trans mount question #3164784
08/01/23 10:01 AM
08/01/23 10:01 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I've been searching all over for a trans mount that has about 1" thickness when compressed/fully tight. Because of some adjustment of engine mounts and a custom trans crossmember, I need to get the tailshaft of a 'glide a bit lower than what normal oem thickness range mounts will allow. I tried the thinner mount used on Muncie manuals, but that one is 1 3/8" thick when tight. I really dont want to run a solid mount. The car does not have a front or mid plate, and it has energy suspension motor mounts. I just wanted to see if anyone had found any alternatives like I described. Thanks!
Re: trans mount question [Re: mopar873] #3164880
08/01/23 03:54 PM
08/01/23 03:54 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
use the thinner mount with alum spacer to get it where you want it
....BAD A$$ STREET CAR.....
Re: trans mount question [Re: n20mstr] #3164962
08/01/23 09:18 PM
08/01/23 09:18 PM
iagree wrench scope up that way you get it exactly were you want it up
Re: trans mount question [Re: mopar873] #3165007
08/02/23 07:36 AM
08/02/23 07:36 AM
gregsdart Offline
gregsdart  Offline
You can also fab up something using rubber shock biscuits possibly. I made a mount that way, to support the trans but allow for flex. 25 years, no issues, both mid and front plates.
Re: trans mount question [Re: gregsdart] #3165027
08/02/23 09:34 AM
08/02/23 09:34 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I already tried the thinner style mount and it wasnt short enough. I think I am going to go with your idea and make one
