Any Tricks on Polyacrylic for wood? #3167274
08/11/23 02:28 PM
08/11/23 02:28 PM
IMGTX Offline OP
IMGTX  Offline OP
Wife and I are remodeling the kitchen and for the time being we decided on putting in a butcher block countertop.
We wanted to stain and put polyurethane on it for color and ease of maintenance.
The stain was a bust. We tried the water based stain and it was horrible so we sanded it off.
From there we put the polyacrylic on the sanded wood.
No matter how I try to put it on it will either have dry patches, bubbles, or brush strokes.
I have tried slow brush strokes, fast brush strokes, thick and thin coats, I even wet the brush with water before one coat. I brush in the direction of the wood grain. I tried only in a left to right direction and also in a back and forth direction.
After sanding I wipe and even used a tack cloth.
i am using a Purty brush and only stirring the poly, no shaking.
Am I missing something or is this as good as it gets?
Re: Any Tricks on Polyacrylic for wood? [Re: IMGTX] #3167277
08/11/23 02:37 PM
08/11/23 02:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Never touched the stuff myself. Try a cloth going in circles instead?
https://www.ehow.com/info_8780992_fastest-polycrylic-prevent-air-bubbles.html
Re: Any Tricks on Polyacrylic for wood? [Re: IMGTX] #3167280
08/11/23 02:48 PM
08/11/23 02:48 PM
PA
70Duster Offline
70Duster  Offline
PA
Not sure what's wrong. I always brushed it on heavy and fine steel wool between coats. Finish was like glass when done.
Re: Any Tricks on Polyacrylic for wood? [Re: 70Duster] #3167285
08/11/23 03:08 PM
08/11/23 03:08 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
So I will assume the Butcher block is maple - using an all in one water based polyurethane stains is going to be problematic with maple as it does not absorb color equally across the grain especially water based. I like to use a sanding sealer first then an oil based stain applied and buffed off after it sets a few minutes with a cotton rag - then after that has dried for a few days you can apply a top coat of either water based Polyurethane or my preference oil based polyurethane. If these are "food" service areas then I would use a food grade mineral oil only on the bare wood and just touch it up occasionally.
Re: Any Tricks on Polyacrylic for wood? [Re: IMGTX] #3167289
08/11/23 03:17 PM
08/11/23 03:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Google 'butcher block care' - they need to be conditioned.
Adding a poly finish is not the way.
Re: Any Tricks on Polyacrylic for wood? [Re: IMGTX] #3167291
08/11/23 03:22 PM
08/11/23 03:22 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
I've used a torch (heat gun would be better) to smooth polyurethane (and get bubbles out).
I've never used polyacrylic before, but the above may work for that product as well. You'd obviously want to test somewhere other than your counter top.
You are sanding between coats, right?
Re: Any Tricks on Polyacrylic for wood? [Re: Fat_Mike] #3167304
08/11/23 04:38 PM
08/11/23 04:38 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
This guy has lots of tips for using acrylics on wood.
youtube.com/@BlacktailStudio/videos
Re: Any Tricks on Polyacrylic for wood? [Re: John Brown] #3167397
08/11/23 10:22 PM
08/11/23 10:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'd be concerned with scratching after being done shruggy
