Cam prices
#3164800
08/01/23 11:26 AM
08/01/23 11:26 AM
Posts: 14,509 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s no secret to anyone who’s bought, or shopped for, a cam lately that the prices have steadily gone up.
I just got an order confirmation from Comp yesterday on a flat tappet cam for a BBM. My cost has gone up significantly........ in one big jump.
I checked on Summits site, and they had gone up there as well.
I checked several part numbers, for a variety of engine makes. All have taken a big jump.
The roller cam prices from several suppliers were pretty close to each other, but there was a noticeable difference in price on the “racier” flat tappet grinds.
It’ll be interesting to see if the flat tappet prices get closer from brand to brand over the next weeks/months. I’m wondering if the “lower” priced brands just haven’t rec’d a fresh batch of cores yet, and adjusted their prices accordingly.
Time will tell.
The current pricing for a custom FT cam that’s plasma nitrided is very close to a roller now.
Re: Cam prices
[Re: fast68plymouth]
#3164803
08/01/23 11:37 AM
08/01/23 11:37 AM
Posts: 10,043 MN
JERICOGTX
MN
Unfortunately, we play the game. If you want to Play, you gotta pay.
69 GTX
68 Road Runner
Re: Cam prices
[Re: mopar dave]
#3164836
08/01/23 01:31 PM
08/01/23 01:31 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
I have purchased three roller cams the past 10 months. One was just received from Bullet that’s as ordered a month ago. The prices keep going up like everything else. One of the cams I have ordered was a custom cam. Truly custom meaning we moved the lobes around not just changed numbers. I didn’t think the cost for any of them was that out of line with everything else. Just ordered my third set of BAM lifters as well and they have not been horrible either
Re: Cam prices
[Re: mopar dave]
#3164837
08/01/23 01:32 PM
08/01/23 01:32 PM
Posts: 553 Kentucky
clovis
Kentucky
Fast
What is the ballpark range for a "racier" flat tappet that has been coated? I have another engine that I was thinking about putting together and would need another cam, so inquiring minds want to know.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Cam prices
[Re: clovis]
#3164858
08/01/23 02:36 PM
08/01/23 02:36 PM
fast68plymouth
So. Burlington, Vt.
A custom 3 bolt from Comp is now $340+ shipping, not including the Nitride process($135). Even the racier shelf solids are $325 and up. As an example: https://www.summitracing.com/parts/cca-23-632-5The shipping has also crept up, with charges for shipping just the cam ranging from $25-45.
Re: Cam prices
#3164859
08/01/23 02:40 PM
08/01/23 02:40 PM
Posts: 1,148 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What's a BBM solid roller going for now?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Cam prices
#3164874
08/01/23 03:16 PM
08/01/23 03:16 PM
Brad_Haak
Loudoun County, VA
Given the cost of the solid flat-tappet you mentioned above, I was expecting higher for a sold roller. All in due time, I'm sure...
Re: Cam prices
[Re: Brad_Haak]
#3164878
08/01/23 03:35 PM
08/01/23 03:35 PM
fast68plymouth
So. Burlington, Vt.
The rollers have snuck up a little here and there. The FT’s went up like $95 over night(my cost).
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase.
Re: Cam prices
#3164998
08/02/23 01:32 AM
08/02/23 01:32 AM
Posts: 3,089 Michigan
A727Tflite
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase. New question - who regrinds roller camshafts? I have a couple older Crane and Cam Dynamics rollers that have bad scuffed lobes. All are .750” lift - was wondering if you may have the answer to this regrind question.
Re: Cam prices
[Re: A727Tflite]
#3165009
08/02/23 07:53 AM
08/02/23 07:53 AM
Posts: 4,077 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase. New question - who regrinds roller camshafts? I have a couple older Crane and Cam Dynamics rollers that have bad scuffed lobes. All are .750” lift - was wondering if you may have the answer to this regrind question. I've had a few done at Bullet so far and am very happy with the results.
Re: Cam prices
[Re: HardcoreB]
#3165030
08/02/23 09:54 AM
08/02/23 09:54 AM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
For some reason, the “street” FT cams are still less $$$........ but still saw a noticeable increase. New question - who regrinds roller camshafts? I have a couple older Crane and Cam Dynamics rollers that have bad scuffed lobes. All are .750” lift - was wondering if you may have the answer to this regrind question. I've had a few done at Bullet so far and am very happy with the results. I had one reground by Crower earlier this year. So, they'll do them as well. Price was reasonable and the turn-around was not too bad.
Re: Cam prices
[Re: HardcoreB]
#3165220
08/02/23 11:07 PM
08/02/23 11:07 PM
Posts: 6,148 Melbourne , Australia
LA360
The issue with regrinds, is the possibility of going through the heat treat. Fine if you are using a tool steel through hardened core, but I have seen a few failures of 8620 cores.
Alan Jones
Re: Cam prices
[Re: LA360]
#3165256
08/03/23 09:16 AM
08/03/23 09:16 AM
Posts: 2,521 PA
moparacer
PA
I have had Midway performance (Predator cams) in Mt Carmel PA clean up or regrind several cams for me over the years.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
