Who makes good ball joint/Tie rods #3167900
08/14/23 04:28 PM
08/14/23 04:28 PM
Finally a HUSKER again
Moparnut426 Offline OP
There may only be 1000 miles on the Cuda and the upper ball joints are loose, I bought the complete sets from Mancini, New control arms with Ball joints and Bushings in them. Im Getting ready to buy the Suspension parts for the Bee, and I honestly plan on driving this car coast to coast, dont need any junk parts on it. Who sells a good ball joint now a days?
Kasey
Re: Who makes good ball joint/Tie rods [Re: Moparnut426] #3167961
08/14/23 08:52 PM
08/14/23 08:52 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
We've went to Mevotech supreme. Years ago we tried them first in one of our second gen Cummins snow plow trucks and they lasted longer than Moog. Then my 70 challenger that also had Moog prior and so on... We have a local company Fastundercar that stocks most everything we need and close pricing to rockauto. But the Rock has everything.
Re: Who makes good ball joint/Tie rods [Re: boomerodell] #3168038
08/15/23 10:09 AM
08/15/23 10:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agree on Mevotech being a good choice.
Moog is garbage now , it's coming out of the same southeast asian factory as duralast ... at least the made wrong control arm I got for my 98 ram 2500 2wd did ...
Re: Who makes good ball joint/Tie rods [Re: JohnRR] #3168072
08/15/23 12:52 PM
08/15/23 12:52 PM
moparx Offline
moparx  Offline
moog has been junk for at least the last 15 years or so..........
has anyone used proforged parts ?
as to the mevotech brand, i have used several of their parts in the past, and was pleasantly surprised at the fit and function of the items.
these were used on my caravan [the "bus"] and have been on for several years now, without a problem.
beer
Re: Who makes good ball joint/Tie rods [Re: moparx] #3168138
08/15/23 05:36 PM
08/15/23 05:36 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I’ve had good luck with Rare Parts.
https://www.rareparts.com/
Re: Who makes good ball joint/Tie rods [Re: Moparnut426] #3168163
08/15/23 08:15 PM
08/15/23 08:15 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Kasey
Loose or Sloppy? There's a difference.
Any ball type joint will loosen with even mile usage.
Re: Who makes good ball joint/Tie rods [Re: PhillyRag] #3168268
08/16/23 12:30 PM
08/16/23 12:30 PM
PhillyRag
Im a 22 year tech for chrysler, Not to sound like that guy, but I know a loose/sloppy ball joint when I see one. When the top of the wheel move in and out 1/4" its a junk part! i heard a rattle while cruising around town hitting side street intersection transitions, and I raised on my lift in the shop, and honestly was quite disgusted!
Re: Who makes good ball joint/Tie rods [Re: Moparnut426] #3168425
08/17/23 12:15 AM
08/17/23 12:15 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
PhillyRag
OK fine: you did your homework and sounds like they are bad.
Re: Who makes good ball joint/Tie rods [Re: 65pacecar] #3168875
08/18/23 04:30 PM
08/18/23 04:30 PM
these do look nice, ill try them monday... thanks !
Re: Who makes good ball joint/Tie rods [Re: Moparnut426] #3171042
08/28/23 11:46 AM
08/28/23 11:46 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
QA1
