Cooling a 440
#3167640
08/13/23 01:51 PM
08/13/23 01:51 PM
Posts: 6,404 Abilene, Texas
fastmark
Abilene, Texas
Had there been any problems cooling with one of the new aluminum water pump housings? Seems like I remember someone having trouble with these and flow problems. I’ve got a friend with a 499 cid BB and 440 source aluminum heads. It runs good but is right at 215. Now it is Texas in august and it’s well over 100 degrees outside.
Re: Cooling a 440
[Re: 71birdJ68]
#3167645
08/13/23 02:33 PM
08/13/23 02:33 PM
Posts: 20,788 A collage of whims
topside
A collage of whims
I had a 512" RB in a Duster a while back, Indy top end, pretty stout cam - PO had aluminum radiator, electric fan in front, no shroud, mech fan. Ran 200-210, would go up on a hot day in traffic. I ditched the electric fan, added a shroud, and swapped in a smaller water pump pulley. After that, 170-180 no matter what. Radiator was a 26" in the 22" opening. ATF cooler was separate from radiator.
Re: Cooling a 440
[Re: fastmark]
#3167652
08/13/23 03:35 PM
08/13/23 03:35 PM
Posts: 5,441 So Cal
Sinitro
So Cal
Had there been any problems cooling with one of the new aluminum water pump housings? Seems like I remember someone having trouble with these and glue problems. I’ve got a friend with a 499 cid BB and 440 source aluminum heads. It runs good but is right at 215. Now it is Texas in august and it’s well over 100 degrees outside. Some years ago... 440Source sold an aluminum water pump housing for the mopar big block and its internal coolant passages were too small greatly raising the coolant temperature..Later the tooling was revised... Just my $0.02...
Re: Cooling a 440
[Re: topside]
#3167663
08/13/23 04:02 PM
08/13/23 04:02 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My built 440 runs 12.5 domes etc on the street.I run an old MP aluminum water pump housing and pump.Runs 22 inch rad that was an OE 65 cbody with shroud.Has March underdrive pulleys and flex fan .That rad was damaged so i run a Champion 150 buck one from ebay.Been in 4 years.Never gets over 185 even when its 90s out.Seems many with electric fans etc have problems My kid ran the same setup in his 62 300 413 except he had the OE rad recored Never ran hot.Now his 360 built truck runs stock rad and the same setup.Also never gets hot.
Chrysler Firepower
Re: Cooling a 440
[Re: fastmark]
#3167737
08/13/23 10:24 PM
08/13/23 10:24 PM
Posts: 31,037 Oregon
AndyF
Had there been any problems cooling with one of the new aluminum water pump housings? Seems like I remember someone having trouble with these and glue problems. I’ve got a friend with a 499 cid BB and 440 source aluminum heads. It runs good but is right at 215. Now it is Texas in august and it’s well over 100 degrees outside. I've never had any cooling problems with any of my big blocks. The trick is to use proven combinations. Good radiator, shroud, clutch fan, belt driven pump with correct drive ratio, etc. Works every time.
Re: Cooling a 440
[Re: AndyF]
#3167806
08/14/23 11:04 AM
08/14/23 11:04 AM
Posts: 5,441 So Cal
Sinitro
So Cal
Had there been any problems cooling with one of the new aluminum water pump housings? Seems like I remember someone having trouble with these and glue problems. I’ve got a friend with a 499 cid BB and 440 source aluminum heads. It runs good but is right at 215. Now it is Texas in august and it’s well over 100 degrees outside. I've never had any cooling problems with any of my big blocks. The trick is to use proven combinations. Good radiator, shroud, clutch fan, belt driven pump with correct drive ratio, etc. Works every time. Totally agree with Andy... OE Mopar cooling systems can work just fine, but to add 1 point. Make sure to pressure flush the block to remove any old rust or crap inside the coolant passages.. Just my $0.02...
