it can do everything the 8998 can do plus coil on plug, crank trigger wheels and adjust the dwell on individual coils. The only disadvantage is it is not reparable.
Without Data, you’re just another guy with an opinion.
[Re: CMcAllister]
#3168025
08/15/23 08:34 AM
08/15/23 08:34 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
FWIW...I had a misfire issue w/ a digital 6al-2 programmable box that tested fine w/ the 8998 tester.
[Re: sr4440]
#3168056
08/15/23 11:33 AM
08/15/23 11:33 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not even a contest, pick the 89981, it can do everything the 8998 can do plus coil on plug, crank trigger wheels and adjust the dwell on individual coils. The only disadvantage is it is not reparable. That's what I was thinking, But the fact that the 8998 is almost double the price had me wondering what I was missing. The ability to test and verify rev limiters, shifters and shift lights, nitrous solenoids, and anything else using RPM, along with the functions of the box, coil, wiring, etc., without having to run the engine in a race car, put laps on it, or throw parts at it, is where the value of these show up.
[Re: CMcAllister]
#3168062
08/15/23 11:59 AM
08/15/23 11:59 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
89981 for the reasons given as well as it works with the Grid which the older 8998 does not. It also allows you to simulate runs etc to ensure RPM functions work.
[Re: Al_Alguire]
#3168097
08/15/23 02:18 PM
08/15/23 02:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
89981 for the reasons given as well as it works with the Grid which the older 8998 does not. It also allows you to simulate runs etc to ensure RPM functions work. Yes Sir, I saw that. Just thought I was missing something. Better is seldom cheaper.
