Did I kill my Optima?
#3166765
08/09/23 10:29 AM
08/09/23 10:29 AM
Posts: 2,045 MD
RTSE4ME
MD
I have a Optima yellow top 5+ years old. I left the trunk open for a few days and drained it. Had it on a Battery Tender for a week and will only charge to 11.6 volts. Also tried charging it through a second battery...no joy. Is this a paperweight now? These are really expensive now.....
Re: Did I kill my Optima?
[Re: RTSE4ME]
#3166770
08/09/23 10:44 AM
08/09/23 10:44 AM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You cannot charge an Optima like a normal battery. Battery tenders will NOT charge them. I found the best way to charge one it to put it in series with a regular battery on a 30 amp charge for a few hours, then switch it to 10 amp. There are specific types of chargers for Optima type batteries, but if you don't have one my method is preferred... Edit: I just read your post again, sounds like you tried it through another battery already, may have to charge it longer. One of mine sat for 3 years and I brought it back to life that way.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3166773
08/09/23 10:49 AM
08/09/23 10:49 AM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
You cannot charge an Optima like a normal battery. Battery tenders will NOT charge them. I found the best way to charge one it to put it in series with a regular battery on a 30 amp charge for a few hours, then switch it to 10 amp. There are specific types of chargers for Optima type batteries, but if you don't have one my method is preferred... Edit: I just read your post again, sounds like you tried it through another battery already, may have to charge it longer. One of mine sat for 3 years and I brought it back to life that way. I am pretty sure you meant to say parallel not series.
[Re: topside]
#3166805
08/09/23 01:10 PM
08/09/23 01:10 PM
Posts: 10,214 Someplace you aren't
SomeCarGuy
I revived an optima I left my fm convertor on and drained. It came back with a second battery.
I have the Autozone brand agm capable charger. It works on my dead agm to bring it back up, but that battery is old and won’t stay up though. Haven’t had to use it on my odyssey yet.
I want my fair share
[Re: GomangoCuda]
#3166962
08/09/23 11:07 PM
08/09/23 11:07 PM
Rhinodart
Rhinotruck
Rhinotruck
You cannot charge an Optima like a normal battery. Battery tenders will NOT charge them. I found the best way to charge one it to put it in series with a regular battery on a 30 amp charge for a few hours, then switch it to 10 amp. There are specific types of chargers for Optima type batteries, but if you don't have one my method is preferred... Edit: I just read your post again, sounds like you tried it through another battery already, may have to charge it longer. One of mine sat for 3 years and I brought it back to life that way. I am pretty sure you meant to say parallel not series. Yep, try series anyway...LOL..
A-Body's RULE!
[Re: Rhinodart]
#3167005
08/10/23 08:57 AM
08/10/23 08:57 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My son has one in his truck Its at least 10 years old and been dead many times.He charged it and its still working like new.This is probally at least 5 or 6 times it has been stone dead and recharged and it works.
