E an B body 2 pc. Rotors for the single piston #3166562
08/08/23 02:11 PM
08/08/23 02:11 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What years did they have the 2 pc rotors for the single piston calipers?
Are there any part numbers of date codes on these?
What is the minimum thickness that can be turned down to?
Re: E an B body 2 pc. Rotors for the single piston [Re: ragtop] #3166794
08/09/23 12:26 PM
08/09/23 12:26 PM
VA
dragon slayer Offline
VA
70-72 B&E used the KH set up. The disc is 10.98"dia, 1"thick, .94 is the minimum thickness. The hub/disc is 4.84" tall.
Re: E an B body 2 pc. Rotors for the single piston [Re: dragon slayer] #3166967
08/09/23 11:51 PM
08/09/23 11:51 PM
IMGTX Offline
IMGTX  Offline
I hate to hijack this tread but does anyone make a replacement disk or complete 2 piece rotors for restoration purposes?
I have a pair of disks that are worn out but kept them in case I could get replacement rotors to install on the hubs.
Re: E an B body 2 pc. Rotors for the single piston [Re: ragtop] #3167126
08/10/23 05:01 PM
08/10/23 05:01 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
If push comes to shove, you can use the later 73 and up 1 piece rotors with the original calipers. You will need a bearing spacer from Dr. Diff though, due to the larger inner bearing of the later rotors.
Re: E an B body 2 pc. Rotors for the single piston [Re: JDMopar] #3167174
08/10/23 09:37 PM
08/10/23 09:37 PM
VA
VA
One piece rotors were available.
Re: E an B body 2 pc. Rotors for the single piston [Re: dragon slayer] #3168174
08/15/23 08:58 PM
08/15/23 08:58 PM
JDMopar Offline
JDMopar  Offline
Maybe as aftermarket replacements, but not from the factory. If they're going on a car that will be driven, the one piece are way better because the 2 piece ones would warp to hell and back with hard use or the ding dongs at tire stores with air guns.
Re: E an B body 2 pc. Rotors for the single piston [Re: JDMopar] #3168237
08/16/23 09:40 AM
08/16/23 09:40 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I have a pair that may be in-spec if anyone is interested.
