Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES
[Re: 68LAR]
#3172211
09/01/23 10:54 PM
09/01/23 10:54 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
I think there is WAY WAY too much time trying to make the linkage "perfect" when that is not the cause of the chatter issue at all. I have seen some really misaligned linkage before work perfectly my car included. It's inside the bellhousing, the flywheel, the plate or the disc is the issue here. Get the flywheel surfaced by a good machine shop then make sure the disc is not warped with a dial indicator and some type of lathe and a dial indicator. As for solid motor mounts or motor plate if your stuff is balanced right there will be no severe vibration issues. Mine is smooth and I have gotten compliments on how smooth and quiet it is. Been running a motor plate and a poly transmission mount since I built my car about 30 years ago. The only clutch that chattered for me was a Ram sintered bronze 6 puck disc and a Hays race adjustable plate. You have to start measuring from the crank flange then the flywheel to make sure you don't stack tolerances. Something is warped or bent somewhere. Gus I agree with all this except the tranny mount. None of what had been mentioned here will cause chatter. Dirty flywheel, pressure plate or type of disc material could and will cause chatter. One end of the z bar holds the nylon bearings in place. The other side slides free to compensate for engine torq. This doesn’t have to be perfect. That’s what the nylon bearings and the ball fittings compensate for. The other stuff mentioned will certainly help with drivability, but not cause chatter. Gus and I have been doing this for many years. Lots of experience between us. Just sayin’. thanks for the input from both Please read the previous posts by me on this issue. Page 1 and 2 are good for a start When the alignment is off to the point it is grooving the pivot studs it needs to be corrected. Yes I could slap it together as the previous shops did and shove it out the door but my conscience won't allow it. I would love to find the root cause of the alignment issue but the owners budget doesn't allow it. if it were not for the lateral misalignment shimming the L mount would get by. But then we'll also have a head pipe too close to the torsion bar. What I'm doing is not correct but easily reversible when his budget allows and will alleviate the alignment issue for now. At 69 YO I've been around the block a time or two. Couple that with 25 years of engineering, 25 years of owning a classic car resto /repair shop and 56 years of busting knuckles. I am not trying to be rude or offensive but rather fill in some of the information you must have not had. Thanks again fo r your input and trying to help I will keep all posted
[Re: TJP]
#3172467
09/02/23 10:35 PM
09/02/23 10:35 PM
TJP
Omaha Ne
I made a dummy shaft out of 1" plastic rod boring both ends to fit the OD of the pivot balls. This allowed me to install an the mounts and shaft much easier and better see the misalignment. After trying several different things to no avail, there was a new BH mount in the parts box that came in with the car. I installed it with the dummy shaft. I proceeded to cut one of the braces closest to the pivot stud on the back of the mount. Removing a bit of material from the brace allowed me to tweak the Pivot position enough to where the dummy shaft slips all the way back and forth with no binding. I'll weld it up tomorrow and continue with the remaining assembly. What a PITA. Thanks again to all for the support and I am praying that the issue is history. Will follow up once running and the clutch is tested
[Re: TJP]
#3172620
09/03/23 04:32 PM
09/03/23 04:32 PM
Posts: 43,523 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I made a dummy shaft out of 1" plastic rod boring both ends to fit the OD of the pivot balls. This allowed me to install an the mounts and shaft much easier and better see the misalignment. After trying several different things to no avail, there was a new BH mount in the parts box that came in with the car. I installed it with the dummy shaft. I proceeded to cut one of the braces closest to the pivot stud on the back of the mount. Removing a bit of material from the brace allowed me to tweak the Pivot position enough to where the dummy shaft slips all the way back and forth with no binding. I'll weld it up tomorrow and continue with the remaining assembly. What a PITA. Thanks again to all for the support and I am praying that the issue is history. Will follow up once running and the clutch is tested Sounds like a smart way to figure it out! Hope it works this time, keep us posted!
