Advise on changing mastercylinder
#316768
05/13/09 07:57 AM
05/13/09 07:57 AM
Posts: 309 S.e. lower MIch..
66droptop
S.e. lower MIch..
I am going to change my MC as it fails to hold the pedal and I must pull back the pedal.The 2nd owner put on a dual MC for 1967 for saftey in 1990 with the correct prop valve. So are there any tricks to make this easier as I will be doing this myself.When I disconnect the lines from the MC will the fluid leak out? Is it just taking the 4 nuts of from inside the car and the MC will come off?Do I need to disconnect the pedal or the rod hooked up the pedal.
Thanx.If more info is needed from me just ask.Thanx...
Having trouble DL pics.Will try again later.
Re: Advise on changing mastercylinder
[Re: 66droptop]
#316769
05/13/09 08:25 AM
05/13/09 08:25 AM
RapidRobert
disconnect the rod at the pedal, the 4 nuts and have a rag under the MC as it will drip some fluid when you undo the lines. then use your vise to take out the pushrod. Make sure your new M/C has the recess for the pushrod retainer & if a new rubber retainer is not included in the M/C box you can cut a piece of vac line.
[Re: 66droptop]
#316770
05/13/09 08:29 AM
05/13/09 08:29 AM
Posts: 7,506 Az
Crizila
Az
Even if the MC is bad, the pedal should return to the up position. Start by checking the pedal linkage to be sure it is not binding and that it returns all the way to the stop. A lot of MC's have been changed due to linkage problems.
Fastest 300
[Re: RapidRobert]
#316772
05/13/09 09:59 PM
05/13/09 09:59 PM
66droptop
S.e. lower MIch..
What about the spring and retainer that surround the rod?
Let me add that 90% of the time the pedal goes too the floor,9% if the pedal is firm,it will slowly sink to the floor.1% of the time the pedal will be hard.
Still having trouble DL pics.Will I lose fluid when I disconect the lines from the MC.......
[Re: 66droptop]
#316776
05/15/09 12:01 PM
05/15/09 12:01 PM
be sure to bench bleed teh new master cylinder first. this will save some aggrevation of doing it on the car. just a personal pref.
[Re: 66droptop]
#316780
05/17/09 06:52 PM
05/17/09 06:52 PM
Posts: 565 IA
landon1
IA
you should be able to pull it out with the assembly in the vise - in the instructions that came with mine it said to go ahead and disconnect all the linkage, etc. but then at the very end it said "if you have a chrysler car with a "pop-off" rod, leave linkage attached, loosen master cylinder, and pry it off the rod" - well, it maybe would have worked, but it was too late, so i got it pulled out using a vise as mentioned. install new rubber and gasket, and install - i got the rod to pop back in just by tightening the master cylinder to the firewall
'71 Satellite Sebring 440
[Re: 66droptop]
#316782
05/18/09 04:46 PM
05/18/09 04:46 PM
66droptop
S.e. lower MIch..
So I bled the back---fine.Now the frt,,,,,,I hooked my vaccum pump up to the pass.frt and very little fluid came out,then none.If I pump a few times and un hook the vaccum line you here the suction noise.On to the driver side,nothing,just creates a vaccum.I attached the pump to the brakeline before the hose which attaches to the cylinder and again very little fluid,then nothing..So it seems as though something is clogged or blocked from the MC to the prop valve,,,,,I guess.....Any ideas.
