Re: How much steam from W9's naturally aspirated?
[Re: dustyhof]
#316394
05/12/09 10:54 PM
05/12/09 10:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine is a fairly mild set up and it makes like 720hp with a single 1050. I could use a bigger cam and more carb at 405ci
[Re: MR_P_BODY]
#316396
05/12/09 11:00 PM
05/12/09 11:00 PM
Posts: 502 Huron, South Dakota, United St...
dustyhof
What do you think it would make if you turned up the wick? Is more stroke and bigger cubes better? It looks pretty easy to get 440+ cubes with a race block.
[Re: dustyhof]
#316399
05/12/09 11:23 PM
05/12/09 11:23 PM
Posts: 6,149 Melbourne , Australia
LA360
Most of the WOO stuff is making well over 800hp with the W9RP on Alcohol, but it wouldn't make that power aspirated. The RP stuff doesn't seem to perform on gasoline.
How much power is going to be dictated by how many cubes and how hard you're prepared to turn it.
Have you looked into a complete R5/P7 deal?
AL....
Alan Jones
[Re: dustyhof]
#316401
05/12/09 11:30 PM
05/12/09 11:30 PM
Posts: 243 NJ
arc
NJ
Just wanting to know what some of the most impressive W9 combos that you know of, made? Can be RP or standard, as long as you can still find some of this stuff and it works in a drag race application. I don't want some one-off pieces that you can't find anywhere like some of the W8 stuff. I'm going to be in the parts collecting stage of my car again soon, and I would just like a proven combo to start tracking down pieces if I come across them. I don't want to re-invent the wheel. Thanks!
I dont have any dyno # but i built a 4" stroke 4.185 bore w 9 that has run 8.88 in a 2800 cuda with a rons injection
[Re: Dartman75]
#316405
05/13/09 01:01 AM
05/13/09 01:01 AM
MR_P_BODY
some recently dyno'd a W9 combo at a bit less than 1000 HP: https://board.moparts.org/ubbthreads/show...e=6&fpart=1
From what I understand the W9 is a lighter update on the W8 and likely with the Raised Port version could have more potential.
I imagine the bucks and the details behind that type of motor is pretty high.
Greg
Thats a W-8. Yes the W-9 is a light version of a W-7 and W-8 combined with some differences... the W-8 makes more power.
[Re: jim sciortino]
#316407
05/13/09 08:19 AM
05/13/09 08:19 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I seen a 435 inch W9RP make 825..but it was a nitrous motor..but had some very good parts in it..I seen the heads and they were really nice.. to pretty to put on a motor..LOL
I was told that a max effort W9 could make 900hp..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: jim sciortino]
#316409
05/13/09 09:25 AM
05/13/09 09:25 AM
FASTFISH420
Central,Ohio
We put together a W-8 15* NASCAR take off...
4.185 x 3.79, 13.8 comp, 420 cast intake, 4150 carb, about.760 lift @ the valve. Very mild stuff.
No lightweight parts...the engine is built for oxide. Made 861 @ 8100 and 635 @ 6400 on a very accurate inertia dyno.
A W-8 is not "exotic".
A max N/A single 4 cast intake W-8 will make 1000+.
I have yet to see a W-9 make that kind of steam and probably never will.
What I find hard to believe is not one company is casting a new W-8!!!
Jim..Looks like you have a happy dyno there 861..with that kind of compression,carb,and cam..boy that is hard to believe..
My old 16 degree W-8 would make 880hp on BES's dyno..with dominator,16.1,and 950 lift cam..and old technology..so I think your probably around the 800 to 820 range..
www.URE-RACING.com
[Re: FASTFISH420]
#316410
05/13/09 11:47 AM
05/13/09 11:47 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
I hope not.
This dyno seems to be real close to a number of cars that have made laps, including Emilio's blue Duster that won Pinks All Out. We've talked to a half dozen guys that run #s right on this dyno.
We have a good 15* head. It flowed just over 400cfm @.800 with good mid #s and speed, on MBEs bench, a done up 420 intake and a big 4150.
Time will tell. The Dart its going in will be finished and at ATCO in the fall. Its a big tire backhalf, with a good 3sp that we will gear and converter for N/A before we spray it next year.
[Re: jim sciortino]
#316411
05/13/09 12:20 PM
05/13/09 12:20 PM
FASTFISH420
Central,Ohio
Jim, There is nothing wrong with a 15 degree head..Tell you the truth..if I was to do a new head it would be a 13 degree..The 15 and up motors like rpm..when we changed to the 10 degree..the rpm came down..which is easier on the motor.but this is also with over 400 inches..but the 9400 rpm thru the traps is fun. A 360 cube with a 10 degree is another story.. What kind of rpm did the motor like on the dyno?..my 16 degree would go around 8900 before it would fall off?
www.URE-RACING.com
