.005" oversize rings? #3164732
08/01/23 02:39 AM
08/01/23 02:39 AM
Detroit, MI
CokeBottleKid Offline OP
Detroit, MI
So... I'm building this motor with .030 over pistons (4.03" bore)... I bought the rotating assembly used off market place for a decent deal. Got it all machined and I'm ready to start file fitting these Total seal rings I got in the kit... put the first top ring in the bore and the sucker is butt up against itself hard.... only then for whatever reason I checked the part number to find they're .035" oversize... I asked my machinist what the deal was, did this guy [censored] up or did he do it for a reason? Machinist says "Because that's the trend. It's gay" laugh2. He didn't really offer an explanation for it tho, other that it became a thing about 20 years ago. Has anyone else heard of this? Is this peoples attempt to fine tune ring tension? I'm not really looking forward to grinding the [censored] out of all 4 rings for each cylinder.....
Re: .005" oversize rings? [Re: CokeBottleKid] #3164737
08/01/23 05:59 AM
08/01/23 05:59 AM
gregsdart Offline
gregsdart  Offline
Yes. All good performance builds will have the rings custom file fit. You need a tool you can buy at Jegs, etc, to effectively file the rings. Google it. File fitting piston rings. It is worth the effort. The top and second rings are PROBABLY the only ones needing a file fit. The oil rails may already have clearance. The top ring is critical to beat outcome. The second, a little less critical
Re: .005" oversize rings? [Re: CokeBottleKid] #3164739
08/01/23 06:10 AM
08/01/23 06:10 AM
Locomotion Offline
Locomotion  Offline
Fine-tuning the gap will help performance but you have to have the patience to do it. Gotta sneak up on the target gaps because you can't go back if you file too much. Go by the piston mfg. instructions because gap specs vary. Hypereutectic pistons, for example, require wider gaps. Basically file fitting rings is to minimize blowby but there are different recommendations and differences between top & second. Top & 2nd ring tension can be adjusted by back-cutting & spacers, usually done on class cars to get the most HP out of a combo despite the high cost. Oil ring tension adjustment is more common and cheaper. That's determined by the expander under the oil rings.
Re: .005" oversize rings? [Re: CokeBottleKid] #3164761
08/01/23 08:59 AM
08/01/23 08:59 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, that's just how they are. Won't even go in there.
They are smarter than we are. (Just ask them to make sure).
Re: .005" oversize rings? [Re: CokeBottleKid] #3164771
08/01/23 09:17 AM
08/01/23 09:17 AM
A727Tflite Online content
A727Tflite  Online Content
What machine shop did you take it to?
Re: .005" oversize rings? [Re: A727Tflite] #3164775
08/01/23 09:32 AM
08/01/23 09:32 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You didn't state if this build is a bracket racing engine or for your grandmother. If it is a high performance build, he sold you the right stuff. If they weren't 5 over there wouldn't be anything to file fit. You normally won't be filing the oil ring, just check a few. It will take you an hour or so with one of those hand crank ring files to do the top 2 rings. This plan is supposed to be mo better. You can still buy rings for a stated bore size and the gap will fit into SAE specs but that is not considered a proper high performance build.
2011 Drag Pak Challenger
Re: .005" oversize rings? [Re: CokeBottleKid] #3164846
08/01/23 01:58 PM
08/01/23 01:58 PM
I have bought and used two different ring filers, one mechanical that you rotate with one hand while holding the ring against the grinding wheel and the other one is battery powered that I hook the charger up to while using it and way easer and better to use.
I gap my rings way wider now than the minimums due to seeing the rings end butt and hurt the cylinder walls and pistons when they are driven on the streets in slow traffic in the summer times in SO CA up scope
On 440 motors I shoot for .020+ and more on the second ring like .024+ up wrench
Re: .005" oversize rings? [Re: A727Tflite] #3164918
08/01/23 06:50 PM
08/01/23 06:50 PM
Detroit, MI
Detroit, MI
Dizusters friend
Re: .005" oversize rings? [Re: CokeBottleKid] #3164920
08/01/23 06:52 PM
08/01/23 06:52 PM
Detroit, MI
Detroit, MI
Yes I see, didn't know that's how they referred to 'file fit' ring packages.... I'm not really sure I see the value tho, as most non file fit rings have to be file fit anyways, and I don't have to remove .020" from each ring...
Re: .005" oversize rings? [Re: CokeBottleKid] #3164935
08/01/23 07:45 PM
08/01/23 07:45 PM
Dizusters friend
I assume it’s Dave, Dave does first class work. I asked because you stated he said it started about 20 years ago. It’s been a thing for much longer than that.
I remember filing rings in the 70’s, when I bought my first rotary filer from Sealed Power. Before I bought it we used a file.
Re: .005" oversize rings? [Re: A727Tflite] #3164939
08/01/23 08:00 PM
08/01/23 08:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
^^^^^ this. I bought a hand crank ring filer about 1975. Don't remember who made it. shruggy It was red. laugh2
Re: .005" oversize rings? [Re: A727Tflite] #3164997
08/02/23 01:29 AM
08/02/23 01:29 AM
Detroit, MI
Detroit, MI
Dizusters friend
Ya Dave's the best. I've always filed mine by hand, but mine have always been drop in sets that needed no more than .005" removed...
You should consider changing your nick... means something entirely different these days... :P
Re: .005" oversize rings? [Re: CokeBottleKid] #3165043
08/02/23 10:56 AM
08/02/23 10:56 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've lost the spare grinding wheels for my hand crank filer. Does anybody know who has those?
Re: .005" oversize rings? [Re: rickseeman] #3165046
08/02/23 11:00 AM
08/02/23 11:00 AM
Summit luck scope twocents
Re: .005" oversize rings? [Re: Cab_Burge] #3165116
08/02/23 02:22 PM
08/02/23 02:22 PM
X
Re: .005" oversize rings? [Re: Cab_Burge] #3165258
08/03/23 09:22 AM
08/03/23 09:22 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Re: .005" oversize rings? [Re: A727Tflite] #3165489
08/04/23 03:45 AM
08/04/23 03:45 AM
Detroit, MI
Detroit, MI
Originally Posted by A727Tflite
X
Haha didn't get to see your post before you deleted it, but I see you changed your name laugh
Re: .005" oversize rings? [Re: CokeBottleKid] #3165493
08/04/23 06:28 AM
08/04/23 06:28 AM
X
Thanks for the suggestion on the name change.
