i have some 69 imperial parts sitting here that need to go to a good home. i'll never use them in my lifetime, so is there any interest in them ?
have two inside door pulls that are in very nice condition, not "show chrome", but very presentable for a driver. the hinges are tight, the emblems are in very good condition, but the wood grain needs a touch of glue at the extreme edges.
the vacuum trunk latch works perfectly, as does the enclosed release button. to operate correctly, a reserve canister needs to be in use. the vacuum pod holds vacuum as it should using a mitty-vac tool.
the key surround works perfectly, and the spring snaps the cover shut and holds it there as it should.
the lock solenoids work as they should, in the lock and unlock actions when 12 volts are supplied.
a BIG TIA to those that know more about these items than i do...........
