Quality Fuel Vapor Separator #3163406
07/26/23 02:56 PM
07/26/23 02:56 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
As the title implies: looking for a quality fuel vapor separator for my 68 Hemi car. I remember a discussion a few years ago regarding the repop's at that time and the consensus was that they were not designed correctly and would lead to driveability issues. Have those issues been solved, or are there no good options?
Re: Quality Fuel Vapor Separator [Re: 2JcodeChargers] #3163693
07/27/23 05:27 PM
07/27/23 05:27 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Buy one from 521 Restorations. They have the correct ones.
https://521restorations.com
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Quality Fuel Vapor Separator [Re: 70sixpkrt] #3163706
07/27/23 06:12 PM
07/27/23 06:12 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I got mine from mopar mall. The small nipple is the correct size of .060 and the huge one is the problem child.
I want my fair share
Re: Quality Fuel Vapor Separator [Re: SomeCarGuy] #3163746
07/27/23 09:11 PM
07/27/23 09:11 PM
70sixpkrt Offline
70sixpkrt  Offline
4-speed
3:54 Dana
Re: Quality Fuel Vapor Separator [Re: 2JcodeChargers] #3163976
07/28/23 06:31 PM
07/28/23 06:31 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
As far as I know Frank Baldson is the only one that has them with a screen in it. But it doesn't have the correct orfice, so I just made a small plug and drilled the hole in it and slid it in the hose for the return line.
Re: Quality Fuel Vapor Separator [Re: 70sixpkrt] #3164473
07/31/23 11:04 AM
07/31/23 11:04 AM
Long Island, NY
70plymA34 Online content
70plymA34  Online Content
Long Island, NY
this is all great information. What is the driveability problems with using the repros?
Super Commando
Re: Quality Fuel Vapor Separator [Re: 70plymA34] #3164984
08/01/23 11:33 PM
08/01/23 11:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Most didn't have a screen and as such not filter what so ever. With out the little orifice being .060 the fuel pressure can be to low.
Re: Quality Fuel Vapor Separator [Re: 70plymA34] #3165014
08/02/23 08:25 AM
08/02/23 08:25 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
In my experience.
Unless you consistantly hammer on it.
You may never know if it's wrong or right.
Normal around town drives. Odds are you'll never detect an issue
Re: Quality Fuel Vapor Separator [Re: 71birdJ68] #3165437
08/03/23 08:54 PM
08/03/23 08:54 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I went through pressure loss problems when I was setting up my 68 Hemi Runner. Even with the factory .060" return I had about 1.5-2 psi loss from when the line was clamped closed. I soldered the opening and with a little trial and error, I ended up with a .035"ish opening and with just a slight loss in pressure but still allowing enough flow to keep the function. I have had no issues in the past ten years or so with vapor lock but I also used a couple short pieces of insulation around the fuel line where it has close proximity to the exhaust pipe.
This may or may not work for you but keep in mind that you might need to make small modifications to enhance the OEM function.
68jim