Chrysler Firepower
[Re: therocks]
#3167102
08/10/23 03:35 PM
08/10/23 03:35 PM
Posts: 16,483 On the run…
BloFish
On the run…
I bought an Optima charger for this very reason.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3167127
08/10/23 05:02 PM
08/10/23 05:02 PM
Posts: 2,045 MD
RTSE4ME
MD
[Re: RTSE4ME]
#3167576
08/13/23 08:39 AM
08/13/23 08:39 AM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Grab a NOCO GENIUS10 charger. https://no.co/genius10They are approx $100. Home Depot sells them, Battery Warehouse, Amazon... Get best reviews and ratings. I love mine. Have the 10 and the 5. GENIUS10 6V/12V 10-Amp Smart Battery Charger 10-Amp Battery Charger, Battery Maintainer, and Battery Desulfator Introducing the all-new GENIUS10, one of our most powerful, highest-performing, energy-efficient, and compact chargers yet. The GENIUS10 is a 6-volt and 12-volt battery charger, battery maintainer, and battery desulfator rated at 10-amp for lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries. Meet the GENIUS10 - Similar to our G7200, just better. It's 17% smaller and delivers 115% more power. And it's simpler and easier to use than ever before. Do more with Genius - Designed for 6-volt and 12-volt lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries. Enjoy precision charging - An integrated thermal sensor detects the ambient temperature and alters the charge to eliminate over-charging in hot climates and under-charging in cold climates. Charge dead batteries - Charges dead batteries as low as 1-volt. Or use the all-new Force Mode that allows you to take control and manually begin charging dead batteries down to zero volts. Simple to set up and use - Plug-in, connect to the battery, select a charge mode, and start charging your battery. A fully-automatic, worry-free battery charger for year-round use. Restore your battery - Detects sulfation and acid stratification and restores lost performance for stronger engine starts and extended battery life. Compatible with all types of vehicles - Charge and maintain cars, motorcycles, lawnmowers, ATVs, tractors, trucks, SUVs, boats, classic cars, hot rods, and more - you name it.
[Re: RTSE4ME]
#3167584
08/13/23 09:11 AM
08/13/23 09:11 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have a Optima yellow top 5+ years old. I left the trunk open for a few days and drained it. Had it on a Battery Tender for a week and will only charge to 11.6 volts. Also tried charging it through a second battery...no joy. Is this a paperweight now? These are really expensive now..... A battery tender is worthless as a charger, they don't put enough current in to charge a dead battery up. They will charge a slightly discharged battery but they are meant to maintain a battery that doesn't see much use. Now that you have it at 11.6 volts go buy a charger with an AGM setting and let it charge on a 6-12 amp charge. The optima brand chargers are great, I have the 4 amp smaller one and it does very good despite the low output of 4 amps. Even if your optima doesn't come back an AGM charger is good to have if your purchase another AGM battery regardless of brand. Most chargers won't kick on if the battery is below 10 volts, that is the reasoning for hooking another battery in parallel. This would apply to any battery not just an optima.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3167631
08/13/23 01:21 PM
08/13/23 01:21 PM
Posts: 6,263 nowhere
Sniper
nowhere
There is a reason for that, it's called thermal runaway. A possibility when trying to charge a deeply discharged battery not designed for deep discharge. Now before someone pipes up with how they've done it for years with no problems, yeah I know I've done it too, but you aren't going to get sued if it happens and someone's house and car burns down. So the charger manufacturers but in limitations to mitigate that risk. What you do to defeat that is up to you.
[Re: RTSE4ME]
#3167642
08/13/23 02:16 PM
08/13/23 02:16 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Don't ask me why... An Optima battery needs a special charging cycle.. Even though some smart chargers state they can handle AGM batteries.. I have Optima batteries in all (4) of my cars, typically I get 6-8 years, sometimes up to 10 years. If an Optima battery is low, I bought an Optima charger, and it works great to bring it back up. 1 of my Optimas'(yellow top) I accidently left a small hood light ON and it ran the battery down, hooked up the Optima charger and the battery recovered just fine.. Just my $0.02...
[Re: Sniper]
#3167644
08/13/23 02:24 PM
08/13/23 02:24 PM
Posts: 21,514 N.E. OHIO, USA
A12
N.E. OHIO, USA
There is a reason for that, it's called thermal runaway. A possibility when trying to charge a deeply discharged battery not designed for deep discharge. Now before someone pipes up with how they've done it for years with no problems, yeah I know I've done it too, but you aren't going to get sued if it happens and someone's house and car burns down. So the charger manufacturers but in limitations to mitigate that risk. What you do to defeat that is up to you. Yeah just asked Jim about that. Sorry Jim to bring up bad memories.
[Re: RTSE4ME]
#3167692
08/13/23 06:27 PM
08/13/23 06:27 PM
BloFish
On the run…
Just buy it and don’t look back. One thing less to worry about.
