Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES
[Re: Sniper]
#3170703
08/26/23 10:04 PM
08/26/23 10:04 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
Well, the Mopar pins are at .500" too so your screwed which ever way you go. Correct except for Robb Robb mc, LINKY and Brewers pins which are sized correctly. My error was twofold, 1. I did not think about the BH side of the dowel which also has to be reduced. That error pushed the offset portion into the block enough to seize it. but fortunately only on the lower accessible pin. The never seize may have helped 2. Again not thinking things through I installed the pins with the offset 180 degrees out of where they should have been. again. I am happy to say the new pins are in and the BH is +/- .0035 which is within spec. Amazing how easy things can be when you think things through Will try for the clutch etc tomorrow
[Re: TJP]
#3170733
08/27/23 12:29 AM
08/27/23 12:29 AM
Posts: 10,707 North Dakota
6PakBee
North Dakota
I'm confused. +/- .0035". Is that 0.0035" TIR or 0.007" TIR?
[Re: TJP]
#3170923
08/27/23 09:59 PM
08/27/23 09:59 PM
TJP
Omaha Ne
[Re: TJP]
#3170950
08/28/23 12:17 AM
08/28/23 12:17 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
Sucks, but I really think all the new stuff was only way to get to a resolution here.
I want my fair share
[Re: TJP]
#3171005
08/28/23 09:57 AM
08/28/23 09:57 AM
6PakBee
North Dakota
I'm confused. +/- .0035". Is that 0.0035" TIR or 0.007" TIR? .007 TIR. previously at .022 TIR Thanks for the clarification.
[Re: Sniper]
#3171269
08/29/23 09:33 AM
08/29/23 09:33 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Well, the Mopar pins are at .500" too so your screwed which ever way you go. I know you love a good fight , even when you are wrong ... the mopar pins are NOT .500 ... the aftermarket has been selling the wrong ones forever .
[Re: JohnRR]
#3171329
08/29/23 12:33 PM
08/29/23 12:33 PM
TJP
Omaha Ne
Well, the Mopar pins are at .500" too so your screwed which ever way you go. I know you love a good fight , even when you are wrong ... the mopar pins are NOT .500 ... the aftermarket has been selling the wrong ones forever . They are .496"
[Re: TJP]
#3171495
08/29/23 09:17 PM
08/29/23 09:17 PM
Posts: 6,233 nowhere
Sniper
nowhere
https://www.summitracing.com/parts/mop-1122532Brand: Mopar Replacement Manufacturer's Part Number: 1122532 Part Type: Bellhousing Dowel Pins Product Line: Mopar Replacement Transmission Housing Dowel Pins Summit Racing Part Number: MOP-1122532 Dowel Pin Offset (in.): None Dowel Pin Length (in.): 0.750 in. Dowel Pin Diameter (in.):0.500 in.Quantity: Sold individually.
[Re: topside]
#3171523
08/29/23 11:16 PM
08/29/23 11:16 PM
TJP
Omaha Ne
Regardless of what Summit says, it's been documented here in prior threads that .496 is the correct size. Sniper, Directly from Brewer's site
[Re: Sniper]
#3171603
08/30/23 11:50 AM
08/30/23 11:50 AM
JohnRR
U.S.S.A.
https://www.summitracing.com/parts/mop-1122532Brand: Mopar Replacement Manufacturer's Part Number: 1122532 Part Type: Bellhousing Dowel Pins Product Line: Mopar Replacement Transmission Housing Dowel Pins Summit Racing Part Number: MOP-1122532 Dowel Pin Offset (in.): None Dowel Pin Length (in.): 0.750 in. Dowel Pin Diameter (in.):0.500 in.Quantity: Sold individually. still WRONG ....
[Re: SomeCarGuy]
#3171705
08/30/23 04:40 PM
08/30/23 04:40 PM
TJP
Omaha Ne
Clutch and trans are installed, Z bar still not straight across or level. The motor mount studs on the L and bolt on the R are all the way down on both sides. I have discovered the motor is not sitting level (leaning to the L (drivers side). The mounts and K frame appear correct. If I raise the L side and level the motor it helps a lot with the Z bar leveling out but I am puzzled as to why it's sitting so low on both sides and how to raise the L side other than shimming it up. Normally one can "rock" the motor to level it on the mounts but in this case they are both at the bottom so the rocking idea's not going to work. Maybe it's a BB dart thing ? has anyone run into this before? I can 1. Shim the motor till it's level which appears to be the root cause. 2. Move one of the Z bar ball studs, but I really prefer to find a correct the root cause A couple of pic's of the K frame and Mounts that are in the car. Note the R mount has limited adjustment with one long bolt while the L has a lot with the slotted holes in the k frame that the studs go through Any suggestions/ comments/ experiences? Thanks
[Re: JohnRR]
#3171727
08/30/23 06:19 PM
08/30/23 06:19 PM
Sniper
nowhere
https://www.summitracing.com/parts/mop-1122532Brand: Mopar Replacement Manufacturer's Part Number: 1122532 Part Type: Bellhousing Dowel Pins Product Line: Mopar Replacement Transmission Housing Dowel Pins Summit Racing Part Number: MOP-1122532 Dowel Pin Offset (in.): None Dowel Pin Length (in.): 0.750 in. Dowel Pin Diameter (in.):0.500 in.Quantity: Sold individually. still WRONG .... Just telling you how they are listed, won't be the first time they sold something that didn't fit and I am not going to buy a set to see if the listing is wrong.
