Removed the dash to R&R the a/c evaporator and everything else while in there (son's truck). On start-up to recharge a/c, compressor won't engage, speedo is at 120, and abs/brake lights are on. Had the battery disconnected while doing the work.
Finally found an EWD online this morning. Found a pin had backed out of a connector.
The speedo problem evidently is common to Dakotas after having the battery disconnected for as short a time as 15 minutes.
Here's the fix-
1. Ignition switch off
2. Press and hold the trip reset knob
3. Turn the ignition switch to on but do not start.
4. Hold the reset knob for approx 10 seconds
the dash panel will go through a self check
Be ready to write down any codes that show up on the read out.
I had to do it twice before the speedo went back to 0.
Hope this helps someone else out.
Tim