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3172698
09/03/23 10:00 PM
09/03/23 10:00 PM
TJP
Omaha Ne
I made a dummy shaft out of 1" plastic rod boring both ends to fit the OD of the pivot balls. This allowed me to install an the mounts and shaft much easier and better see the misalignment. After trying several different things to no avail, there was a new BH mount in the parts box that came in with the car. I installed it with the dummy shaft. I proceeded to cut one of the braces closest to the pivot stud on the back of the mount. Removing a bit of material from the brace allowed me to tweak the Pivot position enough to where the dummy shaft slips all the way back and forth with no binding. I'll weld it up tomorrow and continue with the remaining assembly. What a PITA. Thanks again to all for the support and I am praying that the issue is history. Will follow up once running and the clutch is tested Sounds like a smart way to figure it out! Hope it works this time, keep us posted! After welding and painting the Z bar went right in and appears to be pretty well centered The hack job on the exhaust was another issue. Whomever thought of slotted on size fits all flanges should be castrated so they can't pass on their moronic thinking. Couple those with a 1/8" or so flanged lip for sealing, and a larger ID pipe than the manifold and one has a real challenge trying to line up the pipes and gaskets to the manifold. Finally used two different sized OD sleeves to slip over each other centering the manifold and pipe. This of course required a different gasket which had to be sourced and the hole spacing modified. I'm about ready to start drinking again
[Re: moparx]
#3172981
09/04/23 09:51 PM
09/04/23 09:51 PM
TJP
Omaha Ne
every time my old man would see me, he would look and say : "he,he,he.........i got hair and you don't.........he, he, he........." but then, he didn't work on cars [he just broke them ] and i do.............. still got any hair on the top of your head ? i don't........... LOL yes as a matter of fact I do have a full head of hair although lately I've seen more in the shower👀😂 However, I finally got to do a test drive today and all was NORMAL, WOW!!! 💥🚀🧨🎉🎇🎯🤸♂️🤸♂️🤸♂️imagine that. My prayers were heard 🙏🙏 I do want to thank all that contributed and offered help while reading my findings. The ROOT cause? Don't know But I'm going to guess that the bolded portion of RudeRunners post below was the culprit. Before removing the flywheel, I'd like to check the runout of the face. Indicator base on the block, needle on the face. That dark spot looks about 180 from where the grinding marks are visible. Like the flywheel wobbles. Be a good idea to check that on the new flywheel too. Who knows if the crank flange is bent. Unlikely but not impossible. Bellhousing concentricty is important too. There may be multiple little things adding up. Thanks again to ALL
Re: RESOLVED!!, SEVERE Clutch Chatter from a stop.
[Re: moparx]
#3173187
09/05/23 06:05 PM
09/05/23 06:05 PM
Posts: 5,783 ohio
ruderunner
ohio
Bubba has nothing on farmers, I've fixed more than my share if their fixes.
Angry white pureblood male
[Re: ruderunner]
#3173226
09/05/23 09:53 PM
09/05/23 09:53 PM
TJP
Omaha Ne
Bubba has nothing on farmers, I've fixed more than my share if their fixes. he does have a liking for their daughters said just like them cow and pigs the bigger the better ( bring more at auction and BEER) LMAO You BTW pretty much nailed it with you earlier post several days back so and
[Re: TJP]
#3173228
09/05/23 10:14 PM
09/05/23 10:14 PM
Rhinodart
Rhinotruck
Rhinotruck
Freaking awesome! I almost want to put one of my 4-speed cars together one of these days...LOL..
A-Body's RULE!
[Re: Rhinodart]
#3173299
09/06/23 10:36 AM
09/06/23 10:36 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I'm amazed at the stack up of small issues that led to the huge one you dealt with and conquered. I hope the car owner is singing your praises loudly and not whining about how much it cost only.
