Re: 68 GTX Factory AC. Need help!
[Re: mercman1]
#3164850
08/01/23 02:09 PM
08/01/23 02:09 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is the blower intermittent in all speeds? There is a blower motor resistor attached to the rear side of the A/C box. Could also be the switch.
[Re: John_Kunkel]
#3165546
08/04/23 11:36 AM
08/04/23 11:36 AM
Posts: 2,922 Calgary, Alberta Canada
a12rag
I have a 70 Sport Satellite with AC . . . I get similar situation . . . where the blower motor gets nothing from the switch - I did find a NOS switch (spendy !! $$$), as the original was very worn - the blower motor pulls a fair bit of current. Didn't change things, sometime would work, sometimes not. When I restored the car, I made sure ALL connections at bulkhead were clean and tight ! . . . wondering if it is the "vacuum switch"- which controls where you get the airflow (defrost, heat, ac vents) - as the blower motor circuit does go through the 'Max AC" position . . . when I put 12volt direct to blower motor - full output for sure. Time to upgrade and build a relay panel to be controlled by the OE switch, and then the relays take the current draw . . .
Oh, and have to make sure if you change out the vacuum switch unit - you get the one for your year !! It has been superseded over the years, and while it "looks" the same, the functionality was changed over the years . . .
Cheers,
[Re: a12rag]
#3165698
08/05/23 05:46 AM
08/05/23 05:46 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
The resistor can be seen by looking above the gas pedal and it is in the air box. Mine had melted down the wires going into it. Had to get a used one. You can rewrite it for a relay. 1wildrt posted details on fbbo on doing that. You can boost up the fan speed by doing that as the full 12 volts isn’t delivered even on high by the factory setup.
I want my fair share
[Re: SomeCarGuy]
#3165747
08/05/23 02:13 PM
08/05/23 02:13 PM
John_Kunkel
Rio Linda, CA
You can boost up the fan speed by doing that as the full 12 volts isn’t delivered even on high by the factory setup. Did that on my '70 Charger and the motor got really hot.
[Re: John_Kunkel]
#3166116
08/06/23 10:12 PM
08/06/23 10:12 PM
Posts: 710 St Louis, MO 63026
convx4
St Louis, MO 63026
You can boost up the fan speed by doing that as the full 12 volts isn’t delivered even on high by the factory setup. Did that on my '70 Charger and the motor got really hot. The safe way of boosting the high fan speed would be with the use of a high speed relay in the circuit. This would help reduce the risk of melting the blower wiring.
[Re: convx4]
#3166223
08/07/23 11:58 AM
08/07/23 11:58 AM
John_Kunkel
Rio Linda, CA
The issue is whether or not the motor will survive running on straight battery voltage. There have been other instances noted where a motor won't survive at full voltage.
[Re: John_Kunkel]
#3166283
08/07/23 02:31 PM
08/07/23 02:31 PM
Posts: 21,541 N.E. OHIO, USA
A12
N.E. OHIO, USA
Is the blower intermittent in all speeds? There is a blower motor resistor attached to the rear side of the A/C box. Could also be the switch. Thought this was in the A/C air flow duct work to cool it?
[Re: A12]
#3166469
08/08/23 10:04 AM
08/08/23 10:04 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
The problem with increasing fan speed is that the flow increase directly with speed but the power increases as the cube. As an example, if you double the speed of a fan, the flow doubles. The power required is eight times the original. This is all from the fan affinity laws. That's why a modest increase in speed results in significant power increases with the resulting motor heating.
[Re: 6PakBee]
#3166474
08/08/23 10:32 AM
08/08/23 10:32 AM
SomeCarGuy
My 77 truck with factory ac had a switch wired in for the fan when I got it. The ac worked for about ten miles the day I bought it, enough to run out the charge they out in at the lot. I had to manually turn the fan on every time I got in and the motor never slowed down or caused any trouble in the years I owned it. I don’t doubt it got hot, it just didn’t didn’t matter.
[Re: A12]
#3166530
08/08/23 12:43 PM
08/08/23 12:43 PM
John_Kunkel
Rio Linda, CA
Is the blower intermittent in all speeds? There is a blower motor resistor attached to the rear side of the A/C box. Could also be the switch. Thought this was in the A/C air flow duct work to cool it? The resistor coils are in the air flow, the connector terminals in my pic above are exposed outside the box.