Carl Kessel
[Re: TJP]
#3173329
09/06/23 12:36 PM
09/06/23 12:36 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I made a dummy shaft out of 1" plastic rod boring both ends to fit the OD of the pivot balls. This allowed me to install an the mounts and shaft much easier and better see the misalignment. After trying several different things to no avail, there was a new BH mount in the parts box that came in with the car. I installed it with the dummy shaft. I proceeded to cut one of the braces closest to the pivot stud on the back of the mount. Removing a bit of material from the brace allowed me to tweak the Pivot position enough to where the dummy shaft slips all the way back and forth with no binding. I'll weld it up tomorrow and continue with the remaining assembly. What a PITA. Thanks again to all for the support and I am praying that the issue is history. Will follow up once running and the clutch is tested Sounds like a smart way to figure it out! Hope it works this time, keep us posted! After welding and painting the Z bar went right in and appears to be pretty well centered The hack job on the exhaust was another issue. Whomever thought of slotted on size fits all flanges should be castrated so they can't pass on their moronic thinking. Couple those with a 1/8" or so flanged lip for sealing, and a larger ID pipe than the manifold and one has a real challenge trying to line up the pipes and gaskets to the manifold. Finally used two different sized OD sleeves to slip over each other centering the manifold and pipe. This of course required a different gasket which had to be sourced and the hole spacing modified. I'm about ready to start drinking again Did you snap a picture of the modified bracket ? Good work getting it back to working properly.
[Re: CKessel]
#3173398
09/06/23 04:19 PM
09/06/23 04:19 PM
TJP
Omaha Ne
I'm amazed at the stack up of small issues that led to the huge one you dealt with and conquered. I hope the car owner is singing your praises loudly and not whining about how much it cost only. he's definitely happy but whimpering as usual. By the log sheet I have racked up over 100 hours in this mess. That time includes the analyzing, research etc. I'll lose my backside but it's done, as right as the budget would tolerate, and likely the last one for awhile. If I hit him full bore with parts and the little that's left to do it'd be close to 15K. Hard to swallow for a chattering clutch problem. So, what does one do? take what they can afford and eat the rest. BTW I'm going on a diet LOL 🤣😂
[Re: Rhinodart]
#3173399
09/06/23 04:20 PM
09/06/23 04:20 PM
TJP
Omaha Ne
Freaking awesome! I almost want to put one of my 4-speed cars together one of these days...LOL.. 4 speeds are FUN!!!!!
[Re: TJP]
#3173417
09/06/23 05:34 PM
09/06/23 05:34 PM
Posts: 6,233 nowhere
Sniper
nowhere
This is why I learned to do it myself. I won't begrudge a man what he's earned, but conversely I couldn't afford to pay the man with the knowledge either. So I "invested" in learning how to do it myself. Sometimes that was more expensive than letting the man do it, lol. Something I learned after the fact.
[Re: CKessel]
#3173447
09/06/23 07:44 PM
09/06/23 07:44 PM
Posts: 5,783 ohio
ruderunner
ohio
I'm amazed at the stack up of small issues that led to the huge one you dealt with and conquered. I hope the car owner is singing your praises loudly and not whining about how much it cost only. In this case, surrender there were a few small things but, after seeing the flywheel pictures I'd say that was 95 percent of the problem. A thousandth or so at the flange becomes pretty significant at the pressure plate bolts. I didn't expect rest buildup but the possibility that the crank might have been dropped at some point.
[Re: Sniper]
#3173485
09/06/23 10:11 PM
09/06/23 10:11 PM
Posts: 10,201 Someplace you aren't
SomeCarGuy
This is why I learned to do it myself. I won't begrudge a man what he's earned, but conversely I couldn't afford to pay the man with the knowledge either. So I "invested" in learning how to do it myself. Sometimes that was more expensive than letting the man do it, lol. Something I learned after the fact. Yep no way I’d have been able to stay in the hobby paying others for most of this stuff. I’ve come to accept I can afford to redo it if I screw it up, maybe buy parts I didn’t need to to begin with, etc and still be ahead of paying a shop. Tools I don’t even flinch at buying and my hobby has always led to me having tools I use in the house. I don’t think I’d want to be doing this for a hundred an hour anyway.
I want my fair share
